External hard drive case with bad supply
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    The hard drive case brand is VIPOWER, it was bought at 2004 and it has gone bad less than 3 years later.
    12V voltage is crazy. It goes from 11.3 to 13.5 and tries constantly to reach 12.14V and stay there, but few times it manages to do that.
    5V seems to be ok.
    Opening that psu today with tech guy's help, no bad caps were found in it..
    He said the transformer is bad and nothing can be done with that...
    Photos attached
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: External hard drive case with bad supply
    recap it and look for bad solder joints.esp replace the small lytic toward the center of the board.if the transformer were bad it would not run.
    • i4004
      • Oct 2006
      • 2029
      you mean no bulging caps?
      they still may be bad...did you measure their esr?
      if not, then you don't know if they're bad or not.
      that's something those that don't know say...hehe...
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        I don't know what's wrong there, all I know is this thing was not even plugged in most of the time.
        The hard drive in the external case was used for complete system back up 2-4 times per year and then was put in a shelve...
        I was testing it right now. When powering on, 12V goes ~13.5V, then drops to ~11.2V and then slowly goes up to ~12.20 and does not fluctuate at all.
        Sometimes it stays at that voltage, steady as a rock, more often thought, while steady at 12.2, suddenly polymeter shows for example 12.8 and then again 12.2. Then it happens again and again with different peak values and goes together with hard drive motor sound going higher for a sec and then back to normal.
        I find it hard to blame the caps for that.
        Before opening psu, I have tried adding caps at the outputs (5V and 12V) but it did not make a difference.
        Confused...
        • i4004
          • Oct 2006
          • 2029
          crappy caps can go bad even when unused...
          i had great trouble finding decent lytics here, everything is old stock, esr goes pretty damn high...even though they were never used...
          and i didn't really find any, i should be ordering panasonic from rs in the future, like you.
          in this case it's really hard to say if changing lytics would help it, or is there another underlying cause of the problem.
          if caps are ok(which, again, we don't know untill their esr is measured), then something is messing the feedback circuit (ie regulation that tells the primary section when to stop increasing the voltage, so to say), and kc's suggestion about checking for bad solder joints is good....you should first resolder everything...
          either way, you really should get esr meter if you're really interested in such things.
          uhu, better not to connect it to that hdd anymore....chances are you'll mess the hdd if it stays that way...
          if you can't fix it, think about using some pc psu to power it...hehe...yes, it'll be bigger than hdd tray itself, but it'll last MUCH longer, if it's a decent psu...
          which reminds me, i too should adapt cables to be able to hook my hdd trays( i have 3) to my old enermax psu, as it's currently doing nothing usefull...
          and yes, these small supplies really are rarely seen crap...
          • goodpsusearch
            • Oct 2009
            • 2850
            • Greece
            It's a sacrificial hdd so it's ok (has its own problems too :P ).
            What do you mean in your last sentence?
            I already ordered a new external hdd case
            • i4004
              • Oct 2006
              • 2029
              the external case is ok, but its supply is not, and in my last sentence i said these external cases usually have crappy supplies....ie bad quality, so the chances are new one will have a bad supply too...
              that's why i said (in the line just above) i should attach decent pc psu to it(enermax pc psu i have), instead of these crapppy supplies that come with them....
              then you just connect 5 and 12V from pc psu molex to wires of the external hdd case power connector...
              and then you can power all 3 with one pc psu....hehe...no need to have 3 adaptors for each hdd external case like i now have...
              • goodpsusearch
                • Oct 2009
                • 2850
                • Greece
                This is f*** incredible! The psu was completely ok. The CASE was the reason of the problems!
                I tested the VIPOWER HDD CASE with the psu that came with RAIDMAX ICYBOX today and it didn't work good. Voltage was doing the same as with the original psu connected to it.
                Firstly I thought the new psu was crap too and I got depressed... But when connected either the new or the old psu to ICY BOX, it worked flawlessly with any hard drive I put on it.
                So, to make it easy, I now have,
                2X 5V & 12V OUTPUT POWER SUPPLIES:
                1)PRIVER
                2)FLYPOWER
                and
                2X external HDD CASES:
                A)VIPOWER
                B)ICYBOX
                1)PRIVER --> A)VIPOWER --> NOT WORKING
                2)FLYPOWER --> A)VIPOWER --> NOT WORKING
                1)PRIVER --> B)ICYBOX --> WORKING
                2)FLYPOWER --> B)ICYBOX --> WORKING
                Who could have imagined this? And why this thing failed at first place?
                • i4004
                  • Oct 2006
                  • 2029
                  just look at the "nice" soldering on that pcb.
                  but yes, it is kinda weird that supply is ok, and device itself is making problems.
                  troubleshooting can't be too easy as measuring will just show whole circuit pumping voltage when it happens...
                  i would resolder it first, then see if i can detect any component overheating, if resoldering doesn't help.
                  (i don't see how would i tackle if from purely electrical perspective of just measuring voltages etc.)
                  • federalhouse
                    **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                    by federalhouse
                    Hi everyone,
                    I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                    **Background:**
                    I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                    **What I've Tried So Far:**
                    1. I accessed
                    08-01-2024, 07:03 PM
                    External hard drive/cd rom enclosure-printer port interface recap power supply board
                    by sam_sam_sam
                    I going to modify the enclosure to except the new USB 3 interface
                    The 3.5 enclosure do not have internal switching power supplies and use a small switching wall wart power supply really
                    I need a cd rom drive for my new computer and do not want to use a 2.5 cd rom drives
                    The switching power supply in the old enclosure has nice heat sinks and has a cooling fan in the enclosure that is the main reason why I want to repurpose for this project
                    https://www.ebay.com/itm/231205428647
                    I will post some pictures of it when I get the usb 3 to IDE...
                    04-08-2023, 05:42 PM
                    by sam_sam_sam
                    07-01-2024, 06:34 AM
                    by sam_sam_sam
                    03-31-2024, 02:12 PM
                  • ash91
                    Hp pavilion 15 not detect hard drive
                    by ash91
                    Hello gentelmen .... this is my first post and sorry for my bad english,
                    so my proplem is my laptop keep losing hard drive even if i but the
                    hard disk in the cady (the box that can replace the dvd rom with hard disk)
                    when i turn the laptop on the massage that said no boot media found pop on
                    the hard disk is fine and to be sure i try another hard
                    i also update my bios to the last update
                    the 5 volt is present on the hard connector on the motherboard
                    the dvd rom work fine when i but a windows dvd in it
                    also when i boot from flash...
                    06-07-2023, 01:45 PM
