Beetronics electric fencer schematic
  • orion4567
    • Oct 2022
    • 4
    Hello, Would anyone happen to have a schematic diagram for a Beetronincs electric fencer Model SPD-9701? These fencers were made in Edmonton, Alberta, Canada.
    Thanks in advance.
    • 31019
    Re: Beetronics electric fencer schematic
    damn, i was hoping for a robot with a sword!
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      tbh I was thinking the same thing for some reason.
      WTF is it? Electric fence charger?
      pictures? of damage?
      • jiroy
        • Jun 2016
        • 2416
        • Lebanon
        Yes , it is ..:
        STINGER LITE DC, SPD-9701; 12 VOLT BATTERY OPERATED FENCER. 47,500 WATTS, 1 JOULE OUTPUT. WORKS FOR UP TO 3 WEEKS FROM A FULLY CHARGED AUTOMOTIVE BATTERY. PROVIDES EXCELLENT PROTECTION FOR SMALL PASTURES, HOBBY FARMS, ACREAGES OR WINTER STACK FEEDING SYSTEMS; US $119.; SHIPPED FROM MONTANA OR IN CANADA ($* CANADIAN FUNDS); DB-BT-VW NO LONGER AVAILABLE; LEFT FOR REFERENCE;
          • 31019
          47.5Kw?? must be chinese ratings!
          either that or buy a couple to protect the u.s. and european borders!
          • jiroy
            • Jun 2016
            • 2416
            • Lebanon
            Yes , but it's one Joule/second .. I like to repair such a device if he put clear images , since I never saw one but in testing devices .
            Doing some research , i got those related pictures ..
            • orion4567
              • Oct 2022
              • 4
              I have attached some pictures of the PCB.
              Of note I have repaired the unit and returned it to the owner.
                • 31019
                so what was it?
                first thing i noticed are the 6A diodes too close to the board - obviously well over-rated as no signs of heat,
                and the associated dark brown resistors - an obsolete type known for drifting and absorbing moisture
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  well, there were three to-92s that seem to have been reworked...
                  hmm... interesting design.
                  anyway good job, didn't need a schematic after all!
                  • orion4567
                    • Oct 2022
                    • 4
                    It was a high resistance connection on the 12 volt battery terminal connection. Mechanically it was sound! An easy fix but I am disappointed in one way. I would have been interested to find out exactly how this particular system delivers 8,000 volts as it was different from the last electric fencer I worked on.
                    Cheers everyone for weighing in.
                    • TinkerTron
                      Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                      by TinkerTron
                      Hey everyone,
                      I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                      Instead, here's what's been bugging me so far:
                      The schematic...
                      03-06-2025, 02:03 PM
                    • atunguyd
                      Acer x163w Monitor PSU schematic
                      by atunguyd
                      Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                      The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                      03-05-2025, 02:08 PM
                    • Thetechdude
                      MSI Ventus RTX 4080 16G Broadview schematic needed
                      by Thetechdude
                      Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
                      I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
                      Thanks.
                      07-15-2025, 11:15 AM
                    • ianpoultonknights
                      Zenbook Flip 15 UX562AI schematic
                      by ianpoultonknights
                      Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
                      06-26-2025, 02:41 PM
                    • Much Bugs
                      MSI Z390 A-PRO Schematic and BoardView
                      by Much Bugs
                      The Schematic and BoardView( *.cad ) of MSI Z390 A-PRO , the board model no is MS-7B98 Rev1.0-1.1 ....
                      06-24-2025, 10:13 AM
