Warm CPU VRM components
  • lti
    • May 2011
    • 2550
    My old Compaq has a CPU VRM based on an SC1101 controller and is similar to the test circuit in the 2000 datasheet (the current datasheet has a different test circuit). The actual circuit uses an FDB603AL MOSFET, an S10S40C diode, less capacitance on the input (one 1000uF cap and one 1500uF cap), and different resistor values. The diode runs very warm and is almost too hot to touch, and the MOSFET and the controller IC are only slightly cooler. Why do these components run so warm? I don't know anything about switching power supplies and DC-DC converters.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Warm CPU VRM components
    Because they cheaped out and used components with high voltage drop (or high on resistance - mosfets). Or they simply didn't use enough of them. Or the board layout is tight and they didn't leave enough cooling area (D2PAK parts rely on the PCB area they are mounted on to cool them).
    Btw - the diode is rated 125C, the mosfet is rated 175C. If the manufacturer says the parts can take high temperature, there aren't too many efforts made to keep it low.
    A working TV? How boring!
    • lti
      • May 2011
      • 2550
      Why would the diode get so warm? It doesn't seem like much current should be flowing through it. I have added the SC1101 datasheet. Also, I measured 2.30V on the output with the output voltage set to 2.2V. The values of the resistors must not perfectly match their marked rating. There could also be a flaw in the circuit design (this is a Compaq).
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        It's not current alone that gives temperature of a diode. It's current times voltage drop over package plus heatsink area. Like i said, if the board layout is tight, then the diode will get hot.
        If the package is not over 100C (simple test - lick your finger then touch the diode and see if it fizzles) then it's operating under normal conditions.
        • lti
          • May 2011
          • 2550
          It isn't running that warm. It is just hard to keep your finger on it for more than a couple seconds. It isn't as bad now that I have a fan blowing over the VRM. The board is cramped, so there isn't much room to cool these components.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            A fan won't do much by itself but it's still an improvement. You can try sticking some ramsinks on top of them if you have spare ones, they will help more than the fan alone does.
            Reminds me of my Asus P55T2P4. Pentium MMX 200 @ 292MHz. Took quite a bit of heatsinking to pull that one off. For the CPU it was simple - a Socket A heatsink, for the VRM, not much so.
            • kaboom
              "Oh, Grouchy!"
              • Jan 2011
              • 2507
              That's not an old compaq!
              At least it has a proper PWM DC-DC converter. These old Presarios (and others) used linear regs for the CPU. Both the CPU and VRM were cooled by air entering the case through the holes on the left side. Just oversized heatsinks, the only fan was in the power supply.
              I have personally seen three out of a set of eight overheat and freeze when the 'genious' had them open to reinstall Win95. Don't even ask.
              I would concur with the ramsinks. LTI, are those semi soldered to the board or is there a screw, washer and nut? If it's the latter, you may be able to get some small TO-220 heatsinks in there.
              -Paul
              "pokemon go... to hell!"
              EOL it...
              All style and no substance.
              guilty,guilty,guilty,guilty!
              guilty of being cheap-made!
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                If you are really concerned you can put another same size diode in parallel with it.
                Mann-Made Global Warming.
                - Dr Seuss
                • lti
                  • May 2011
                  • 2550
                  -Paul
                  This computer is a Presario 2286. It is cooled in the manner you mentioned, but the VRM is not in the airflow path. The original power supply fan spun so slowly that there was no air coming out of the exhaust vent. I put a better fan in the power supply and the original power supply fan is now on the CPU heatsink and connected to a homemade fan controller. This computer uses the same case, motherboard, and power supply. The components are soldered to the board.
                  If those computers overheated with the top cover off, they must have been close to overheating with the cover on. This one has never overheated. If it does, my fan controller has an alarm.
                  I would like to know what purpose the diode has.
                  • pfrcom
                    Oldbie
                    • Jun 2006
                    • 1230
                    100% for persistence https://www.badcaps.net/forum/showthread.php?t=14686
                    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                    • kaboom
                      "Oh, Grouchy!"
                      • Jan 2011
                      • 2507
                      When the MOSFET is turned on, current flows through the inductor to the load. Due to the inductance, the current increases with time, as a magnetic field builds up. When the MOSFET turns off, the diode commutates the current still flowing through the inductor to the load. The inductor stores energy in its magnetic field so as to make the PWM possible. The diode, or bottom MOSFET if synchronous rectification is used, is the current path when the top MOSFET is off.
                      Without the diode, the nature of the inductor to 'keep current flowing' would generate nasty spikes.
                      These pdfs may help.
                      -Paul
                      EOL it...
                      • lti
                        • May 2011
                        • 2550
                        What maximum voltage and current should the diode be rated for? Is the current 10A, 40V diode good enough? This voltage regulator currently powers an AMD K6-2 running at 500MHz, but the diode ran just as warm with the original Cyrix MII-333GP CPU.
                        • b700029
                          Banned
                          • Sep 2010
                          • 640
                          40V is plenty since that diode is in the Vcore circuit which is below 3.3V (and ~1V these days). I'm not sure of the power output of the CPU but 10A may or may not be sufficient depending on how many diodes there are. (For comparison, modern CPUs now consume around 100A at full load )
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            If you are going for two diodes in parallel then use a matched pair least one take all the load and the other do nothing.
                            - Dr Seuss
                            • lti
                              • May 2011
                              • 2550
                              The diode is connected to ground, so the full output current doesn't pass through it. I don't know how much power the CPU draws. The diode that is currently installed is actually two 5A diodes in a single package.
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                http://www.m571.com/m571/m571_amd.htm
                                21W @ 2.2 volts = 9.55A.
                                • chickenhawk88
                                  Troubleshooting Razer Blade 15 DA560
                                  by chickenhawk88
                                  I started troubleshooting this Razer Blade 15 laptop DA560 motgerboard a while back, due to some shorted 19v, 5v, 1v power rails. I fixed some of components and think 19v rail is good, 5v rail is good, 3v is better but not all way i think, and 1v is still bad. At this point the diode reading on these rails are 19v - 0.032v , 5v - 0.167v, 3 - 0.63v and 1v - 0.005v .
                                  When the rails when down, I went down different rabbit holes and seeing chips getting pretty warm on thermal but not blazing hot. Yet there were not any caps or any small components getting blazing hot. Example is EC chip,...
                                  06-06-2024, 11:35 AM
                                • dj8452000
                                  How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                                  by dj8452000
                                  I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                                  02-18-2025, 08:28 AM
                                • bendeg
                                  Test circuit for curiosity : 2 x NE555 (astable + PWM) + n-mosfet + var 10k + pc fan
                                  by bendeg
                                  Hi reader,
                                  I'm trying to control a pc fan speed by giving PWM to the gate of a n-mosfet.
                                  1) generation of a clock with a 555 timer (~ 1,5 kHz, as seen in the datasheet, fig.12) (Vcc = 6V).
                                  Output to TRIG of second timer (pin 2) + red led
                                  2) generation of a PWM with a second 555 timer (as seen in the datasheet, fig.18), CONT (pin 5) modulated by a variable 10k resistor (Vcc)
                                  3) Using output of second timer to "pulse" n-mosfet gate (MDP13N50) + yellow led
                                  4) pc fan (12V, 0.18A) in series in drain-source of...
                                  05-01-2023, 07:59 AM
                                • davidebaldini
                                  ATX power supply keeps blowing PFC mosfets — Cooler Master RS-550-ACAA-E3
                                  by davidebaldini
                                  This is an ATX PSU rated for 550W powering 24/7 a computer load of about 200W, fed by a line-interactive 1500VA UPS. Mains is 230V.
                                  1. First issue: the PSU blew a mosfet on what I think is the active PFC boost converter, shorting its G D S pins together causing a short across the + and - lines produced by the rectifier on the 230V mains. The surge protector of the house tripped. When this happened I found that the UPS was unexpectedly disconnected from the wires of its battery. The UPS wasn't damaged, but I suspect this spontaneous detachment of a battery wire caused a condition that blew
                                  01-25-2023, 02:23 PM
                                • Cecilius
                                  Huawei Matebook D15 - DAH98AMBAD0 Rev.:D dead
                                  by Cecilius
                                  Hi, I just come to this laptop with symptoms from owner - it stop charging. Thought it would be easy USB-C replacement (matebooks known issue) I took it. But port is good. After charging battery from power supply laptop is still dead. No power to EC chip. I'm out of ideas what to check next.
                                  Next to 3.3V LDO which is only active rail after main rail is a circuit which sends voltage to EC chip. I don't understand at all function of this circuit. It consist of 2 PNP transistors few resistors and P-channel mosfet. Below is a circuit diagram of that part with explanation. Does anybody...
                                  02-19-2025, 07:52 AM
