The best way to drive a heating element?
+ More Options
Posts
    • Jul 2011
    • 6039
    Re: The best way to drive a heating element?
    Here is an of the shelf solution that might work for you if you are going to use it for 5 volts or 3 volts you will need to change the resistor to the optic sensors for it to work correctly
    If I remember correctly it is setup for a 12 volt input system
    https://www.ebay.com/itm/29216811276...Bk9SR4Kvve7BYQ
    Another option might be to use this module might be a simpler method of doing what you are trying to do
    https://www.ebay.com/itm/224143044400
    You might get a module that does not work correctly meaning that you can not get the current all the way down to the milliamperes range just try another module I have had this issue with a couple of these modules but most of them do work correctly
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      That's tempting at that price. I already got the IRL7833PBF's ... just a few bucks for a 10 pack on Amazon. If it doesn't work out, I'll definitely use one of those boards. Looks like a fairly simple circuit..
      sigpic
      • EasyGoing1
        Shock Therapist
        • Sep 2016
        • 977
        eccerr0r - just an FYI, I added you to my ignore list. I should have done that a long time ago. I cant see any of your posts anymore so don't bother with me anymore please.
        sigpic
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Originally posted by EasyGoing1
          You can point out my mistakes all you want, I'll just ignore you from now on. Your criticism doesn't help me at all.
          And likewise you can keep assuming your mistakes are correct, and don't deserve to learn. Which is fine because obviously you don't.
            • Jul 2011
            • 6039
            It is and it is easy to modify the control circuit just by changing the optic sensors input resistor but you need to change both resistors one for each optic sensor because one is for mosfet and the other one is visible indicating LED light
            • EasyGoing1
              Shock Therapist
              • Sep 2016
              • 977
              Would you happen to know or have at the ready ... a schematic for a circuit like that?
              sigpic
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16956
                One last time (and I mean for the LAST TIME), we're not in friggin' junior high school here....If you can't post without insults and condescension, just sit on your hands instead. Save this nonsense for the VIP section and out of tech threads.
                <--- Badcaps.net Founder
                Badcaps.net Services:
                Motherboard Repair Services
                http://folding.stanford.edu/
                Team : 49813
                Join in!!
                Team Stats
                  • Jul 2011
                  • 6039
                  It is very simple to do there is a dot on the optic sensors and if you look at the board just above it you will see a resistor that is for input side the other resistor is on the output side of the optic sensor
                  https://content.invisioncic.com/ulti...23284c0728.png
                  You have to change R10 to 500 to 1000 ohms for it work properly on 3 to 5 volts just make sure that you do not over drive the optic sensor according to the data sheet
                  R8 only needs to be changed if you are using it for less than 24 volts on the output side
                  You can use a PWM controller on this setup by the way
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    #49
                    Originally posted by eccerr0r
                    Thumbs up on 60N02. IRF510 is a flaming heap. or will be one if one tries to use it as is.
                    On the other hand, that otherwise flaming heap and pretty useless power MOSFET can be had for peanuts... and someone over on your side of the pond managed to coax A PAIR of them to run in FM. I had seen ham/CB/AM/SW setups with them before, but, damn...
                    I could never get that guy's schematic to work fully, he must have had some golden parts with very low gate capacitance, I have burned dozens trying, but I have managed to get a single one to work reliably and built two modules which I cascaded one after the other.
                    The first gives around 4-5W from 1W in, the second boosts that to 8-12W depending on frequency. It DOES work. Even my radio buddy who's built all the classics with Russian, Motorola, Philips transistors was shocked by it. It's certainly weird, but if you look at it long enough it starts to resemble half of an expensive Motorola power RF FET. That's what it is, actually. He still has that transmitter which we built inside an old VCR case and it still works.
                    A working TV? How boring!
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      Yes people like IRF510s because they're low capacitance (at least to the insane other mosfets around that can drive higher currents) and thus great for QRP and even higher (maybe 20W or so) transmitters. but for this specific "high current" load and drive limitations (digital logic ics)...
                      nope.
                      BTW I'd be kind of worried about accidental impedance mismatches, especially since the transistor isn't specced for RF use like specs for its input/output impedance depending on frequency. Antenna mismatches then causing SWR problems and then damage to the transistor...
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        #51
                        Yeah. Digital logic was out of the question from the start - it needs a 15V gate voltage for achieving the rated RDS(on), which isn't stellar to begin with.
                        That transmitter has been working for years. The gain of the IRF510 at commercial FM frequencies is so low that it needs to be lifted into mostly linear mode (and thus efficiency is low) but I have never blown a single one due to SWR issues. Overheating or oscillation on a lower frequency otoh... However they are less than $1 a pop retail in local stores - I could afford to blow two dozen.
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          I'd be surprised you get 1W out of an IRF510 at 3 meters - not sure what kind of gain if any at that frequency since the GBP is only 20MHz, so it may even be a gain loss there...
                          But for HF you should get some gain at least especially 20 meters or longer wavelength, for sure... enough to get things going and self-destruction if not tuned right.
                          • bendeg
                            Test circuit for curiosity : 2 x NE555 (astable + PWM) + n-mosfet + var 10k + pc fan
                            by bendeg
                            Hi reader,
                            I'm trying to control a pc fan speed by giving PWM to the gate of a n-mosfet.
                            1) generation of a clock with a 555 timer (~ 1,5 kHz, as seen in the datasheet, fig.12) (Vcc = 6V).
                            Output to TRIG of second timer (pin 2) + red led
                            2) generation of a PWM with a second 555 timer (as seen in the datasheet, fig.18), CONT (pin 5) modulated by a variable 10k resistor (Vcc)
                            3) Using output of second timer to "pulse" n-mosfet gate (MDP13N50) + yellow led
                            4) pc fan (12V, 0.18A) in series in drain-source of...
                            05-01-2023, 07:59 AM
                          • Jane
                            How do you test MOSFET in laptops ?
                            by Jane
                            I tried to use this method:
                            Testing an N-channel MOSFET:
                            Step 1: Discharge the Gate (turn off the MOSFET)
                            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                            Step 2: Charge the Gate (turn on the MOSFET)
                            Now, place the red probe on the Gate (G) and the black probe on the
                            09-27-2024, 03:31 AM
                            Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                            by sam_sam_sam
                            I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                            I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                            12-16-2023, 08:39 PM
                          • Nooy
                            VGA MOSfet permanently shorted and loss of MOSfet pad
                            by Nooy
                            Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                            I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                            02-14-2024, 02:26 AM
                          • JayPoorJay
                            A Central Air Heating Element, A PID and a Sauna
                            by JayPoorJay
                            What could go wrong...?
                            I'm not sure if this is the right sub category or even the right forum but here goes,,,
                            I'll just dive right in. I want to see if it's possible and what it would take to use a PID Controller (or 2) to run a central air conditioning heater element (the kind that goes into an air handler) and a small blower fan... The application is a DIY Sauna... Am I nuts? Mean, these components could be had for around 100 bucks.
                            What do I need to be thinking?
                            Of course I will go to Vevor and order one of their 200$ sauna heaters so I...
                            01-10-2024, 02:48 PM
