Capacitors for DC smoothing, Low-ESR or not Low-ESR?
  • Agent24
    I see dead caps
    • Oct 2007
    • 4950
    • New Zealand
    #41
    Re: Capacitors for DC smoothing, Low-ESR or not Low-ESR?
    Well it worked great after reflash\reset for about a week, then did the same thing again.
    I got pissed off and now I'm using the Thomson instead (after Telecom told me the only way to change gateway IP was to save the config file, manually edit it and load it back in - buggy interface is a piece of crap and refuses to accept the IP addresses stating they are invalid)
    BUT even so, the Thomson still won't connect properly sometimes either.... Though its capacitors aren't bulging, and it has a lot more of them and a much beefier Vreg circuit overall than the Dynalink.
    What's interesting is that both use the Broadcom BCM6338 chipset - incompatibility problem with new ADSL cabinet?
    New capacitors in the Dynalink are 'Too good' ? Signal level is 'too high' and new ADSL cabinet which is only 200 metres away is overloading the signal? Damned if I know.
    Anyone got any better ideas?
    -David VanHorn
    • dragon3x
      by dragon3x
      power on.
      Here are some examples :
      switching supply area).
      than 6.3 V.)
      03-21-2025, 02:46 PM
      After all of...
      07-13-2024, 08:14 PM
    • chth96
      Is it no harm to replace with capacitor without ripple current rating?
      by chth96
      When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
      Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
      But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
      Rubycon YK DataSheet (b...
      04-19-2024, 05:19 AM
    • Ady2017
      Are there any datasheets available for Elna RJG capacitors?
      by Ady2017
      I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
      05-25-2025, 02:19 PM
    • RukyCon
      ZUMAX Technology (Leadman Power) ZU400W (X1), Modifications & Life Test
      by RukyCon
      Hello Again, so i'm bringing back this Zumax PSU from the gutless thread and going to be doing some modifications, and also putting it into a PC i'm going to throw together out of spare parts to see how long it lasts.
      So the first thing i did was fill in the missing filtering, by replacing the cheap common mode choke with a real one and adding a 470nf X2 capacitor in the open capacitor spot, i then replaced the fake Y-class capacitors with real ones, i also swapped out the mismatched primary caps with a pair of Aishi WK 470uf 200v caps, both of which test around 520uf. I also swapped...
      04-15-2022, 11:20 PM
