I recommend DMM UNI-T UT61B+
  • bhgsmservis
    • Jan 2022
    • 6
    • BiH
    Today I recive my new multimeter UNI-T UT61B+.
    First impression is great, very nice dmm for this coste.
    BR
    • 31094
    Re: I recommend DMM UNI-T UT61B+
    61E is the one with best features
    • redwire
      • Dec 2010
      • 3910
      61B+ doesn't have the extra MOV's for protection?
      • jayjr1105
        • 281
        Uni-T always offered good value as long as you're not probing around any high energy stuff. I bought this exact meter but returned it and I can't remember why. It probably had a quirk or two I didn't like. I ended up with a slightly more expensive Brymen BM786
        Ryzen 3600x
        16GB Patriot 3600MHz
        MSI B450 Gaming Plus
        MSI Air Boost Vega 56
        Acer 32" 1440P Freesync
        Rosewill Capstone 750W
        Hakko FX-888D Station
        FX-8802 Iron
        MG Chem .8mm 63/37 RA 2.2%
          • 31094
          https://www.uni-trend.com/meters/htm...es/UT61B+.html
          comparing the B to the E, B must stand for basic
          • jayjr1105
            • 281
            Did you mean this one? (yes I modded it with a blue LED backlight) I have since given it away.
            Ryzen 3600x
            FX-8802 Iron
              • 31094
              yes,
              but they have a + version now with backlight and some other changes.
              • KadFree
                • Apr 2022
                • Belgium
                I was looking to buy one.
                Tx for sharing
                • aaronkatrini
                  by aaronkatrini
                  - Autorange
                  - DC volts up to 30V
                  - Accurate Resistance
                  - Diode test (Beep mode)
                  - Frequency up to 200MHz
                  - Capacitanze up to 5000uF
                  - as cheap as possible
                  05-06-2024, 09:54 AM
                • ngml
                  Repair of an LG split AC system indoor unit PCB
                  by ngml
                  I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                  This indicates an error in the communication between the outdoor and the indoor unit.
                  The outdoor unit is fine, so the problem is the indoor PCB.
                  The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                  I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                  Does anybody have the schematics of this board,...
                  02-01-2025, 12:55 PM
                • dj8452000
                  How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                  by dj8452000
                  I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                  02-18-2025, 08:28 AM
                • nobbnobb1
                  Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
                  by nobbnobb1
                  Hi guys,
                  Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
                  When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
                  02-03-2022, 11:14 AM
                • Gjackson
                  Air-conditioning unit power supply failing to power up
                  by Gjackson
                  Hi all, I managed to narrow down which PCB was causing my Haier AC to throw out an E7 error code (E7 indicates that the indoor unit and outdoor unit cannot communicate). I found that the outdoor unit power board which gives 5v and 15v to the outdoor unit module board fails to fully power up.. The power Led starts to fade in incredibly slowly and the 5v and 15v power buses jump around like crazy and never reach their required voltage. I unplugged the module board from the power board and the power board powered up fine! It had a steady 5v and 15v out and the power LED came on instantly and Bright....
                  01-08-2022, 09:24 AM
