Sewing machine Husqvarna 1610 electric contact
  • bohaboha
    • Nov 2012
    • 1016
    • sweden
    can someone say how to put this plug together, there are two cords, one goes to the pedal and the other from wall plug to sewing machine. Don't know if the pedal should get its power from the motor, it's a bit confusing because the two cords coming from the motor are brown colored, don't know which is live or ground the blue and brown cord comes from the lamp. if anyone knows grateful
  • R_J
    • 9559
    Re: Sewing machine Husqvarna 1610 electric contact
    I'm not sure what you mean by "how to put this plug together" as it looks like it is already together.
    Going by picture 1, it looks like the connector next to the switch (2 pins) is for the foot pedal, and the connector on the right (2 pins) is for the a/c line. Post a picture of both the foot pedal and the a/c line cord.
    • bohaboha
      • Nov 2012
      • 1016
      • sweden
      here some other pictures. The cord is connected ground together and live as you see in the picture it must be wrong if you can point which is ground or which is live on the plug on the sewing machine
      • R_J
        • 9559
        It seems this foot switch is not for this model sewing machine, The machine uses 4 wires, and I would think the footswitch is on the neutral or ground, but in this situation I don't think it really matters. The footswitch must just turn the motor on and off, it is not a variable speed footswitch.
        The first picture connects the wires using black as neutral as the two center pins are connected by a coil. The second picture has the two black wires separated and each connected to its own pin on the sewing machine. Either should work.
        • bohaboha
          • Nov 2012
          • 1016
          • sweden
          then the white wire is + Live? = "the two center pins are connected by a coil " have to be Live ?
          • R_J
            • 9559
            I have no idea which pin is the LIVE pin on that plug in your country, It looks like the plug can be inserted in the outlet either way, so it would not matter which is the live pin as neither is connected to the machine case.
            All you are doing is turning a motor on and off, with a foot switch, how complicated can it be?
            In Canada the White wire is neutral and the live wire is Black, if the plug is not polarized, it doesn't matter
            • bohaboha
              • Nov 2012
              • 1016
              • sweden
              in our country Sweden brown is neutral and bleu is live or bleu = + and black neutral and if it is grounded then it is bleu + brown - and yellow-green soil.
              But this construction in the machine only matches half way bleu and brown that goes to the lamp but then the white that is to laid. Going by picture 1, it looks like the connector next to the switch (2 pins) is for the foot pedal, and the connector on the right (2 pins) is for the a/c line. Post a picture of both the foot pedal and the a/c line cord.
              • petehall347
                • Jan 2015
                • 4428
                • United Kingdom
                live neutral reversed shouldnt matter much . it would confuse me as brown is live and blue neutral here .
                on another note the correct cable with plug is available to buy new .
                • harp
                  • Jun 2022
                  • 609
                  • Planet Earth
                  It is pedal with variabile resistance, not only on off switch. Motor speed depends on how much is pedal presed. Motor is stoped if no presure on pedal, go slow if some touch is present, and go full speed if stepped on it to the flor.
                  • bohaboha
                    • Nov 2012
                    • 1016
                    • sweden
                    have searched to buy but can not find do you have any link to it? It's an old machine but looks like new except for this missing connector
                    but i think the correct coupling is -++- it's a bit confusing with coil in those two middle connectors
                    • R_J
                      • 9559
                      Lets hope the variable resistor can handle this motor's current. I know most foot pedals have a variable resistor and switch, but some are meant to control a motor speed controller not the motor directly.
                      • R_J
                        • 9559
                        Maybe this will help, disconnect the two black wires from each other so you have two separate cables, one for the power and one for the switch.
                        • bohaboha
                          • Nov 2012
                          • 1016
                          • sweden
                          The problem right now is not "The variable resistor" except how do I connect the pedal plus the power to the machine? which cord to go to the right hole (plug) is -++- option ok = -+ pedal +- wall socket ?
                          • R_J
                            • 9559
                            There is no + and - it is AC voltage, connect it like I already showed you. Is that a polarized AC plug ??? if not who cares which way it is connected.
                            • bohaboha
                              • Nov 2012
                              • 1016
                              • sweden
                              Sorry didn't see your reply
                              • bohaboha
                                • Nov 2012
                                • 1016
                                • sweden
                                I think it's a polarized AC plug
                                • bohaboha
                                  • Nov 2012
                                  • 1016
                                  • sweden
                                  see how it is shaped the male plug enters in one way
                                  • R_J
                                    • 9559
                                    The motor should not be a concern, the only item that would be a concern would be the lamp. The lamp socket (the outer part that has the threads) should be connected to neutral. other than that, everything else should be isolated and never exposed to a live line
                                    • bohaboha
                                      • Nov 2012
                                      • 1016
                                      • sweden
                                      The lamp is no problem because it is already plugged into this connector it is the one that has the bleu cord and black cord and it should be bleu =+ (live)and black - (gnd) and it is in its place isolated
                                      • R_J
                                        • 9559
                                        • CG2
                                          Janome DC3050 Sewing Machine Pedal Resistance
                                          by CG2
                                          OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                                          Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                                          04-14-2023, 07:53 AM
                                          ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                                          This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 03:28 PM
                                        • Soulzink
                                          Samsug washing machine. Power supply DC41-00189a board issue
                                          by Soulzink
                                          I am trying to fix a samsung washinmachine power supply main board.
                                          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                          The power supply board reference is the following: DC41-00189a
                                          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                          04-19-2025, 06:26 AM
                                        • unimatrix93
                                          How to stabilize AC voltage to CNC machine
                                          by unimatrix93
                                          Hello there everybody, I'm not sure if it's the right topic to ask this but I hope so.
                                          I have a CNC machine wired to 3-phase 230V AC.
                                          It's a smaller CNC machine with a 3500W motor, do it does not uses much power.
                                          The problem is, when the residents come home and put load on the network, the voltage can drop to around 207V which is fine for most household items but by CNC machine stops working from this.
                                          I contacted the electricity company but they refuse to help me solve this problem.
                                          So I started to look around for some DIY...
                                          03-17-2025, 05:52 AM
                                        • xdever
                                          820-01700 not booting, 4V PP2V5_NAND_SSD0 but 2.5V when the machine is off.
                                          by xdever
                                          I got a 820-01700 of a friend that doesn't turn on. I read that a typical issue with these boards is the TPS62180 generating the NAND voltages, so this is where I started looking. Sure enough, PP2V5_NAND_SSD0 is 4V when the machine tries to turn on (I try to determine this by measuring PP2V5_NAND_SSD1, which is 2.5V as it should in this case. The PP0V9_SSD0 and PP1V8_SSD0 power supplies for the SSD are on at the same time when PP2V5_NAND_SSD0 is 4V). The extremely weird thing is that when the machine is off (PP2V5_NAND_SSD1=0, PP0V9_SSD0=0 and PP1V8_SSD0=0), PP2V5_NAND_SSD0...
                                          01-15-2025, 08:44 PM
