oscilloscope probes
  • aliasdck
    • Sep 2009
    • 100
    oscilloscope probes
    I have some cheap (~$20) generic 100Mhz oscilloscope probes. I am currently looking for a used 200Mhz scope but Im wondering what type of probes I should consider getting for it. The probes I've found so far are all very expensive (over $100 each). Anyone have any recommendations on which probes I should get? I'd rather not spend too much money if I don't have too.
    I plan to use the oscilloscope to help me diagnose problems in plasma tv's... service manual recommends 200Mhz scope.
  • cadiman
    • Mar 2010
    • 397
    Re: oscilloscope probes
    I have a hitachi 100mhz and use the probes that came with it. When you pick up a scope it will normally have probes with it. You will need to calabrate them. I have been using mine on plasmas and I have been able to dial in and set waveforms by the book.
    I have not used my scope for diag on a tv yet. I only used it for set-up and set-down on the y sus boards.
    I have a scope for automotive use that is pc based with lots of waveform storage and good for record keeping, but has voltage limits (I use an inductive pick up or transducer (picks up vibration). Something to look into. Wizard would know more. I have never read very high waveform frequencies on my scope,(on plasma) but I am new to plasmas.
    I have mostly used scopes to look for signals to trace through a board then looked at the waveform for distortion. You have a good question here and I look forward to all the answers! Thanks, Cadiman
    • aliasdck
      • Sep 2009
      • 100
      Currently I need a scope capable of looking at setup and setdn waveforms as you mentioned. I'm glad to hear 100Mhz is plenty for this application though ill likely still try to find a 200mhz.
      I've been searching ebay for used scopes. Most of what I've come across in my price range do not include probes. I'm thinking about getting a tektronix 475 but haven't made up my mind yet.
      • cadiman
        • Mar 2010
        • 397
        I do agree I wish I had the 200, but I mostly do audio work and automotive as well. I purchased my hitachi new for around 2000 bucks and didn`t even price out the 200.
        They should be cheap now and I am not sure 100mhz is plenty I haven`t worked on every unit out there. I know you don`t measure 100psi with a 100psi guage you use a 200psi guage. I am sure the same goes for a waveform. I know by setting the timebase I have plenty of chase speed to catch a plasma signal....for now
        I would try to find something local. Only use ebay for a price guide. I wouldn`t want to ship somthing like that.
        Cadiman
        • intp1000
          • Nov 2007
          • 21
          • usa
          IMHO 200MHz is enough, maybe even a little more than enough.
          When I worked for the military industrial complex we had a rule of thumb that any test equipment we built; I was an electrical design engineer, had to have 10X the resolution of the measurment tolerance. So, 200MHz may be about 10X the requirement. Now, in normal shops equipment which is 3 to 5X the requirement is OK. You're not trying to characterize circuits, just looking for a close match. Therefore, while 100 MHz probes may distort the waveform a little trying to buy 500MHz probes (you are going to use them on a 200MHz scope ) may be overkill. I've bought 500MHz probes on epay for 48 $US. Just have to wait and not be anxious about a time frame. While a 100MHz BW probe is not the best match for a 200 MHz BW scope they will work with up to 30 MHz with only small degregration in waveform display (unless you're looking a 1ns rise time square waves). But then, you're not so don't worry. Just use them knowing that sometimes really fast rise time measurement won't quite make it.
          Have fun.
          • aliasdck
            • Sep 2009
            • 100
            Thank you for your advice.
            I just acquired a tektronix 475 a couple of days ago. I'm not going to bother trying to find better probes as it sounds like my current probes will be sufficient.
            Let the testing begin...
            • SolomonMan
              Vintage BK Precision 1403 Oscilloscope....
              by SolomonMan
              All,
              Some of you have helped me in the past and I am very appreciative of all the help! (I have fixed TVs/Stereos/ and other small appliances with your efforts...Thanks so much!!!
              Today I went to a local HAM Radio Festival. It was one of the smaller ones in our area. My stepfather is the HAM operator. I tinker in electronics but am a Software Programmer (27 years now).
              I was looking for a few odds and ends for some electronics work I have to do for the household/farm. Typically these type of shows have the grab bags or a electronics vendor...
              12-03-2023, 10:39 PM
            • repair-it
              Need advice testing a samsung power supply board with scope
              by repair-it
              I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
              07-12-2025, 11:00 AM
            • Tarot Superstars
              How not to Damage an Oscilloscope
              by Tarot Superstars
              Hello.
              I have jut got my first analogue oscilloscope. An Isotech 620 20MHz.
              I want to learn how not to damage it, and I found instructions on the internet obscure.
              They talk about ground, earth, floating ground, this, that....
              But they don't actually say anything anything useful so far.
              I want to know:
              Don't connect exactly this to exactly there or it blows up.
              For example, I am tracing a signal from a function generator in an audio amp, or testing for voltages in different parts of a circuit.
              I want to know what not to connect...
              08-29-2023, 02:27 PM
            • Evets
              Dynamco analogue oscilloscope
              by Evets
              I have recently acquired a Dynamco D7100 analogue oscilloscope without a user manual. As this is the first time I have owned or used an oscilloscope I would like to try and find an instruction book. The manufacturers no longer hold any information and a Google search only found one site but when I downloaded a 'service manual' all I got was gobbledegook. Any help would be gratefully appreciated or even pointers to a generic manual where I could learn more.
              08-30-2024, 06:54 AM
              Hantek scope that can hook up to your iPad or computer IDSO1070A feedback wanted about it specifications
              I thinking about about buying one later on this year depending on what feedback I get from this forum members that know more than I do about what is importance about what to have in a scope
              https://www.aliexpress.us/item/32568...3333736563%21s...
              04-12-2025, 10:24 PM
