Zener diode test question
+ More Options
Posts
  • billy66
    • Mar 2010
    • 124
    I have a surface mount zener diode and I want to make sure it is good/bad. I believe it may be shorted, but not sure. Here is the data sheet:
    http://www.taitroncomponents.com/cat...et/TZT2.0W.pdf
    The diode is part number: TZT7.5YW
    When testing resistance across pins 1-3... I get 21 ohms... Max Zener Impedence is listed as 23... does this mean I'm ok? Or am I grossly misunderstanding this?
    Thanks for any and all help
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Zener diode test question
    So it's a 7.5 volt. Remove it from the board and hook it up to a 12v power supply with a 1k resistor in series. Resistor goes from cathode (pin 3 in this case) to +12v, anode goes to ground. If you don't get 7.5 volts across the diode in this arrangement then it is bad.
    A working TV? How boring!
    • billy66
      • Mar 2010
      • 124
      Thanks, I'll give that a try... if I can dig up a power supply.
      • billy66
        • Mar 2010
        • 124
        .2V, it's bad... thanks for the help.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          .2v is consistent with your 21 ohm resistance reading (apply voltage divider rule). It's bad alright.
          • billy66
            • Mar 2010
            • 124
            Will this work in its place:
            http://www.mouser.com/Search/Product...1-BZX84C7V5W-F
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              Yup, will do.
              • billy66
                • Mar 2010
                • 124
                Thanks... I thought so, just ordered.
                • billy66
                  • Mar 2010
                  • 124
                  Worked perfect, thanks!
                  • unimatrix93
                    TV backlight zener diode
                    by unimatrix93
                    Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                    So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                    Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                    The led strips has 9 6V leds.
                    02-10-2025, 12:13 PM
                    NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                    I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                    I bought this from an eBay seller but unfortunately they only had one
                    I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                    I bought three of from them to also make battery packs with this output power limit in mind
                    I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                    04-23-2025, 05:50 AM
                  • nev1001
                    What zener diode might fix the sound on Maestro Mayhem gaming chair?
                    by nev1001
                    Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                    The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                    It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                    I think an issue could be a zener diode (or capacitor) which has shorted out.
                    The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                    04-17-2025, 05:09 PM
                  • hobostove
                    Corsair RM1000e - Help identify 5VSB Zener diode
                    by hobostove
                    Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                    Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                    There's a 22ohm resistor that's melted and open, but it still has the bands.
                    The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                    It looks like the diode connects the source and drain of a TNY284...
                    03-27-2025, 02:25 PM
                  • debidoobs
                    Yamaha delay D1500, zener diode broken with no marking
                    by debidoobs
                    im actually trying to save a d1500 delay from yamaha. I found the service manual but schematic is missing and BOM list is a bit unclear as components listed have no reference linked to the pcbs... In my case, one zener diode was broken (114 code on the pcb in attached file) and couldn't be repaired : it was a zener type package. In the BOM list i found 3 reference on this board : 1S555 (can be replaced by 1N4148), RD4.7EB2 (approx 5v rectifier), RD7.5EB3 (approx 7v rectifier)...
                    Actually the cathode goes to VCC of sram M5M5118P, without this diode missing, i have...
                    04-24-2024, 09:01 AM
