Technique Questions
    Technique Questions
    I'm not a complete newbie to solder but I am new to soldering on boards and components. I was practicing on an old motherboard last night the capacitor removal process and I got that going OK but I didn't have any extra capacitors to try and install, just the set that I bought from badcaps.net (which by the way went very smooth, mailed the same day I ordered them and got here quickly).
    When I install the new capacitor I'm having troubles getting the solder to stay at the bottom of the lead next to the board. It has a tendency to want to migrate to the soldering tip. Do I need a smaller tip so that I can heat the board and lead at the same time or should I just move the soldering iron up the lead away from the board and be more patient with taking the time for the solder to melt? If I'm moving the tip away how far from the board should I be heating the lead? The tip I'm using is the one that came with my Weller WES51.
    Re: Technique Questions
    See this video by CuriousInventor on soldering
    http://www.youtube.com/watch?v=I_NU2ruzyc4
    --- begin sig file ---
    --- end sig file ---
      You need to have the tip almost touching the board. Trim the legs of the cap you don't want the heat to bleed off. The solder flows toward the heat, it won't run down the legs. You need a good-sized tip like this one: http://www.alliedelec.com/search/pro...px?SKU=9840300
      The skinny tips won't get enough heat into the board. The object is to get the solder to flow into the holes and complete the circuit between the capacitor leg and the internal copper traces on the motherboard.
      Your iron has sufficient power. You need a tip that will hold the heat, and that tip has to be CLEAN. If the tip is oxidized you won't get enough heat.
        I always touch the pad and the lead at the same time (this is in the Navy manual). They will both be at same temp and solder easily. I almost always use flux from a bottle that I dip my solder in when using the .015 solder and not often when using the .032 as it has more rosin in it.
          This is chapter 3, but you can read the other chapters by changing the # at the end of the url. I have not tried any lead free solders, but I hear people don't really like them. I have almost a lb of 63/37 .032 and 1/2 lb of .015 .
            Steve
            Awesome link to Navymars, some really useful stuff on there.
            Thanks.
