Finding the right large capacitors
    I need some 560uF 250V electrolytics to replace some that have failed in a plasma TV. I believe they must be low ESR as it is a secondary side. Although that being said the output current is probably less than 2A on this rail so maybe low ESR aren't required. The originals were Samyoung KMH. I *cannot* find anywhere in the UK that stocks them. The best I got were some Panasonic TS, not low-ESR, from Mouser, in the US. And I'm not really good on spending £12 on shipping from them when they only cost £3 each. (I need 3.) Badcaps.net store doesn't stock them either.
    If I can't get these in the UK would it be possible to arrange to buy these off someone on this forum that could source them from DigiKey, minus the $30 international shipping charge?
  • Jack Crow
    It's a CLASOB!
    • May 2008
    • 823
    Re: Finding the right large capacitors
    Tom,
    I had a similar battle some years back with printer chips for Okidata 320 printers.
    Got turned onto a vendor who for a price (not cheap) was able to sneek them out of Japan around Oki's regular shops.
    I know for a fact there are people in Japan that sell home market stuff outside the country. A friend got an exotic video game board that way for a sumo wresteling arcade game.
    He found that source on Ebay.
    In the case of your caps, who in the UK is authorized factory service for your TV?
    It can't be a unique part, who else makes a similar supply?
    Keep at it, sooner or later you will catch a break.
    Be well
    Jack Crow in Virginia USA
    "You are, what you do, when it counts"
    The Masso
    "Gravity, the quickest way down"
    Mayor John Almafi
    "You ever drop an egg, and on the floor you see it break?
    You go and get a mop so you can clean up your mistake.
    But did you ever stop to ponder why we know it's true?
    If you drop a broken egg you will not get an egg that's new?"
    MC Hawking
    • ipman
      • Jul 2011
      • 159
      Low-ESR caps are used afther high-frequency part of the switching power supply.
      Are you sure that's the way it is? Looks strange.
      • digge
        • Apr 2006
        • 296
        Found another thread here where PCBONEZ i think said that chemicon is the same. So here are datasheets for those to easier find replacements.
          Originally posted by Jack Crow
          Tom,
          Be well
          I have contacted eBay sellers with no luck thus far.
          The TV is a Thomson Wysius 42WM02L, a 42" plasma TV. It is essentially an LG inside. However a new power supply will set me back £100+.
          Yes, these are on the secondary side. They filter the "Vs" bus, which runs at around 190V. There are some primary side capacitors that filter the mains, these are 220u/450V x 3 plus a 100u/450V for the standby supply.
            Thanks for the link - didn't realise Samyoung were copying the series off Chemicon. Interesting, I may be able to source these easier.
            • digge
              • Apr 2006
              • 296
              I just happened to stumble across the comment from PCBONEZ over here
              https://www.badcaps.net/forum/showthread.php?t=15747
              • dragon3x
                by dragon3x
                power on.
                Here are some examples :
                switching supply area).
                than 6.3 V.)
                03-21-2025, 02:46 PM
              • slybunda
                AA and AAA battery charger capacitors?
                by slybunda
                hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                it has inside:
                2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                2 x 470uf 16v LZ105c branded as G.Luxon
                not heard of these brands are they any good?
                iv attached photos of the charger and the board inside for an idea on the type of...
                12-24-2023, 04:41 AM
                After all of...
                07-13-2024, 08:14 PM
              • Ady2017
                Are there any datasheets available for Elna RJG capacitors?
                by Ady2017
                I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                05-25-2025, 02:19 PM
              • ctroxtell
                Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
                by ctroxtell
                I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
                01-03-2025, 08:57 PM
