Electronic Fluorescent Lamp Ballast
  • mysterfxit
    • 31
    My wife has a make-up mirror (zadro clv581) that stopped working. It was quite expensive and I'd hate to just toss it.
    It has a circular flourescent bulb, and switch for 3 levels of brightness. It's completely dead, not even a flicker.
    The components look OK visually. Can anyone give any advice on how to go about finding what's wrong here?
    Thanks.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Electronic Fluorescent Lamp Ballast
    Maybe unscrew TG1 and measure the DC voltage across some of those electrolytic caps to see if you even get power?
    --- begin sig file ---
    --- end sig file ---
    • cmj21973
      • 267
      Post a picture of the solder traces for both boards, please.
      • Rob Northen
        • Jan 2010
        • 137
        • Denmark
        Thanks.
        Toss wife, it will save you lots of money
        • Evil Lurker
          Warranty Voider
          • Feb 2011
          • 454
          Start by yanking ou the two transistors and test them
          • mysterfxit
            • 31
            I attached a composited photo of the fronts and the backs of the boards. I mirrored the back pics so that each everything lines up as if you were looking through the board from the top.
            L3 is kind of melty looking.
            • GeX
              • 4
              • Romania
              Check the C9 and C10 capacitors.
              • mysterfxit
                • 31
                I'm new to electronics repair so I'm trying to test the components while still on the board
                Testing the capacitors with a multimeter (set to ohms) C10 is the only one that didn't do a low resistance kick then fade to open. It stayed at a low resistance value (needle spiked.)
                • mysterfxit
                  • 31
                  The Transistors are labeled 13003 LZA.
                  I tested the transistors with multimeter set to ohms and they both give the same results. Current passes both ways between pins 1-3 and only in one direction between pins 1-2 and 2-3.
                  • b700029
                    Banned
                    • Sep 2010
                    • 640
                    You need to test components out of circuit for accurate results.
                    • Longbow
                      • Jun 2011
                      • 623
                      Technically this statement is true. To get all of the exact component specifications, run leakage tests, voltage break down tests, run curve traces showing hfe, linearity, etc. etc. then yes the component should be removed from the circuit. On the other hand, 99% of effective troubleshooting can be and actually IS done in the real world with parts in circuit. Not only does desoldering and resoldering risk damage to the pc board and components, but it takes a lot of time and is rarely necessary.
                      Is it plugged in?
                      • GeX
                        • 4
                        • Romania
                        Let's make a long story short: change C10 with a compatible one (value/voltage). I bet on this.
                        • mysterfxit
                          • 31
                          Thank you. The only markings on C10 are 608J 1000V. What Farad value is that? And I'm guessing this is a polyester film capacitor?
                          • Toasty
                            • Jul 2007
                            • 4171
                            Check that 8 please. Sure it's not a 3 ? Or the whole number is not 683?
                            608J would be 6000 uF, 5% tolerance. (it's a *tad* small in size )
                            603J would be 0.06 uF, 5% tolerance. (aka: 60 nF or 60,000 pF ) The size would be more correct.
                            "68" is a more common value
                            Usually caps run in numbers such as:
                            33, 47, 68, 100
                            -or-
                            33, 47, 56, 68, 82, 100
                            Actually (probably) a metallized polyester film.
                            Toast
                            PS: Can you post a broader picture/view so the input and outputs are more understandable. I can't be sure which is 110v in, output to lamp, dimmer switch. Thanks!
                            veritas odium parit
                            • mysterfxit
                              • 31
                              Thanks. I'll check the numbers again and take another photo when I get home tonight.
                              • mysterfxit
                                • 31
                                Here's a wider photo and a close up of C10.
                                • Toasty
                                  • Jul 2007
                                  • 4171
                                  6n8J = 6800pF or 0.0068uF, 1000v, 5%
                                  Thanks for the pics!
                                  EDIT: You are reading 0Ω across that cap? Try unsoldering one leg and testing it. If it's good then, perhaps the bulb is shorted? Does it glow or flicker at all?
                                  veritas odium parit
                                  • mysterfxit
                                    • 31
                                    Yes, IIRC there appeared to be very little to no resistance. I'll try testing it unsoldered it this weekend.
                                    The thing is completely dead. No flicker, glow or anything.
                                    Thank you all very much for the help!
                                    • Toasty
                                      • Jul 2007
                                      • 4171
                                      Essentially:
                                      Where Cr is C10 and C1 & C2 are C5 & C6.
                                      veritas odium parit
                                      • mysterfxit
                                        • 31
                                        Thanks.
                                        Funny. I don't know if I can get to desoldering tomorrow night, so I was going to ask if you can explain to me a bit what's going on in this thing.
                                        I know the diode symbols and I'm familiar with rectifiers from working on motorcycle charging systems. C's are capacitors, but why is Cr not numbered like the rest. What is L, B and M?
                                        • vestaviascott
                                          Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
                                          by vestaviascott
                                          Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
                                          Here's what happens:
                                          1) Power on
                                          2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
                                          3) Blue status light flashes for appx 4 minutes...
                                          07-29-2020, 06:08 AM
                                        • mikey5791
                                          Help on Samsung Syncmaster T220 dead ccfl lamp
                                          by mikey5791
                                          This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
                                          Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
                                          10-18-2020, 03:17 AM
                                        • khelane
                                          test active pfc power with lamp test
                                          by khelane
                                          Hello
                                          I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                                          Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                                          Is there a way...
                                          06-03-2025, 01:00 AM
                                          Electronic Goldmine has replacement Irons for the ZD-978 or similar model number this the one that has the sleep function
                                          by sam_sam_sam
                                          This is a new item at Electronic GoldMine that has arrived within the last few weeks
                                          Here is the link for them I know for sure that it works because ( I tried it on mine soldering station ) I bought two of them and I just bought two more of them so I have some extra replacement ones in my parts bin
                                          Stahl Tools DDDS Replacement Iron for DSDS Stahl Solder Station
                                          https://theelectronicgoldmine.com/products/g28392
                                          One note it will not work for the ZD-917 or similar model number that does not have the sleep function that are the same iron but the plug only...
                                          11-24-2024, 01:25 AM
                                        • Yanleb
                                          Sharp LC-60LE810UN Lamp Error
                                          by Yanleb
                                          I have this Sharp LC-60LE810UN that stays off and blinks a Lamp Error (1 long flash followed by a short flash, in a loop).
                                          I already confirmed that the first backlight strip has an open LED using a LED strip tester. The other 3 LED strips are fine.
                                          Before tearing the LCD panel apart, I want to make sure that the rest of the TV set is good. I've tested the power-supply/LED inverter board by sending 5 volt to PS-ON, to PNL-POW (that commands power the T-CON board only), OFL and STB pins. The power-supply is good.
                                          I've tried all the key...
                                          08-24-2021, 11:48 PM
