Am I working safely?
  • Francesc V.
    Tempus fugit
    • Nov 2022
    • 231
    • Catalonia
    Hi:
    I would like to ask you a couple of questions regarding my work station.
    1. Is this a right isolation transformer to isolate it from ground and work more safer for instance with SMPS?
    I bought this transformer where I have plugged a serial lamp and from it I plug the PCBs I want to test.
    2. Isolating correctly the oscilloscope
    I am not sure if connecting the oscilloscope at the isolation transformer will be good idea when measuring things with HOT GROUND........or maybe better to use batteries and have it fully isolated.
    I'v bought a second hand osciloscope and I have built a 5V battery for it.......is it a good configuration? or both are good?
    Thanks in advance,
    Francesc.
  • R_J
    • 9535
    Re: Am I working safely?
    That is NOT an isolation transformer, it is a variac (autotransformer) It will not isolate anything from the a/c line.
    • Francesc V.
      Tempus fugit
      • Nov 2022
      • 231
      • Catalonia
      Thanks R_J for highlighting it!!...
      So better I buy a real isolate one before I die.
      What about the oscilloscope external supply? Battery powered is a good isolation from ground, right?
      • harp
        • Jun 2022
        • 598
        • Planet Earth
        Just dont even think that isolation transformer is ultimate safety against dieing or worse...
        Have you watch and understand plenty of yt videos about problem with ground and where come isolation transformer handy?
        Battery power devices is more protected in practice, when using only one channel.
          • 31011
          real men just keep their hands dry and watch where they put their fingers
          i couldnt count the number of times i disconnected a 20kV charged crt with bare hands
          • R_J
            • 9535
            The isolation transformer is there to protect the equipment and the unit you are working on, It is not going to protect YOU from getting shocked or worse.
            It is necessary when connecting a line powered scope to a smps primary circuit. without an isolation transformer, as soon as you connect the scope ground to the primary hot ground you will blow the primary circuit and likely your scope ground clip and lead at a minimum.
            • harp
              • Jun 2022
              • 598
              • Planet Earth
              NHF, newermined how much smileys you put, that comment is not helpful in this type of thread...
                • 31011
                • Francesc V.
                  Tempus fugit
                  • Nov 2022
                  • 231
                  • Catalonia
                  Do not worry.......I think I am getting the irony. Thank you all for your replies.
                  I got a Real isolation transformer (1000 VA). However I put 230V on the input and I only have 180V on the output. I am wondering whether to use it or not. The idea goes as follow:
                  I connect the transformer to the main. The output for this transformer to the VARIAC and setting it to 230V. The VARIAC's output to the serial lamp.......
                  Will it be ok or better I keep the current config?
                  Thanks you your patience of keeping me alive
                  Regards,
                  Francesc.
                  • petehall347
                    • Jan 2015
                    • 4426
                    • United Kingdom
                    isolation transformer should be 1 to 1 so something is wrong .
                      • 31011
                      got a picture of it?
                      • Francesc V.
                        Tempus fugit
                        • Nov 2022
                        • 231
                        • Catalonia
                        2-4 1 ohm
                        3-5 1 ohm
                        ( I also tried to feed 230 in both "inductances" at same time; same result)
                        I am getting about 180V between 8-11 in the secondary.
                        • harp
                          • Jun 2022
                          • 598
                          • Planet Earth
                          Thats a nice one
                          You are doing something wrong with wiring.
                          I guess that in primar is two 230 windings, first between pin #2 and #3, and second between pin #4 and #5.
                          Secondary might be between pin #9 and #10
                          Check double before plug in...
                          • petehall347
                            • Jan 2015
                            • 4426
                            • United Kingdom
                            its wired wrong .. looks like it needs the jumpers .
                            looks more obvious here ..
                            • harp
                              • Jun 2022
                              • 598
                              • Planet Earth
                              Yes... external jumper settings (connection link) may represent this ilustration indeed, but how he get 180v?
                              • Francesc V.
                                Tempus fugit
                                • Nov 2022
                                • 231
                                • Catalonia
                                Fixed!! I was missing 3 jumpers.
                                2-3,4-5,9-10
                                So.....I will use it instead of the VaRIAC.
                                Badcaps approved??
                                • petehall347
                                  • Jan 2015
                                  • 4426
                                  • United Kingdom
                                  2-3,4-5,9-10
                                  Badcaps approved??
                                  well done .
                                  • Per Hansson
                                    • Jul 2005
                                    • 5895
                                    • Sweden
                                    Badcaps approved??
                                    No! I have to say that is the most counter intuitive transformer plate description I have ever seen, and I have seen some confusing crap!
                                    Good work getting it working without it blowing up!
                                    • Francesc V.
                                      Tempus fugit
                                      • Nov 2022
                                      • 231
                                      • Catalonia
                                      All tests done using the light bulb......that helped not blowing up everything. Once mounted I realise that there is a YouTube video that explains all steps.
                                        • Jul 2011
                                        • 6039
                                        I have to agree with you on this most of the time it would show you what terminals would give you a certain voltage this one shows you the windings real odd
                                        • harp
                                          isolation transformer from two 240/12, wiring?
                                          by harp
                                          When is talk about making isolation transformer on poor-man way, always I see schematic 240/12-12/240.
                                          So, I wonder, is this wiring from my attachment it work, bringing some good feature or it is bad idea and why?...
                                          11-25-2022, 05:11 PM
                                        • bohaboha
                                          can a flyback transformer for USB charger isolate?
                                          by bohaboha
                                          can i use a flyback transformer from an usb charger to isolate galvanically a small diy led tester? or it must be an isolated transformer
                                          01-15-2022, 02:36 PM
                                        • mikey5791
                                          Is it possible for transformer substitution?
                                          by mikey5791
                                          Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                          Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                          My questions are
                                          1. How do i test to see if the transformer is in good working condition?
                                          2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                          Hope you guys understand what i was asking. My intention is...
                                          11-03-2022, 02:11 AM
                                        • dennis_elx33
                                          3PHASE STEP-DOWN Transformer in Check
                                          by dennis_elx33
                                          Hello All,
                                          i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                                          Problem statement: Power tripped Off
                                          Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                                          Action Done:
                                          1) Replaced the faulty parts with good spare.
                                          2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                                          12-02-2024, 06:52 AM
                                          ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                                          This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 04:40 PM
