Capacitors for DC smoothing, Low-ESR or not Low-ESR?
  • Pyr0Beast
    • Feb 2009
    • 406
    Re: Capacitors for DC smoothing, Low-ESR or not Low-ESR?
    That's because most people don't know what 'Endurance" aka Endurance Lifetime" aka "Load Life" aka "Lifetime"[in a data sheet] means.
    Then state the difference and clear this up once and for all.
    There are 8760 hours in one year.
    - According to you, 5000 hour rated caps die in 208 days of 24/7 use.
    Pretty much. Out of spec = Unreliable application = Faliure
    There is a formula to estimate Useful Lifetime from Endurance Life but according to Chemicon [I think it was] that equation only has a 40% Level of Confidence.
    Good enough. With some derating you stay on the safe side.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      The test for Endurance Lifetime is defined in IEC 60384-4. [An International Standard].
      None of the other Lifetime terms have standardized definitions so basically they can mean whatever the manufacturer wants them to mean and they can 'come up with' equations and tests to fill the numbers their charts any way they want to.
      As with most Standards if you want a copy you have to buy it. I don't have time to find a link to someone that cheated and posted a copy today. But if you can find such a link please pass it on.
      Basically they put the cap at max Ripple [@rated frequency, usually 100kHz], max DC volts and max rated temp for 'x-many' hours then return it to nominal temp and check that all it's specs are in tolerance. They do this for various 'x-many' hours and the longest 'x-many' hours where the cap does not go out of spec becomes the Endurance Lifetime. [That test tells you absolutely nothing about how long the cap will last in a real world application.]
      In case you haven't noticed all the caps in a series have the same number for a given diameter and that number is always a nice round number like 2000 or 4000.
      [If it was a spot-on number you'd see numbers like 1967, 3985, 2311, etc...]
      There are two reasons.
      - They take the worst case and apply it to the whole series.
      - The test is inherently inaccurate so they round the result down big time to cover their corporate asses.
      Mann-Made Global Warming.
      - Dr Seuss
      • Pyr0Beast
        • Feb 2009
        • 406
        So all is just shit ?
        If we can't keep standards same then whole specs are just garbage.
        I doubt they do that because then they would be worse than competitors.
        I'd go with rounding for the sake of ease, they for the sake of more profit.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Pretty much. Out of spec = Unreliable application = Faliure.
          And therefore according to you Rubycon MBZ and MCZ (both 2000hr caps) are only good for 83 days of 24/7 operation.
          - Dr Seuss
          • Pyr0Beast
            • Feb 2009
            • 406
            At rated temperature, ripple and voltage, yes. Derate and you get more, cool and it will last longer.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              EXACTLY! - It's all marketing BS.
              The terms 'low ESR', 'very low ESR', 'ultra low ESR' also have no standard definitions.
              Don't remember who but I saw an el'cheapo cap brand calling one of their series 'ultra low ESR' but when I looked at the specs the ESR was higher than Panny FC.
              It was just -THEIR- lowest ESR cap so they gave it the grandest name.
              - Dr Seuss
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                But you are derating an -estimated- number by factors that have -estimated- effects.
                Estimated numbers all have a +/- range even if they aren't written that way.
                When you put a whole bunch of +/- ranges into an equation the end result is a number with a BIG HUGE +/- range.
                - Dr Seuss
                • Pyr0Beast
                  • Feb 2009
                  • 406
                  #28
                  Haha. Well. It is same with transistor power rating. 125°C junction temperature, you got to be joking me.
                  Couldn't meet the specs even when cooled with liquid nitrogen
                  Well, I have my own to make some sense from all the rubbish. ULESR are usually really good polys or ceramic. Low esr anything that doesn't reach into ohms range.
                  • Pyr0Beast
                    • Feb 2009
                    • 406
                    #29
                    Yes. Shitty metology to do so. Garbage in, garbage out.
                    • Radio Fox
                      • Jan 2010
                      • 281
                      Excuse me, there is a slight error in the calculation. The DC voltage is the peak AC voltage (9V x 1.414) less the voltage drop of two diodes (1.2V) = 11.53 volts. Doing the calculation in reverse order (as you did) results in predicting the output voltage .5 V lower than what it will actually be.
                      PlainBill
                      Whops, you're absolutely correct.
                      ________________________________________________
                      Invisible airwaves crackle with life
                      Bright antennae bristle with the energy
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        #31
                        Actually transistors do take that temperature. Ever did any thermal calculations that take the junction to case thermal resistance of the transistor into account? You'll quickly see the numbers soar to mind-numbing values. Especially true in power supplies where they use those insulating pads to prevent heatsinks from becoming live - the transistor runs LOTS hotter than the heatsink.
                        I did a test on some MOSFETs with 175C junction temperature (IRF530) and they were still working at 175C heatsink temperature. The transistors were bolted directly onto the heatsink and thermal paste was used, but there was still the internal junction-to-case resistance so the silicon itself was running at 200-something degrees. Sure, this was a short-term overload test (about 2 minutes) but it definitely shows that they do take the incredibly high temperatures mentioned in the datasheet.
                        A working TV? How boring!
                        • Pyr0Beast
                          • Feb 2009
                          • 406
                          #32
                          Mmmm yeah. These things can unsolder themselves from the board and still work.
                          But I wouldn't rely on that. 100°C Tj is way too much for me.
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            - Dr Seuss
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              • Romania
                              #34
                              I already had the datasheet, thank you. But my IRF530s aren't made by Fairchild, here you go, and it explicitly says 175C operating temperature there.
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                And as the graphs clearly show as Tj goes up current goes down so it's debatable that you overloaded them.
                                - Dr Seuss
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4970
                                  • New Zealand
                                  #36
                                  I have sad news. My RTA1320 won't get an internet connection at all now
                                  Worked fine for a few days after recap, but now, I can't get PPP authentication at all.
                                  It powers up fine, gets full speed ADSL sync fine, but the PPP light never comes on and it refuses to get a WAN IP address.
                                  I've tried resetting through the Web interface and also the button, but it just refuses to work. My other router (Thomson ST536v6) works just fine though. I just don't like to use it as I hate the web interface, and it's buggy, won't let me change the DHCP settings, and the Telecom custom firmware locks you out of anything to do with ADSL settings.
                                  Anyone got any ideas or have I screwed something up royally?
                                  -David VanHorn
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 4970
                                    • New Zealand
                                    #37
                                    Well, this is interesting.
                                    Since I had tried everything else I could, I decided to reflash the firmware on the off-chance that it might help..... and it did!
                                    After a reflash and full reconfiguration it's working again.
                                    Coincidence? Or is something sinister going on here?
                                    (enter into conspiracy theories of badly soldered capacitors causing bad ripple suppression leading to partial EEPROM corruption)
                                    Probably not, right? I'm pretty sure I did a good soldering job, anyway.
                                    -David VanHorn
                                    • Pyr0Beast
                                      • Feb 2009
                                      • 406
                                      #38
                                      Eeprom corruption is doubtful, I would go with flash corruption rather. But it might be something that was caused by rapid shut-down or poor power supply.
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 4970
                                        • New Zealand
                                        #39
                                        Configuration corruption I thought would be ruled out by the original reset using the button?
                                        As said before, the power adapter is just a 9v AC transformer. Crappy enough?
                                        Wish I had an oscilloscope....
                                        -David VanHorn
                                        • Pyr0Beast
                                          • Feb 2009
                                          • 406
                                          #40
                                          Nah. Some reset buttons are soft-reset and won't work unless router boots up.
                                          Some other network stuff just uses different combo for reset. It was pain resetting mine. Kind of disabled DHCP and couldn't re-enable it and 192xxx didn't work.
                                          No way of reset work but holding reset on 'warmed up' router, then unplugging from power and holding reset for next 5 minutes.
                                          • dragon3x
                                            After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                            by dragon3x
                                            Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                            power on.
                                            Here are some examples :
                                            (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                            switching supply area).
                                            (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                            than 6.3 V.)
                                            1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                            I replaced capacitors with aluminum-polymer.
                                            3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                            03-21-2025, 02:46 PM
                                            by sam_sam_sam
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • chth96
                                            Is it no harm to replace with capacitor without ripple current rating?
                                            by chth96
                                            When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                                            Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                                            But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                                            Rubycon YK DataSheet (b...
                                            04-19-2024, 05:19 AM
                                          • Ady2017
                                            Are there any datasheets available for Elna RJG capacitors?
                                            by Ady2017
                                            I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                                            05-25-2025, 02:19 PM
                                          • RukyCon
                                            ZUMAX Technology (Leadman Power) ZU400W (X1), Modifications & Life Test
                                            by RukyCon
                                            Hello Again, so i'm bringing back this Zumax PSU from the gutless thread and going to be doing some modifications, and also putting it into a PC i'm going to throw together out of spare parts to see how long it lasts.
                                            So the first thing i did was fill in the missing filtering, by replacing the cheap common mode choke with a real one and adding a 470nf X2 capacitor in the open capacitor spot, i then replaced the fake Y-class capacitors with real ones, i also swapped out the mismatched primary caps with a pair of Aishi WK 470uf 200v caps, both of which test around 520uf. I also swapped...
                                            04-15-2022, 11:20 PM
