Well, I trashed my IBM Socket 478 board. Cause: Impatience. I Had removed a cap, but one leg separated from the cap and remain lodged in the board. Rather than applying some new solder to the offending pin, I stupidly pushed on the protruding pin with the tip of the iron, as it seemed to be "almost" free.
Predictably the iron slipped and exposed a trace. Bloody thin coatings on these newer boards.
Only previous board I wrecked was an Asus P2B-S. I was attempting the bridging of the two Socket 1 pins that allows Coppermines to be fitted to certain BX440 boards.
Worked great on a P2B-DS v1.04, so I tried it on this board. Managed to bend one of the
pins inside the Slot, touched another pin and POOF.
On the other hand, I have successfully recapped maybe a dozen other boards, probably a dozen or so sound cards and some video cards so it could be worse.
Lesson learned - be Patient at all times and don't work when you are tired or pressed for time.
