Technique Questions
  • AdamC
    • Jan 2011
    • 3
    Technique Questions
    I'm not a complete newbie to solder but I am new to soldering on boards and components. I was practicing on an old motherboard last night the capacitor removal process and I got that going OK but I didn't have any extra capacitors to try and install, just the set that I bought from badcaps.net (which by the way went very smooth, mailed the same day I ordered them and got here quickly).
    When I install the new capacitor I'm having troubles getting the solder to stay at the bottom of the lead next to the board. It has a tendency to want to migrate to the soldering tip. Do I need a smaller tip so that I can heat the board and lead at the same time or should I just move the soldering iron up the lead away from the board and be more patient with taking the time for the solder to melt? If I'm moving the tip away how far from the board should I be heating the lead? The tip I'm using is the one that came with my Weller WES51.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Technique Questions
    See this video by CuriousInventor on soldering
    http://www.youtube.com/watch?v=I_NU2ruzyc4
    --- begin sig file ---
    --- end sig file ---
    • bigbeark
      • Jan 2010
      • 661
      You need to have the tip almost touching the board. Trim the legs of the cap you don't want the heat to bleed off. The solder flows toward the heat, it won't run down the legs. You need a good-sized tip like this one: http://www.alliedelec.com/search/pro...px?SKU=9840300
      The skinny tips won't get enough heat into the board. The object is to get the solder to flow into the holes and complete the circuit between the capacitor leg and the internal copper traces on the motherboard.
      Your iron has sufficient power. You need a tip that will hold the heat, and that tip has to be CLEAN. If the tip is oxidized you won't get enough heat.
      • steve2
        • 121
        I always touch the pad and the lead at the same time (this is in the Navy manual). They will both be at same temp and solder easily. I almost always use flux from a bottle that I dip my solder in when using the .015 solder and not often when using the .032 as it has more rosin in it.
        • steve2
          • 121
          This is chapter 3, but you can read the other chapters by changing the # at the end of the url. I have not tried any lead free solders, but I hear people don't really like them. I have almost a lb of 63/37 .032 and 1/2 lb of .015 .
          • dcwtrade
            • Nov 2010
            Steve
            Awesome link to Navymars, some really useful stuff on there.
            Thanks.
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
              Multifix 425-01 and 450-01 Rework Flux Datasheet
              REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
              - No Clean Formulations
              - Low residue
              - Range of activity to deal with different component solderability
              - Halide free
              - Suitable for dispensing
              - Compatible with solder coatings and/or No Clean flux cored solder wire product range
              Both products are supplied in syringes or cartridges for application by dispensing....
              10-07-2024, 06:02 AM
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • jm1234
              Solder joints on heat sinks matter?
              by jm1234
              solder joints on heat sinks - how much do they matter? Could poor joints on heat sink cause issues if they are not properly joining to hot ground?
              I'm looking at power source module of Panasonic plasma TV and I see many of these having visually poor quality, but could they matter? In general I would guess no, but I saw a video where someone was stressing out the importance of tightening the screws when fastening the power source board specifically for the ground to be connected properly.
              04-28-2024, 04:38 AM
            • corrize
              Desoldering - soldering BGA chip close plastic mini fpc connectors ?
              by corrize
              Hello, I need your advise please ? I need to remove and replace the BGA black chip with fpc connectors around. The PCB is small, from camera.
              There is no plastic component directly under, on the other face, (only fuse and oscillator I can remove if they are sensitives to heat), but there is a lot of very small smd components I don't want to desolder by mistake.
              I have :
              - hot air, and a
              ll stuff around
              - true kapton tape
              - 140 and 180 degree soldering paste
              - bismuth
              - little hot plate 250 degree max
              - the new BGA chip with probably
              05-20-2025, 01:26 AM
