Replacing motor brushes
  • Dammon
    Ensign
    • Jun 2010
    • 36
    I've got a really old electric lawn mower that needs new brushes for the motor. I don't have the manual for it and it's no longer supported by the manufacturer, so I have no idea which part to get. Can I just use some generic brushes that are the same size, or is it important to match the hardness of the original?
  • steve2
    • Dec 2010
    • 121
    Re: Replacing motor brushes
    The brush hardness will determine how long they last, so I would put whatever I could find if I can't find the originals. If they are softer , just have to replace more often, but if you have had it that long and just now needing brushes, you are doing good.
    • JackDani
      • Sep 2012
      • Ukraine
      hi guys!
      I also need new brushes for my motor. I have the motor with specifications like in this one https://www.mrosupply.com/product/26...AC_Motors_Pump but its very outdated
      did you find the solution for you? can you advise something for me?
      thanks
      • t.j.
        • Apr 2010
        • 383
        • canada
        Originally posted by JackDani
        hi guys!
        thanks
        pull out old brushes an just match sizing to new one!
        • juergenb
          Nescafe Aeroccino, still fails with new Motor (red flashes only once)
          by juergenb
          i am asking for some Help.
          I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
          The Motor didn“t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
          So i got a few of these from Banggood.
          I swapped the motor and now i have a new fault condition.
          In a working Frother you would press the start button, it will light red and work for a few minutes.
          If you press longer it will light blue and just mixup the milk.
          With the new Motor it just starts...
          03-23-2021, 11:24 AM
        • DanielCoffey
          Bosch GRA53 36V Lawnmower - no motor
          by DanielCoffey
          Hi folks. I have a Bosch GRA53 36V lawnmower that has developed a fault and will not spin the blade.
          I should say for the purposes of guiding what how you can explain things to me that that I have only modest knowledge of electronics, own a basic multimeter and soldering iron.
          The mower is four years old, out of warranty, discontinued and the brand has been sold to Honda who have iterated on the design a couple of times and now sell their own 36V mower. My mower was effectively a prototype when Bosch tried the 36V Bosch Professional range of garden equipment which...
          08-06-2023, 12:40 PM
        • mikey5791
          Help identify this motor
          by mikey5791
          Hi all forum members,
          Found this unknown motor discarded in a junk yard and took home for learning experience. By the look of it, I suspect it is taken out from a type of air blower probably running on ac power. I used digital multimeter on ohm/resistance scale and it doesn't read anything on those 2 black wires. So, this motor is not shorted and should be good to run.
          Correct me if i am wrong on the initial test.
          Can anyone kindly advice on how to test run this motor based on visible external two black wires. Fyi, i don't see any marking on the motor body nor smell anything...
          11-24-2023, 07:54 PM
        • Per Hansson
          Motor run capacitor physical size vs voltage rating & measurements?
          by Per Hansson
          (TL;DR skip the first paragraph)
          I encountered my first dead motor run capacitor at a customer this week.
          For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
          (Unless a servo motor makes more sense that is).
          But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
          The pump would run but sometimes trip the 10A breaker.
          I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
          Then it could...
          09-20-2020, 06:32 AM
        • G0RIT
          Reebok one GT40s treadmill lift motor runs at switch on
          by G0RIT
          Good evening I am working on a Reebok oneGT40s treadmill. It had a flashing display which the replacement of D3 rectified. However the lift motor now runs when the mains is turned on and does not stop. If I then select start so the tread motor runs and disconnect the up lead to the lift motor it stops. If I then reconnect the lead the lift motor works as it should with the controls. It will continue to work correctly until the mains is turned off and on again, or the safety device is removed and replaced. It then runs again and only by disconnecting and reconnecting the up lead will it operate...
          06-23-2022, 05:57 PM
