Philips 9965 000 27114 varistor
  • steve2
    • Dec 2010
    • 121
    A friend of mine that is in Afghanistan asked me if I could get him a couple parts. 2 varistors that blew up with the fuse when the guy plugged it into the 220vac outlets there. It is a Philips HTS3371d home theater. I have been looking , but can't cross it to anything or find it. 996500027114 brings up some on google, but NLA and doesn't give the specs on it. Does anyone know the specs or a replacement for it. Also he needs a Nichicon GW series 470uf 200v for a Toshiba tv that digikey and mouser don't have in stock. Any help appreciated. Thanks
  • steve2
    • Dec 2010
    • 121
    Re: Philips 9965 000 27114 varistor
    I'm good to go. I found a different manual with the same varistors but on the schematic, it had the part #. TVR10-241KS. I sent him an email to see if he had 5mm more diameter space for the cap as digikey had the cap in 250v GW series.
    • chth96
      How can I identify varistor which have been blew up?
      by chth96
      I mistakely pluged 100v japanese retro game console to 220v outlet.
      So It seems that glass fuse and varistor have been blew up.
      I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
      Is there any way to identify varistor type in my sega saturn PSU?
      Any reply would be appreciated.
      EDIT:
      It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
      11-26-2023, 08:52 AM
    • G33RT
      Philips 8200 series 65PUS8204/12 stuck at Philips Logo
      by G33RT
      Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
      It does power up when pressing the power button.
      I already try the power button while plugin the plug with no result.
      Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
      Could this be an PSU or eMMC issue ?
      07-19-2025, 03:43 AM
    • aidanmo
      Philips 43PUS7506/12 - Loud blown out sound
      by aidanmo
      I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
      I thought maybe the speakers got damaged, so I replaced them - no dice.
      • Using the internal speakers, it always happens.
      • Using the headphone jack, it never happens.
      • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
      02-28-2025, 03:13 PM
    • Cornito
      Philips 50PUH6400 bad color and gosting / slow motion on one side
      by Cornito
      Hello Team,
      New issue on LCD panel where I need to find out the cause and the potential solution.
      This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
      I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
      When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
      I've checked voltages, no issue found comparing right and left side of the panel driver.
      VHG VGL CKV... are the sames on...
      03-08-2024, 06:41 AM
    • spantor
      Activate power board Philips 40PFH40009/88 tv
      by spantor
      Hello partners.
      Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
      The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell...
      02-11-2024, 05:07 PM
