Using transistor as a relay.
    Im attempting to figure out how to install door switch panels in my car from a newer model year. Everything is pretty much just wired straight up just with different plugs.
    Except for the Lock/unlock switch.
    On my model year only the up-optioned vehicles like mine received a DDM (Driver Door Module) which is needed for keyless entry and the like. So some vehicles had the lock/unlock switch directly running the lock actuators by switching +12v to them and on the up models it would still switch +12v but only to a pin on the DDM which would then take care of actually running the lock actuators. Basically the switches are designed to switch positive.
    On the newer years, all vehicles receive a DDM so it simply sends VREF out on the lock and unlock wires and the switch itself when pressed shorts the corresponding pin to ground. They are only designed to switch to ground.
    So I need to have a setup I can use ground switched to switch positive. I confirmed the current through the switch on my car is around 35mA to the DDM.
    I have looked on the internet for how to do something like this, but I just get confused.
    Using what is given at http://www.rason.org/Projects/transwit/transwit.htm it looks like I would need a 28-29KOhm resistor as R1 and 280-290KOhm for R2 for the shown 2N3906. Does this sound right? I selected 13V as a middle ground input but there is a pretty wide range of voltage in a vehicle; do you think it would stay "saturated" in say the 10-15V range?
    Re: Using transistor as a relay.
    Wiring diagrams would help. - Hand sketch will do.
    This DDM thing is in parallel with the switches so either works the lock?
    Mann-Made Global Warming.
    - Dr Seuss
      Using a MOSFET may be more convenient since they don't need biasing resistors when used as switches.
        This is what I drew up last night using my original diagram and pasting in the newer switch design then wiring it up with relays. I think some sort of solid state switching action could be much smaller and less complicated as far as actual operation. Relays are way over kill for the actual 35mA going to the DDM.
        http://colt45.ws/cvn/DDM_lock_revised.gif
        The DDM is what actually operates the lock mechanism. The switch just tells it to do so. It basically a computer. It probably has relays of its own internally that operate locks.
          I think I'm lost.
          Have a drawing before the mods?
          Is the light bulb lookin' thing in the "Door Lock Switch" representing the lock's solenoid?
          - Dr Seuss
            My car: http://colt45.ws/cvn/DDM_lock.gif
            2010: http://colt45.ws/cvn/2010locks.jpg
            The light bulb is just a light bulb. I scaled it up because the screen shot is small so it lacks a lot of detail.
              Im liking the MOSFET idea! It looks like I need a P-Channel type.
              Would something like this work?
              http://www.mouser.com/ProductDetail/...jjUTbfift7g%3d
              I drew a schematic again. I tried to to a better job this time.
              http://colt45.ws/cvn/DDM_lock_FET.gif
                I have seen high power solid-state DC relays from Jaycar.
                The AC and DC types of solid-state relay are not interchangable.
                  I also seen solid state relays as well, but they were not cheap. If I was going to do that, I might as well get regular relays..
                  Also, I just realized my FET circuit will not work. It looks like they would have to be fed source voltage at the gate in order to actually turn them 'off'.
                    Why can't you move the grounded line from the switch to +?
                    My pc
                    CPU : AMD PHENOM II x4 @ 3.5Ghz
                    MB : ASUS M4A89TD PRO USB3
                    RAM : Kingston ValueRAM 16gb DDR3
                    PSU : Cooler Master 850W Silent Pro
                    GPU : ATI Radeon HD 6850
                      Then the light wont work.
                        oops didn't take not of that.
                        I'll be back soon i'll cook up something for ya.
                        My pc
                          Here is something using common components.
                          My pc
                            I don't see any functional difference in the two kinds of switches.
                            Why wouldn't this work?
                            - Dr Seuss
                              It's to do with the light on each switch from what I seen.
                              One system is pull low to do it's thing the other is pull high.
                              My pc
                                When all you do is change the switch that doesn't matter.
                                Looks to me like control of the light bulb is via something in diagrams 10-9 and 10-10 which aren't shown.
                                If that isn't true then looking at the original drawing it looks like the light would be on the whole time the ignition switch is, including when engine is running.
                                - Dr Seuss
                                  Well, that depends on how much current is required. If you can drive the load with a a couple of hundred milliamps, a Clare LCA110 can be had for $1.90 from Mouser. It will only do 240 mA max though, in the DC configuration (both Mosfet's in parallel.) 1A and 2A parts are available from other manufacturers, and they cost less than $5. I really like the solid state relays because there's no way to blow out the mosfet gate, since these are driven optically by an LED inside the package. It is, however, possible to blow out the LED if you forget to put a resistor in series with it, and some relays could be damaged by too much reverse voltage at the input. (So don't wire it up wrong!)
                                    The light bulb is always on in run or acc. That is all the +12v feed is for. The switch is connected to the ground side of the bulb.
                                      This is perfect! Thank you!
                                        Much simpler idea:
                                        As FET you can use: IRF5305, IRF4905, IRF5210, IRF9Z24, IRF9Z34.. or just about any P-Channel MOSFET in TO220 case(because you need very small current). TO220 for easy air-wiring and you can screw it to something.
                                        You can reduce R1 and R2 if you want... just need to R1/R2 = 10/1
