Charging Lead Acid Batteries
  • barry wilkins
    • Aug 2009
    • 172
    If you try to charge 2 batteries in parallel from one source of power, the battery with the higher capacity stops charging when the lower capacity battery is fully charged .So you cannot fully charge the larger battery.
    Does anybody know how to overcome this ?
    Barry Wilkins
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Charging Lead Acid Batteries
    If they are in parallel the charger will see the average voltage and since the charger charges to some set voltage I don't see how your assumption is even possible.
    Mann-Made Global Warming.
    - Dr Seuss
    • mysterfxit
      • 31
      Just googling I found the problem explained as the battery with the least impedance discharges (and I assume charges) at a faster rate than the other one. So over time one battery gets cycled repeatedly while the other is hardly used.
      That means you would get double the capacity, but you won't get double the life of using a single battery.
      http://www.rcgroups.com/forums/showp...18&postcount=3
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        "Level of charge" is called voltage and if they are in parallel they are at the same voltage.
        If one drops by 1 volt then so does the other.
        - Dr Seuss
        • quickname
          Cyberpower 1500AVR UPS repair
          by quickname
          I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
          I decided to verify that the batteries were...
          11-12-2023, 09:57 AM
        • orientalsniper
          LA-L246P Not Charging Batteries
          by orientalsniper
          Hello all, I've tried multiple batteries, replaced the charging IC (ISL95522AHRZ) and updated the BIOS.
          It detects the power adapter (90W), so the DC IN jack is okay.
          It shows "IDLE" instead of "Charging", battery health shows "Excellent" on the BIOS.
          09-15-2025, 02:29 PM
        • coasterghost
          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
          by coasterghost
          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
          System Hardware:
          Processor: AMD Ryzen 7 PRO 5850U
          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
          09-08-2025, 10:46 PM
        • Thomasraud
          Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
          by Thomasraud
          i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
          QUOTED
          -It works on charger (without battery connected-only charger)
          -It works on battery (without charger connected-only battery)
          -& it also works when plugged in battery & charger, but it's not charging the battery
          //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
          and..
          QUOTE
          The IC cannot maintain the input current level
          06-28-2022, 06:47 PM
        • carrzkiss
          Cyberpower cps1500avr not charging batteries
          by carrzkiss
          Hello, all.
          Cyberpower Battery Backup Unit.
          I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
          When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
          In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
          Checking the voltage, it was down to 22v.
          I quickly removed everything...
          06-15-2024, 02:10 PM
