Faulty IDE to USB adaptor (drive makes funny noise, doesn't detect)
  • Agent24
    I see dead caps
    • Oct 2007
    • 5039
    • New Zealand
    I bought a USB to IDE enclosure from Trademe a while back second hand.
    It worked OK but didn't like a 40GB drive I tried with it - Lower capacity drives worked fine.
    The 40GB would just make a ticking noise and wouldn't detect in Windows.
    After a while, the size that would detect reliably became less and less until all drives stopped detecting altogether, and all made the ticking noise instead of working.
    When connected to the computer directly, they all work fine, so the problem is the enclosure itself.
    There is one capacitor in the device, which I replaced but which changed nothing.
    It uses a Genesys Logic GL811E IC which seems very common for these kinds of devices.
    I have not looked at the possibility of the power adaptor causing the problem, however the enclosure has a cable and backplate which allow it to be powered from your PCs internal PSU - and the fault got worse even when using that so either the power adaptor caused damage before I used it on my PC or it's something else.
    Has anyone had this or a similar problem with these devices?
    -David VanHorn
  • mockingbird
    • Dec 2008
    • 5484
    Re: Faulty IDE to USB adaptor (drive makes funny noise, doesn't detect)
    You mean GL118E, not 811, correct?
    Try to play with the slave/master jumpers. I often find that this helps with certain drivdx.
    • Agent24
      I see dead caps
      • Oct 2007
      • 5039
      • New Zealand
      No, definitely GL811E (see datasheet)
      The jumper must be on master for the device to work at all (that is what is written on the label on the inside of the enclosure)
      The problem got progressively worse over time, so I doubt it would be a configuration problem anyway.
      -David VanHorn
      • mockingbird
        • Dec 2008
        • 5484
        I have several of these, they all work fine. This chip is terrible though, and only later revisions had the ability to update the firmware. I used to get delayed write failures with it, but I think Windows now has some built in failsafe for this specific chip.
        The next place I would check is the 12V adapter you use to power up the drive. Try connecting it the drive to the computers molex connectors instead. Note: The drive has to be powered on -before- you plug in the USB or else Windows will not recognize it.
        • Agent24
          I see dead caps
          • Oct 2007
          • 5039
          • New Zealand
          As I said in the first post, I have tried powering it from my computer's PSU.
          The device came with a Molex to Mini-DIN that lets you use your PC instead of the power brick.
          It used to work on both, and now it works on neither.
          -David VanHorn
          • mockingbird
            • Dec 2008
            • 5484
            Yes, you're right it's 811E. Here are two different types I've got. The top one works fine, the bottom one, which is part of an enclosure, I have problems with.
            • Agent24
              I see dead caps
              • Oct 2007
              • 5039
              • New Zealand
              What kind of problems do you have with yours? Just delayed write failures or something else?
              IIRC I also had those, when it happened the drive would be making the ticking noises.
              Get a lower capacity drive and everything would work fine again... for a while.
              -David VanHorn
              • goodpsusearch
                • Oct 2009
                • 2850
                • Greece
                I had problems with mine too, thought it was due to the power supply but it was the adapter.
                https://www.badcaps.net/forum/showthread.php?t=8487
                Finally I tossed it.
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5039
                  • New Zealand
                  Yeah I'm pretty sure it's the adaptor itself and not the power supply.
                  I'm just wondering if anyone knows what could go bad... perhaps the crystal?
                  -David VanHorn
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    From what I've heard, crystals almost never go bad.
                    The voltage regulator next to that electrolytic capacitor looks burned, though. Definitely check if it's putting out the right voltage.
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5039
                      • New Zealand
                      The regulator is just covered in flux\glue or something.
                      But I will check it anyway...
                      -David VanHorn
                      • seanc
                        • Nov 2008
                        • 1319
                        Checked the diodes either side of the power input?
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5039
                          • New Zealand
                          I'm not even sure what the diodes are for, the adapter provides DC already - just protection I suppose?
                          Still got to test the regulator, when I find the adapter again...
                          -David VanHorn
                          • seanc
                            • Nov 2008
                            • 1319
                            Well the cheap power adapters often fail, so I would check that for a start.
                            I'm puzzled that you have the same problem when using your PC power supply. It does the same thing using your PC power supply, with the IDE cable unplugged?
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 5039
                              • New Zealand
                              Yes, it does the same thing on both PSUs - the drive won't detect and makes funny noises.
                              I can't remember what it does if you turn it on without a drive connected. Will check that too...
                              -David VanHorn
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 5039
                                • New Zealand
                                Found the adapter and tested:
                                Output from adapter:
                                No HDD \ With HDD
                                12.35v \ 12.45v
                                5.04v \ 4.93v
                                Output from Vreg:
                                3.29v \ 3.29v
                                Now I just have to find the special A to A USB cable!
                                -David VanHorn
                                • Badcappy
                                  Banned
                                  • Aug 2007
                                  • 52
                                  Assuming the drives do spin up, the ticking noise is the actuator attempting to free the head arm from its strong magnetic mount --- and not having enough power to do so. A very large surge of current is required for this process.
                                  • crepiduse
                                    • Nov 2010
                                    • 69
                                    I assure you it's the power adapter or interface ports. The problem you are describing is what Badcappy said. Not enough power to sustain spinup.
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 5039
                                      • New Zealand
                                      I found the cable and tried the thing out again. I think I confused everyone when I said 'ticking' noise.
                                      It's very similar to the 'data reading' sound that drives make on startup, but sounds as if it's trying to read a bad sector (it happens over and over)
                                      The drive is NOT faulty though.
                                      I have managed to get the thing to do three different things.
                                      1) drive will appear to initialize normally, but windows will say "USB device not recognized"
                                      2) drive will be detected, but model number will not be correct (random symbols etc) and it will make the repeated reading noises.
                                      3) it will all work fine. I found this appears to be dependent on the position of the adaptor relative to the drive. Moving the adaptor around can trigger the repeated reading noise problem.
                                      From this I get the impression that the IDE or USB cable (or maybe even power cable) or all have some issues...
                                      -David VanHorn
                                      • mockingbird
                                        • Dec 2008
                                        • 5484
                                        Yes, try changing those cables.
                                          HP EliteBook 850 G5 + Mini Dock, Bag & Spare AC Adaptor Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 850 G5 + Mini Dock, Bag & Spare AC Adaptor Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G5 + Mini Dock, Bag & Spare AC Adaptor boardview and 850 G5 + Mini Dock, Bag & Spare AC Adaptor schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          09-06-2024, 08:50 AM
                                        • tony359
                                          by tony359
                                          11-28-2023, 05:18 AM
                                        • MegaZAC
                                          Onkyo TX-SR805 noise in one channel
                                          by MegaZAC
                                          Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                                          Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                                          There's some logic behind it. As soon as I select an input I get only left...
                                          04-23-2025, 10:09 PM
                                        • courtcircuit
                                          Philips HTS8000 home cinema noise problem
                                          by courtcircuit
                                          Hello
                                          I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                                          Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                                          Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                                          I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                                          Removed each of tyhe boards
                                          02-08-2025, 08:22 AM
                                        • karatzdi
                                          Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                                          by karatzdi
                                          I know some might say... just buy another one. Sell it as parts..!
                                          So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                                          Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                                          Spent some time downloading the Service...
                                          06-11-2024, 08:38 AM
