Reversed polarity cap killed PSU board
  • PCBONEZ
    replied
    Re: Reversed polarity cap killed PSU board
    Originally posted by Pyr0Beast
    Not sure about that.
    I am.
    Take a good PSU with PI filters and measure the ripple on an o'scope.
    Then change [only] one of the OP caps to one with much lower ESR and measure the ripple again.
    It will usually be more, not less.
    Oklahomawolf [from jonnyguru] embarrassed himself publicly by making that mistake.
    Recapped unit had worse ripple than it did with bad caps.
  • Th3_uN1Qu3
    replied
    Originally posted by PCBONEZ
    Lacquer only works if the signing winding is in the outer wraps and that isn't always the case.
    Not if you take the transformer out and dip it for a couple hours.
  • PCBONEZ
    replied
    Ripple filters in most PSUs are lowpass not bandpass, so no they aren't tuned.
    Tweaking them for lowpass IS tuning.
    I've heard people blaming caps with too low ESR for supply whine, but in my experience it was always a case of loose windings in a transformer or coil and a bit of lacquer always the fix. Also if it didn't work when you got it, you have no way of knowing if the noise wasn't there in the first place.
    First version of Antec Smart power was famous for supply whine and it was found to be a poorly chosen capacitor.
  • Th3_uN1Qu3
    replied
    Ripple filters in most PSUs are lowpass not bandpass, so no they aren't tuned. Besides, the variations in ESR that occur naturally, would throw off tuning anyway.
  • Pyr0Beast
    replied
    Output filters are 'tuned' to optimize filtering at a certain 'expected' noise frequency and the value of the inductors, the caps uF, and the caps ESR are all take into account when the designer specs the caps.
    If you go haphazardly changing values around you will most likely de-tune the filters and the result is more ripple noise in the output.
    Not sure about that. I do think it has to deal with loop compensation instability.
    Lower ESR helps greatly with reducing ripple.
  • PCBONEZ
    replied
    Originally posted by Toasty
    Ask Mr. 25 Watt soldering iron (aka: mockingbird) to explain...
    And thus the bird of repetition learns two lessons.
    1: Size does matter.
    2: It is better to walk softly and carry a big stick than to walk loudly and carry a little one.
  • PCBONEZ
    replied
    I don't know why, but some PSU's don't like very low esr and/or high capacitance on output.
  • Pyr0Beast
    replied
    Ya lost me there...
    Extending the leads -increases- the ESR. The Rubycon was Higher than the Panasonic, and Lower than the OEM Capxon.
    But again, some don't start if ESR is too high ...
  • romansroad
    replied
    I thought I had read he was under-wattaged.....the plot thickens! Perhaps we should have a "help mockingbird get a better soldering iron fund" set up?
  • Toasty
    replied
    Ahhh, but you don't know the whole story.
  • romansroad
    replied
    One trick I've used is to cut off a shorter piece of the braid, lay it on the PCB where you want to suck up the solder, and then apply the iron. The braid can be quite the heatsink itself, so shorter pieces sometimes are better. You can also just slightly tin the braid with rosin flux lead based solder (I have a 1lb spool of Multicore), then apply lead based solder to the part you want to de-solder....yeah, I know, seems counterintuitive, but the heat conduction is better. Then, apply the braid and suck up the non-lead with the lead solder. BTW, lead based melts at a lower temp, and makes it all easier.
  • mockingbird
    replied
    Did you get Solder-Wick yet?
    Yes, I bought some "MG Chemicals" braid, and eventhough it shows in the catalog as fluxed, it performs rather poorly even after I dip it in some flux. It's not what I thought it would be. I thought it was gonna suck up solder as soon as I applied heat to it but you really have to put it an effort to get it to absorb something.
  • Toasty
    replied
    >>You told me to remove it!!!<<
    Yeah, but not expecting a tinker-toy soldering iron either...
    >>Check capacitance of Rubycon cap, not ESR.<<
    As stated, Rubycon is fine per spec meaning ESR & capacitance.
    >>how do you test the dual anode diode for failure<<
    Cathode is common center leg. Use diode check with black on center and red to both outside. A failure would either be open or shorted, one or both sides. Can be difficult to check because of connected components. Unsoldering the center leg on a single-sided board is usually the way to go. Through hole board with via's is not easy and will require removal. Experience is the teacher here. Knowing that a reading is good/bad comes with time.
    >>can *DEAD* fuses still show continuity if they're tested in circuit?<<
    Not typically.
    Toast
  • mockingbird
    replied
    Very nice. The diode pack all I did was run a tiny piece of wire between it and the nearest compatible trace. You told me to remove it!!!
    Check capacitance of Rubycon cap, not ESR. Cap can die with same ESR but has lost its capacitance. I suspect the 10V 2200uF cap I put in the wrong way killed it.
    This is good to know for the future. One more question if I may, how do you test the dual anode diode for failure? Second question is can *DEAD* fuses still show continuity if they're tested in circuit?
  • Toasty
    replied
    Ya lost me there...
  • Pyr0Beast
    replied
    >>I do not know (nor understand) why the Rubycon would not allow it to run >>as the original Capxon is higher ESR by the datasheet.
    Chip detects 'short' on the output and shuts down.
    I extend the leads if that happens.
  • Toasty
    replied
    Re: Reversed polarity cap killed Acer AL2017 PSU board
    Acer AL2017 Mfg. 12/2006
    PSU Board: Delta DAC-12M033 AF, Rev: 02A
    Panel: Chi Mei - A201P1
    >>Can you show me the fuse that was blown?<<
    https://www.badcaps.net/forum/showpo...20&postcount=6
    The other pics as promised attached.
    Fuse replacement with Pico fuse. Cleaned mask from trace and drilled holes to accept said fuse type, shown on right.
    Repair of damaged diode pack traces. Removed and remounted diode pack with fresh thermal grease. Cleaned off mask from traces. Drilled holes oversize and inserted wires I pre-bent at 90° to fit alongside diode leads. Fluxed and soldered in place and over-flowed wire back to good trace areas.
    Was not getting any output from main transformer as measured at diode packs. Laid scope probe across transformer and found only a low frequency sine wave. Not correct. With nothing else apparently damaged, and the missing signal at the transformer, I suspected the small cap.
    Even though the cap was a Rubycon YXG and seemed in good condition and in spec on capacitance and ESR. The specs for all caps used there follow. I do not know (nor understand) why the Rubycon would not allow it to run as the original Capxon is higher ESR by the datasheet.
    Code:
    [B]22uF @ 50v[/B]
       Original: Capxon GL - 135mA - 1.00Ω
    Replacement 1: Rubycon YXG - 180mA - 0.70Ω => Actual 0.46Ω
    Replacement 2: Panasonic FM - 250mA - 0.34Ω => Actual 0.23Ω
    I wonder if there is another problem that I should investigate, but after it ran for 10 days with no issues on either test patterns, browsing, or videos, I am not going looking for trouble.
    Toast
  • mockingbird
    replied
    Congrats!
    I tested the startup cap for continuity, so I didn't suspect it. Can you show me the fuse that was blown?
  • Toasty
    replied
    Re: Reversed polarity cap killed PSU board - FIXED!
    Done. Working! Running 4 days continuously.
    Short version:
    1 - 2200uF/10v FM - replaced missing one (One that was reversed)
    1 - 4A pico fuse - replaced blown SMD one on 5v line (W crosses to 4A in 2 different manuf sheets)
    1 - 22uF/50v FM - replaced Rubycon YXG in start up section
    More details and some other photos will be up later.
    Toast
  • Toasty
    replied
    Okay. PM sent.
