Quick Question. If you have 2 identical android phones, same model.(Device 1 and Device two) If you transplant the eMMC from device one onto device two. Will it work or do i have to transplant the CPU too?
Will transplanting 1 eMMC from1 device to another device of same model make it work?
Re: Will transplanting 1 eMMC from1 device to another device of same model make it wo
Hmmmm.. I think i will just try dump the emmc and back up the stuff in the working phone.
Thank youComment
i think you can try, it can work but just for save the data only. Maybe baseband will lost.Comment
I managed to get usb working again by reballing the ic RT5081. Managed to dump the firmware and using poweeriso i can see the system folders.
Is there away to extract userdata been trying power iso for awhile and nothing...Comment
I wanted to dump the phones eMMC
The Phone is a Tecno AX8( Phantom 8)
I managed to dump the ROM using Miracle Thunder(MTK Tab) All Bin Files.
I checked the filesystems using cygwin System folder is EXt4, userdata.bin says data.
Thats where i am at.
Now i am looking for a way to read or mount the userdata bin file.Comment
by EazyBoneI am extremely new to programming and dipping into this. I picked up a XGECU T48 Programmer and have the correct socket for EMMC.
I took the EMMC off a working main board with no problems and threw it into the programmer. I click analysis IC and it gives me a report (attached) of the current EMMC. Model H26M41204HPR
1) I manually found this chip(above model number) in the select IC section of the XGPRO 12.xx programmer software and it had a option for 4 bit and 1 bit. I chose 4... is this correct?
2) In the options section point number 2 operation says "30...5 Photos -
by CornholioGSMHello all,
help needed.
I want to made backup of boot and all partitions from emmc desoldered from old phone.
So i have wired emmc directly to RT809h - Dat0, GND,CMD, CLK, VCC, VCCQ - on programmer sw set Smart Identify to EMMC ISP and voltage to 3.3V.
In Settings (N) i have set area to user, boot1,boot2 and EXT and vccq set to 1.8V (tested 3.3V too).
Problem is, that i still get Read Timeout Error
OK - emmc can be dead...so i have tested emmc wires connection to micro SD adapter and then in card reader and emmc was detected.
So...01-16-2025, 04:34 PM -
by YolofolkssHi this is a really odd case.
I have removed all of the esd ic for USB 3.0 and 2.0
I measured all of the data lines and 5v usb voltage lines there are no shorts
all of the USB ports have no damage
Clearing the bios using the jumper wont help.
it is still showing USB overcurrent device
the only temporary fix I've tried and worked so far is flashing the bios
and the error is gone
but when you start the motherboard with a USB device still attached
the USB over current device error is back. the bios needs to be externally flashed... -
by imran333I saw this software on a foreign forum where you have to pay to get advice but the website doesn't seem great when translated and hardly anyone speaks English there, I saw this software they use for programming the emmc on Sony android boards but can't figure out what device or software it is, here's a picture of the software and maybe someone knows what it is ?...
by mrdevilHi all,
Wanted to share this as I couldn't find anything on the internet about this problem, so pulled one apart and found the problem myself. Years ago I bought approx 20 or so Crest Smart Home Single Power Adapter smart switches - small 240v Tuya-compatible (rebranded) smart switch devices with power monitoring, which Big W had on sale for half price. Paid $7.50 each for these, and they've been incredibly useful for turning things on and off remotely... and monitoring how much power each device uses.
However, after about 12 months, I had a number of these stop working... - Loading...
