Strange Resistor Color Coding & Apparent Value
+ More Options
Posts
  • stevekasian
    Old N00b
    • 182
    • USA - West Side!
    I've got a thread going in the monitor repair forum where I've come across this "resistor" type thingie. (here: https://www.badcaps.net/forum/showthread.php?t=12597) I am posting this here in the hopes that maybe some more people will see it and can comment on it.
    I'm attaching an image below showing an apparent resistor (R106 on the PCB) with some strange color coding that doesn't seem to be possible.
    The colors are brown black silver gold green
    This makes no sense, as silver cannot be the third color in a 5 band coded resistor.
    Changing out gray for the silver band leaves me with a resistor valued at 10.8 Ω with a ±.5% tollerance.
    In a metal film, ceramic or otherwise flameproof resistor, a value of 10.8 Ω isn't even available in any tollerance rating. So I am very unsure of what I've got here.
    It's in an LCD monitor power board, coming off the -lead of the main filter cap, bridging to the Source pin of a Power MOSFET, if that helps at all. The thing measures essentially .1 Ω currently, with no evidence of being burnt or damaged. The board ran extremely hot when it was working, and now I'm wondering if perhaps this component allowing too much current into the circuit could have been part of the reason.
    Any help with this conundrum is VERY much appreciated!
    Thanks,
    Steve
    master hoarder
    • May 2008
    • 12170
    • Bulgaria
    Re: Strange Resistor Color Coding & Apparent Value
    Could be a fusible resistor. Either way, if it was bad, it's more likely to go high resistance rather than low.
    Yup, that's where you'd normally find this resistor. Reading sounds normal for that position.
    • ReverendJones
      Resurgam
      • May 2010
      • 49
      According to the color code you have:
      0.1 ohm
      5% tolerance
      20ppm/K temperature coefficient
      Machina improba! Vel mihi ede potum vel mihi redde nummos meos!
      • stevekasian
        Old N00b
        • 182
        • USA - West Side!
        Thanks for the info. I've researched this for hours on Google and haven't seen a chart like this before. Would you be so kind as to provide a link to the page from whence this came for my review? I need to educate myself! :-).
        Thanks so much!
        Steve
        • ReverendJones
          Resurgam
          • May 2010
          • 49
          http://en.wikipedia.org/wiki/Resistor_color_code
          The 5th band could also stand for "Quality" but typically you will only see that in military hardware. For Quality read the 5th band as the "% Failure rate per 1000 hour".
          • stevekasian
            Old N00b
            • 182
            • USA - West Side!
            Thank you!
            • Askic
              Resistor value - color coding
              by Askic
              Hello electronics expert,
              can you please tell me what is supposed value of this resistor?
              I'm really having a hard time figuring this out, because black lines on first place means 0 and gold lines are multipliers 0.1.
              It seems like colored rings are: black gold gold black orange....
              04-29-2022, 06:17 AM
            • jinu_j
              by jinu_j
              Hi
              05-03-2025, 10:51 PM
            • MidnightRoller
              Can a resistor lose resistance after hot air?
              by MidnightRoller
              I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
              I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
              02-02-2022, 11:46 PM
            • Askic
              Reading resistor value by color band
              by Askic
              attached is a picture with two resistors. I wonder what values are based on color of the band.
              I have used this as a reference:
              https://www.electronics-tutorials.ws...tor/res_2.html
              Since there are 5 bands, the question is from where to start counting (what is the first band).
              Based on this info, I can conclude that thick band is the last one.
              Therefore the values are:
              Left resistor - red(2) yellow(4) black(0) black (x1) brown (1% tol) = 240 ohm, 1% tolerance
              Right resistor - brown(1) black(0) black(0) gold(x0.1)...
              02-10-2022, 12:26 AM
            • artvandalai
              What resistor ohm will work better to repair this waterpik?
              by artvandalai
              The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
              01-05-2025, 04:10 PM
