Suitable resistor replacements?
  • Agent24
    I see dead caps
    • Oct 2007
    • 5039
    • New Zealand
    Re: Suitable resistor replacements?
    I can't offer any concrete advice, only what I have heard and what I can remember (and which may be wrong)
    Might be worth waiting for someone else to answer as well, and\or reading up about it yourself: http://www.maxim-ic.com/app-notes/index.mvp/id/726
    If you already ordered it, might as well try it and see what happens. Pity you broke the original one though, especially if it turns out it wasn't faulty and you need it back...
    -David VanHorn
    • daimoku
      • Feb 2011
      • 85
      Thanks! I read as much about crystal oscillators as I could and I have to admit some of it is over my head at this point. However, it seems that orientation does not matter.
      Well, the Digikey order came in today. I installed the crystal by itself first to see if it exhibited the same symptoms and luckily it did (except no scratchy noise now)...whew!
      I knew the main board had a lot of bad caps so I replaced about 20 bad caps...mostly 35V470uF, a few 35V220uF. Now, the symptoms are slightly different.
      Before: The tv would run for a while and it would shut off on its own. After it cooled for 10-15 minutes, I could turn it back on.
      Now: The tv will run for a while and shut off on its own. However, I can turn it back on immediately.
      Mike - I took your advice and ordered extra of each common component to have them on hand for future repairs.
      I think I'm going to purchase/build an isolation transformer maybe with a built-in variac so that I feel more comfortable taking voltage measurements on a live circuit. That will make the troubleshooting process easier to hone in on which board to test.
      I hear a zapping noise coming from one of the power supply inductive components so I suspect it might have a short. I thought I checked it before, but I'll double check with the ring tester while it's cool and when it's warm.
      Any advice on the purchase vs build isolation transformers with or without built-in variac? Which transformers are well-suited for this task?
      • Agent24
        I see dead caps
        • Oct 2007
        • 5039
        • New Zealand
        I'd re-post with details of your current work and findings in the TV section of the forum, in general electronics with a title about resistors I doubt it will get much attention.
        -David VanHorn
        • belamex
          • Jun 2012
          • 12
          DId anyone find a solution? My NS-LCD32 shut off suddenly. When I press the power button, only the green light comes on. no sound. no pic. I cannot figure it out. I want to test the PS but not sure what to test. Any pointers?
          • gica69
            Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
            by gica69
            I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
            Resistor shows orange range silver gold and green lines.
            Thanks in adv...
            07-21-2025, 09:49 PM
          • mikey5791
            by mikey5791
            Hi to all forum members,
            12-26-2024, 04:55 AM
          • прямо
            Help me decide which MOSFETs are suitable replacements
            by прямо
            Friends,
            I need help. I'm having a bit of difficulty in deciding what would be the compatible replacement for these MagnaChip N-Channel Trench MOSFETs on a VRM circuit because they seem to have a much faster switching times compared to most N-Channel Trench MOSFETs out there that have the same (more or less) current rating and Rds(on)
            MDD1502 (high side), 48.5A 7.8mOhm
            MDD1501 (low side, 2 in parallel), 67A 5.6mOhm
            VGS is 10V High side drain is 12V. Low side drain is from PWM controller (Richtek RT8120A) phase output 1V.
            Here are the ones...
            02-01-2024, 09:06 PM
          • chth96
            Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
            by chth96
            I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
            Since then, This AC/DC adaptor have been out of order.
            But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
            After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
            And Is there any possibility that it will suddenly explode as well as to be out...
            12-03-2023, 04:40 AM
          • narf
            Epson EB-U42 projector / Caps with 0.7 ohms ?!
            by narf
            hi all,
            first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
            i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
            what i've found so far:
            - the PSU does its job and supplies 12V to the mainboard via the connector.
            - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
            - not far away, there's the first cap with a resistance of 0.7 ohms....
            07-02-2024, 03:53 PM
