Cordless Norelco shaver
  • Hondaman
    • Sep 2008
    • 1061
    I've had a Norelco 7xxx series rechargeable shaver for about 6 years now. The instructions tell me to dispose of the NiCd batteries properly at the end of the product's life, and tell me how to take the unit apart to get them out.
    It still works great -- and I plan to keep it as long as it keeps running. So how long will the batteries last? Would there be any problems switching to NiMH at some point? Would NiMH batteries overload the "wall-wart" charger? Any benefits to switching to NiMH?
    (My 18-volt Makita cordless rechargeable drill is about the same age, and it won't run for more than a few minutes with a full charge -- far, far less than when it was new. So whether NiCd or NiMH, all rechargeables wear out at some point.)
    Thanks in advance!
  • Eagle2a
    • Aug 2009
    • 35
    Re: Cordless Norelco shaver
    I would stay with NiCds. NiMH batteries are not capable of the high currents that NiCds can supply. There's no way to predict how long they'll last. It depends on the quality of the cells and how they're treated. Definitely don't overcharge them and try to run them full cycle as much as you can. There are several websites I've found on rebuilding battery packs for power tools, etc. Generally only one (or just a couple) of cells in a battery pack fail, causing the entire pack to fail. You can replace them after disassembling the pack and testing individual cells to determine which ones are bad. I've rebuilt smaller battery packs with good success and wouldn't hesitate to rebuild the larger packs for my power tools when they eventually fail.
    • carrzkiss
      Cyberpower cps1500avr not charging batteries
      by carrzkiss
      Hello, all.
      Cyberpower Battery Backup Unit.
      I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
      When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
      In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
      Checking the voltage, it was down to 22v.
      I quickly removed everything...
      06-15-2024, 02:10 PM
    • howardc64
      Where do repair shops buy MB replacement batteries?
      by howardc64
      Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
      Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
      BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
      07-25-2024, 10:42 AM
    • dbuergi
      DIY: Modified smart charger for all types of batteries
      by dbuergi
      sometimes i'm in need of a charger / tester for very small batteries and even if my multimeter doesn't show anything there is a chance that a smart charger helps to revieve. I'm happy with my Keenstone smartcharger and i made a small mod just to use it with smaller batteries like in smartwatches or even camera batteries with special contacts.
      Soldering wires on the charger contacts and using needles as probes. I covered both with a shrink hose with integrated solder.
      My first work was to bring my Samsung watch battery back to life with was not recognized...
      07-18-2025, 03:17 AM
    • davidebaldini
      UPS ruins batteries every three months
      by davidebaldini
      Problem description:
      My UPS requires new batteries every ~3 months; in this time frame, an average of about 5 to 10 power flickers or short power interruptions (< 2 minutes) occur. After an average of 3 months, a new pair of batteries begins to fail to keep the UPS up during any flicker or power interruption. The load it powers is a single computer/workstation running 24/7 with a continuous consumption between 200W to 300W.
      UPS model:
      The Atlantis 1001 is a non-inexpensive (~120€ back then) home/office offline UPS, rated 1000VA, 600W, designed for two 7Ah...
      10-02-2019, 06:19 AM
      Here is a good used source for 18650 batteries
      Here is a website I have ordered from before and the results that they claim are correct from what I have seen from the batteries I have bought from them
      BatteryHookUp.com
      https://batteryhookup.com/collection...odem-batteries
      I have test about 5 battery packs ( out of 15 battery packs I bought) and have had very good results and so far have not found any bad cells
      I have also bought these battery packs before on EBay and they are a good source for a battery case that holds 18650 batteries however...
      06-25-2021, 05:05 AM
