Anyone know what an NG1N sot23 is?
  • Crystaleyes
    • Sep 2021
    • 493
    • Brazil
    So far been unable to find any reference to this but the code on it is 'NG1N'.
    Any input will be greatly appreciated.
  • R_J
    • Jun 2012
    • 9610
    Re: Anyone know what an NG1N sot23 is?
    Fn4a3q
    • Crystaleyes
      • Sep 2021
      • 493
      • Brazil
      Originally posted by R_J
      Fn4a3q
      Thank you so much.
      Just couldn't find any reference to what kind of transistor it was and it didn't test correctly for a BJT or FET.
      Gonna remove it and see
      • truclacicr
        • Apr 2019
        • 352
        • australia
        http://markingcodes.com/search/c/ng1
        • speaktorob
          Reference Nvidia GTX 980 ti - looking for a new shroud
          by speaktorob
          So a while back, to deal with the fan noise of the old blower style shrouds on the reference cards, I chucked it and installed the monster that is a Raijintek MORPHEUS 8069, with a couple Noctuas on it. Did the job but quite unwieldy tbh.
          Anyone know which boards would have a compatible shroud for it? I know the EVGA used the reference board but wondering if any other manufacturers did. I want to put something sensible back on it, but I'm having a hard time getting hold of even a faulty reference board for a reasonable price.
          03-22-2024, 03:00 AM
        • Nevillet
          Identifying a 'FS45' SOT23 device
          by Nevillet
          Hi All,
          I'm trying to repair a PCB that has some surface mount SOT23 devices that apear to be transistors but testing them on the board are giving confusing results.
          Its named FS45 but I can't find a datasheet that seems correct.
          The device is used in 10 places on the PCB. In 4 cases they appear to be controling triacs and the attached picture it shows it connected to a BT136 triac with the FS45 connected to the gate leg of the BT136.
          Can anyone identify the device and suggest an alternative?
          Many thanks.
          PS: I have...
          06-19-2024, 11:42 AM
        • Rhork
          Chip reference DA0G7BMB6D0 rév D HP Pavilion - 15-cs0006nf
          by Rhork
          I would like to know the reference of a QFN-20 because the reference marked on the chip does not give anything...
          PC Reference : HP Pavilion - 15-cs0006nf
          Motherboard : DA0G7BMB6D0 rev D
          Reference marked on the chip: AWVAIL
          Type : QFN-20
          I didn't find a boardview or repair schematics
          Thanks in advance...
          03-30-2022, 11:32 AM
        • mecmast
          Need help about "G2920T11U" / "G2990" / "2990(x) SMD SOT23-5 replacement
          by mecmast
          I've searched the internet but couldn't flnd a replacement/substitute for this part.
          It is marking as "2920N" SOT23-5 case.
          I am looking for the "G2920T11U" 3.3v version.
          Also uploading the datasheet.
          Thank you all....
          10-15-2025, 11:39 AM
        • kjchatman
          identifying sot23 on backlight cirucuit of 17" razer rz09-0423
          by kjchatman
          this laptop was damaged by a roof leak at the repair shop that it was at while waiting for a replacement cpu fan. It was given to me to try to save the motherboard which wouldn't power up anymore. The only issue now is that an sot23 marked R1 is missing one of it's three legs. I cannot find schematics for this model but I found a mosfet that has the same label but i'm not sure if it's an actual match. CJ3401 is the one that I found but I have no clue about the true identity of the damaged one.
          07-28-2025, 11:47 AM
