Need help with solder pot pls
  • petemanuk
    • Feb 2022
    • 26
    • Wales - United Kingdom
    Just bought a solder pot (actually a retangle 180mm x 140mm x 45mm) as i want to use it to take muilt pin connecters (288 pin) off boards so i can replace them, the problem is the tank/pot needs a lot of solder to fill it!!! and that's gonna cost a furtune . Would any one know it if it would be ok to put say a block of metal in the tanks to reduce the volume so i dont need to buy so much solder?
    • 31314
    Re: Need help with solder pot pls
    sounds reasonable, but make sure the item is copper for good heat transfer
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8716
      surprised solder costs so much nowadays...
      a brick of copper technically should be more expensive than a brick of solder. Probably have to use a brick of iron or something and be damned about the heat conductivity.
      • diif
        • Feb 2014
        • 6978
        • England
        When I was looking for lead for making low melt solder there were sellers on ebay selling decent weights for not much. i found that the price of tin was much cheaper off Aliexpress though.
        • petemanuk
          • Feb 2022
          • 26
          Thanks all for the info.
          Bit of a wild card i've seen a roll of roofing lead for a resonable price only thing i cant find what its actual composition is?? so may not be suitable for soldering, i'll post my findings as soon as i can get some more info (unless anyone else on the forum knows)
          Thanks again.
          • diif
            • Feb 2014
            • 6978
            • England
            Roofing lead is just lead. You might want to add some tin to lower the melting point.
            • harp
              • Jun 2022
              • 650
              • Planet Earth
              About 60% Pb and 40% Sn, for work with flame burner.
              Information may be marked directly on stick, say 40% Sn.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8716
                Interesting, wonder how cheaply you can get roofing lead flashings and try to make DIY lead acid batteries with them...
                • alfatv
                  • Sep 2020
                  • 353
                  Probably it would be better to use smaller pot.
                  Anyways, your idea about metal piece may work. I suggest to use aluminum, it has very good conductivity, much better than solder and not so expensive.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8716
                    Actually one problem that hasn't been considered... wouldn't a brick of aluminum float in a pool of solder? I think even iron may float in a pool of molten solder. Copper might actually sink, but again copper is more expensive than solder.
                    I'll need to test this the next time I remelt my pot of waste solder I've collected, I figure a lot of stuff could actually float.
                    • Daemoch
                      Jaded Optimist
                      • Aug 2013
                      • 6
                      not sure if youve already gotten a solution, but how does your cost compare to getting a cheap propane tank driven forge/casting/melting setup? (google amazon for examples). aside from having other potential uses, you could basically melt down whatever materials you wanted then and basically recycle stuff, make your own formulas, etc.
                      Rules:
                      1 - If it can happen, it will.
                      2 - There is always a way.
                      3 - There is always a BETTER way.
                      4 - There is an exception to every Rule, including Rule #4.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8716
                        Too easy to overheat the pcb using propane...
                        • corrize
                          Best way to solder LVDS connector for beginner (and qfn) ?
                          by corrize
                          Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                          I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                          I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                          See the test :
                          https://youtu.be/bNAzC-EvqHs?t=1767
                          With hot air from bellow the board, that's...
                          03-09-2023, 02:57 AM
                        • petemanuk
                          BGA solder balls not connecting - help pls
                          by petemanuk
                          So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                          I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                          I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                          11-16-2022, 05:21 AM
                        • myth77
                          UV solder mask - high temp resistent, recomendation?
                          by myth77
                          Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                          Is there any solder mask...
                          03-28-2022, 04:04 AM
                        • Inforgalaxie
                          IR6000 profile ramp to solder AM4 Socket
                          by Inforgalaxie
                          Hello I have a IR6000 and i need solder new AM4 Socket in the motherboard.
                          I was solder one but damage the plastic socket...
                          Can you tell me what is the best profile ramp to do that?
                          Thanks!...
                          12-03-2025, 03:41 AM
                        • acedogblast
                          by acedogblast
                          11-02-2024, 05:13 PM
