26 LED Parallel Circuit
  • mferna14
    • Jun 2018
    • 1045
    Dear Electronics Friends.,
    I have 26 LEDs (Rating 3v 20mA) in my garden attached all in Parallel Circuit. I am using a 12v 5amp DC power adapter. I calculated the value of Resistor which was nearly 13ohms 1 watt resistor. All LEDs light up very well.
    My question is after 4 ~ 5 days the first 2~3 LEDs (starting in the circuit) nearest to the power adapter get burnt or just do not light up & the rest 22 LEDs makes no difference, they glow very well. Why is this so? This is the 3rd time I have replaced the 1st 3 LEDs in the start of the circuit. Am I doing something wrong, or the 1st 3 LED require a resistor each? Can anyone help me in this circuit design? Thanks in advance.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: 26 LED Parallel Circuit
    LEDs are current controlled devices. Wiring them in parallel will not get them the same current and by luck of the draw, the ones that draw more current will draw more, overheat, and burn out.
    LEDs need to be connected in series with other LEDs or resistors and control their current for longevity.
    You could just keep replacing them and find 26 LEDs that match but it may take a while and a lot of replacements...
      • 31198
      or put a seperate resistor on each led
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Since you have a 12V PSU, the cheap solution is to try to wire a few in series in groups of three with a resistor per group. 26 isn't a multiple of 3 so you'll need to recalculate a resistor for the stragglers.
        The optimal solution is connect all in series and have a 20mA CC power supply (which will get to 90+ volts, but who's looking?)
          master hoarder
          • May 2008
          • 12175
          +1
          Both of these are good solutions, or wire each LED with a resistor... in which case, you can even swap out the PSU for a 5V one to waste less power with the resistors (less voltage drop across them.)
          I'm also curious what LEDs you're using. Care to post a link where you bought them or datahsheet for the LEDs? If the LEDs are cheap no-name stuff from Amazon, eBay, Ali, or similar, forget that they will do 20 mA in the long term and not burn out. Cheap LEDs don't last at all at high power... and sometimes not at all, regardless of the power being fed. I find SMD LEDs to be the worst offenders when it comes to die separation (and thus the LED starting to flicker randomly.) But even the regular "oldschool" 3 mm, 5 mm, and 10 mm clear epoxy lens LEDs are not safe from this anymore.
          So in short, if you have cheap LEDs, don't plan on pushing more than half of their rated current... in this case, 10 mA if they truly were rated for 20 mA. And if they were rated for 20 mA absolute max, I'd say 5-7 mA would be the most you can push through them to have them last a reasonable amount of time (a few years, fingers crossed.)
          • mferna14
            • Jun 2018
            • 1045
            Thank you so much guys for all your input & tips. I think putting them in series, (5 LEDs per line) will be fine. Surely have to redo all of them. I am so grateful to have so helpful electronics techs all across the world. A BIG THANK YOU ONCE AGAIN.
            • redwire
              • Dec 2010
              • 3912
              The 13Ω resistor seems wrong.
              3V LEDs on 12V power is 9V drop, 26 LEDs at 20mA is 520mA. That's 17.3Ω required. Using 13Ω you'd get 692mA for 6W and 26.6mA per LED.
              Seems too much.
                • 31198
                https://ohmslawcalculator.com/led-resistor-calculator
                • Crystaleyes
                  Calculating resistor values in parallel with Caps
                  by Crystaleyes
                  Hi all.
                  I recently picked up a dead car amplifier from the flea market, with the intention of learning some more in the area of audio repair.
                  It has a stereo output with an added mono woofer output. The stereo channels are on one board, whilst the woofer section is on a separate board. There are also three large (ish) transformers.
                  Apart from the fact that it was seriously dirty inside, it seems to be essentially complete with the only clearly damaged component being a toasted 1/4 watt resistor on the woofer board and it is this which I am wondering...
                  05-21-2023, 07:35 PM
                • Califauna
                  Help with boom box modification
                  by Califauna
                  Hi, this is more of a project help request than a troubleshooting question. I hope I can post it here.
                  I have a W-King D8 Bluetooth boom box which I'd like to modify with some external speaker output jacks and some buttons to switch the internal speakers on and off.
                  From factory the specs of the boom box are:
                  -Power Input: DC 5V
                  -Speaker Output Power: 2 x 25W ( confirmed by Youtube channel Hartdegen review as 12.5W RMS per channel)
                  -Drivers:
                  -2 x Woofer, 70mm, 10Ω, 70mm,15W
                  -2 X Tweeter, 8Ω, 30mm,10W x 2
                  -Frequency...
                  12-04-2021, 01:53 PM
                • unimatrix93
                  Which resistor should I remove/replace to decrease current to backlight leds?
                  by unimatrix93
                  Dear community, I want to increase the lifespan of my backlight led in my TV by decreasing the current.
                  However I need some help identifying the resistor I need to replace to achieve this.
                  Thank you!
                  11-29-2024, 05:05 AM
                • mikey5791
                  by mikey5791
                  Hi to all forum members,
                  12-26-2024, 04:55 AM
                • MidnightRoller
                  Can a resistor lose resistance after hot air?
                  by MidnightRoller
                  I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                  I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                  02-02-2022, 11:46 PM
