Help Identifying Vintage Measuring Device
  • tollfree
    • Oct 2010
    • 19
    Hi all!
    Could you help please:
    1 What is this device for, and
    2 Who may need it now?
    On the box and on the board it reeds the same:
    74116D trans meas set
    SLS 1505D SHT 74/4
    serial N ... made in England by
    Standard Telephones & Cables Ltd London
    It is portable, of late 60's according to the date on the part inside, pre-printed-board assembly. Has inside some weird glass unit, a little bulb-like thing but with 3 wires (transistor?). I am very curious to find this out, so if there is no info available, would you please point to a right direction for a search. Thanks!
  • yyonline
    • Jul 2009
    • 692
    Re: Help Identifying Vintage Measuring Device
    I think it's a transmission measurement set used to measure signal levels in telephone lines. This isn't my area of expertise, so I could be totally off on that.
    • Dgtech
      E. Technician
      • Apr 2009
      • 1462
      • Steeler
      A vacuum tube maybe?? (See pic below to confirm) They come in different sizes and the inner wires are different.
      This unit may be something used with audible sounds.
      • Dgtech
        E. Technician
        • Apr 2009
        • 1462
        • Steeler
        There is a good read on this company on the site below.
        http://www.gracesguide.co.uk/Standar...nes_and_Cables
        • tollfree
          • Oct 2010
          • 19
          yyonline, Dgtech: thank you for your input. The bulb-like thing is a nickel size glass tablet with a little dot inside and three copper wires going out of it. There are two of them side by side: one is connected to the circuit, and another is SPARE! The company history kindly pointed to by Dgtech lists 1968 as "STC Footscray(?) announced new semiconductor devices", so I guess this realy may be the first transistor! My date reading on the right round db-meter is 1967. Would like to lean more on what might be the use of this nowadays...
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Blurb on device type:
            A Transmission Measuring Set is designed to fulfill all type of requirements for determination of signal level, insertion loss, transmission loss and return loss in cable circuits used in audio telephones.
            Mann-Made Global Warming.
            - Dr Seuss
            • tollfree
              • Oct 2010
              • 19
              ... learn
              • tollfree
                • Oct 2010
                • 19
                this is a spare one comparing to a nickel, you cannot really see the tiny dot inside.
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Transistors have been around in a usable form since 1947 and in metal cans at least since sometime in the 50's.
                  There was some experimentation with using glass because it was cheaper than metal cans but I think that was over by the 60's.
                  OTOH, it may be a totally custom part built in-house by someone or another.
                  Why don't you draw out the schematic and figure out what it should be.
                  - Dr Seuss
                  • tollfree
                    • Oct 2010
                    • 19
                    Thank you PCBONEZ, I didn't know the whole story on transistor inclosures. What home-made? - I cannot think of any other 3-connector thing. Might try to draw -- it will be fun, colored wires I still wonder what would be the use of this device now, there are digital transmission meters, they are at least smaller...
                    • Dgtech
                      E. Technician
                      • Apr 2009
                      • 1462
                      • Steeler
                      Post some pics of the circuit board inside. It's always fun to poke around at yesterday's electronic relics. I'm sure someone will have more info by looking at the pictures.
                      • tollfree
                        • Oct 2010
                        • 19
                        Here we go
                        Can't wait to sort it out, thank you very much for your input, guys!
                        • brethin
                          • Dec 2008
                          • 1907
                          Its a analog phone line tester for the old pots lines Pre any digital switching, totally useless now. Might find a collector that collects old juck that might be interested in it.
                          • tollfree
                            • Oct 2010
                            • 19
                            Thank you Brethin, great news really! Could you guess about the glass tablet device too, what is it and what's the function there?
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              That thing is in really good shape. - Nice find.
                              - Dr Seuss
                              • Toasty
                                • Jul 2007
                                • 4171
                                The glass bit looks like a spark gap or surge arrestor of some type. Hence the 'spare' one under the clamp next to the soldered in one. Might be filled with neon or similar gas that will 'fire' when voltage exceeds the rating.
                                Love the wiring! Precise bends and the looming is sweet!
                                veritas odium parit
                                • stretch0069
                                  Screwed Up Super Moderator
                                  • Oct 2003
                                  • 2658
                                  • oooo ess aaaaaaaaa
                                  If ya ever want to sell it, I know an guy that collects old telephones. He'd probably love that thing.
                                  "Its all about the boom....."
                                  Guns kill people like spoons made Rosie O'Donnell fat.
                                  We now return you to your regularly scheduled drinking.
                                  "Fear accompanies the possibility of death.....calm shepherds its certainty"
                                  Originally posted by Topcat
                                  AWD is just training wheels for RWD.
                                  • SolomonMan
                                    Vintage BK Precision 1403 Oscilloscope....
                                    by SolomonMan
                                    All,
                                    Some of you have helped me in the past and I am very appreciative of all the help! (I have fixed TVs/Stereos/ and other small appliances with your efforts...Thanks so much!!!
                                    Today I went to a local HAM Radio Festival. It was one of the smaller ones in our area. My stepfather is the HAM operator. I tinker in electronics but am a Software Programmer (27 years now).
                                    I was looking for a few odds and ends for some electronics work I have to do for the household/farm. Typically these type of shows have the grab bags or a electronics vendor...
                                    12-03-2023, 10:39 PM
                                  • Adam Biderman
                                    Nintendo switch HAC-CPU-20 help identifying resistors
                                    by Adam Biderman
                                    Good morning, I would appreciate help identifying resistors responsible probably for volume down / volume up buttons that I accidently knocked off while replacing fan connector. I enclose picture with location. Thank you for help in advance.
                                    07-19-2025, 01:49 AM
                                  • omaar
                                    Help Identifying an IC
                                    by omaar
                                    I need help identifying this IC and, if possible, the value of the capacitors next to it. It is part of the HDMI circuit of an EVGA RTX 2060 GPU. It suffered a short circuit, leaving the graphics card without video and the TV without image....
                                    06-06-2025, 07:48 PM
                                  • Digital Solutions
                                    Help Identifying IC on MacBooks Pro - 820-02020
                                    by Digital Solutions
                                    Subject: Help Identifying IC on 820-02020 (MacBook Pro A2338 M1, 2020) — C02045500 / EKQ8LL1A
                                    I'm working on a MacBook Pro A2338 M1 (2020) with logic board 820-02020.
                                    The machine has a power issue — not powering on, and I'm trying to trace the fault.
                                    While inspecting the board, I found a cluster of components
                                    This area looks damaged or burned — there are about 4–5 components that seem affected
                                    I've attached a close-up photo of the chip and its surrounding area (see...
                                    06-05-2025, 03:43 AM
                                  • m1ch43lzm
                                    70mai Dash Cam A510 - help identifying connector on camera module
                                    by m1ch43lzm
                                    Hi everyone
                                    I have a 70mai Dash Cam A510 which failed after about 3 months of being installed in my car, likely due to heat, i got it from aliexpress so no point in trying to return it for warranty (and shipping it back would cost me almost the same as a new one from ali)
                                    The camera would boot loop showing 70mai logo on the screen, sometimes it would boot fine then the live view would freeze or display purple lines
                                    I already took it apart, and found out that the camera boots fine if i unplug the camera module from the main PCB, sometimes "playing" with the connector...
                                    05-11-2025, 06:02 PM
