I picked up a pair of UPS batteries today for $4. They are spec'd at 12v, 7.2Ah and made by "Kung Long Batteries Industrial Co Ltd". One of them is good, the other collapses under load. But i find it interesting that both charge at a ridiculously slow rate - 400ish mA. I've charged cellphone batteries with more current!
The current increases only if i increase the voltage beyond what is safe for those batteries - they need 16-17v to really get going. At this level i hear gas forming, and AFAIK if the cells are gassing it means they are good. I don't want to fill my floor with acid however.
I've read about pulsed charging restoring sulfated cells to useful life, so i dug out an old AT power supply (they are stupid easy to mod), and made it into a ghetto pulsed charger. I removed the 12v output capacitor, this oughta make enough pulse. I tried to jump the inductor as well but the PSU didn't like it - on AT PSUs the TL494 is fed from the 12v rail. With just the capacitor removed things work fine because the batteries themselves are acting like a huge cap.
I also wired a pot between the positive input of the TL494 error amplifier and ground, so i can set the voltage to whatever i like. Btw, on this particular supply the second error amp isn't even used - the 12v and 5v are resistively summed then sent to error amp 1. Group regulation at its best.
I set it so that the weaker battery doesn't exceed 14.8v, and let it do its thing. I noticed that the current increases briefly if the batteries have been put under load then immediately connected to the charger. This is reminiscent of NiCDs and NiMHs that had grown crystals - i used to zap those with a 100uF capacitor charged to 250 volts and they would start charging afterwards. But at the size of those batteries i'm not sure how much that would help.
I'll be letting them charge overnight and see what happens, trickle charging never hurt anything. Now i'm looking for an UPS to drop them in.
