Increasing voltage
  • Rob Northen
    • Jan 2010
    • 137
    • Denmark
    Increasing voltage
    I recently recapped some Pentium SBC boards.
    When testing one today, it halted after 8 hours. When checking the voltages,
    I saw 3.3v was 3.6v. Turned off power, turn on again, now it was 3.4v.
    Then keeping an eye on it, it was very slowly increasing..
    I then tried replacing the 3.3v regulator, no dice, still the same.
    The board gets power (5v only) from a 12v-5v step down module.
    It just sits calm at 4.9 volts ALL the time, so powersupply is no problem.
    Any idea, why the 3.3v is slowly increasing ???
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Increasing voltage
    Is there a zener diode between 3.3v and ground or between 5v and 3.3v?
    It may be drifting w/temp.
    Mann-Made Global Warming.
    - Dr Seuss
    • Rob Northen
      • Jan 2010
      • 137
      • Denmark
      Thanks for the reply!
      Just checked, and no zener.
      I come to think of a thing. I replaced an old Panasonic 10v/1000mf cap
      GE series. I could not find any info on GE series, so I went for Panasonic FM.
      As it turns out, I measured old cap, it had ESR 0.20 Ohms. New is ESR 0.08 Ohms.
      The 3.3v regulator output, is connected directly to the positive leg of the cap.
      So, can the lower ESR be a problem ?
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        In that application I can't see how ESR would do that.
        ESR affects AC and ripple [noise] and not DC.
        I can't see how it would cause a static DC voltage to slowly drift.
        - Dr Seuss
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Maybe leaky cap if Vref to VR chip?
          Adding a zener would be cheesy but should fix it.
          - Dr Seuss
          • Rob Northen
            • Jan 2010
            • 137
            • Denmark
            I replaced all electrolytics, there are only some VERY small SMD caps left.
            The zener sounds like an interesting idea.
            Thanks for the advice!
            • Fernon@Repair
              Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
              by Fernon@Repair
              i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
              VCCIO voltage ok
              VCCSA Voltage OK
              VCCPLL Voltage OK
              Ram Voltage ok
              RamVTT OK
              VPP 2.5 OK
              But No Core Voltage
              and i want to this vrm ic datasheet or pinout (ISL69269)
              anyone have this ic pinout voltages?...
              06-25-2025, 07:19 AM
            • electron_jj
              Panasonic TH-L42D25A checking the PSU output voltage
              by electron_jj
              Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
              I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
              08-29-2021, 08:13 AM
              ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
              3+1 Voltage Regulator for IMVP-7/VR12 CPUs
              Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
              core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
              configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
              serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
              Based on Intersil's Robust Ripple Regulator...
              11-05-2024, 03:24 PM
            • ruletero
              Acer a515-43 low battery charge voltage
              by ruletero
              Hi
              Acer A515-43
              LA-H801P
              Fail: Does not charge battery, has low voltaje on connector.
              Laptop didn't want to turn on, only charge led blinked.
              I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
              I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
              Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
              10-24-2022, 02:31 PM
              Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
              I want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
              https://www.ebay.com/itm/116497313155?var=416785404161
              Here are some of the description from the eBay seller
              The main parameters:
              1. Product name: High-power non-isolated DC boost module power supply.
              2. Product model: 100A2000W.
              3. Input voltage: DC12V-60V.
              4. Input current: 100A (maximum)....
              05-18-2025, 09:45 AM
