solder mask question
  • ramondo
    Confused Member
    • Jun 2015
    • 39
    When I use UV curable solder mask I find it is too thick. Is there a suitable thinner that that would duplicate factory look and remain curable.
    Thanks to all for being__WAR_KITTENS____!
    • 31197
    Re: solder mask question
    ?? use a brush!
    • myth77
      UV solder mask - high temp resistent, recomendation?
      by myth77
      Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
      Is there any solder mask...
      03-28-2022, 04:04 AM
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
    • corrize
      Best way to solder LVDS connector for beginner (and qfn) ?
      by corrize
      Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
      I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
      I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
      See the test :
      https://youtu.be/bNAzC-EvqHs?t=1767
      With hot air from bellow the board, that's...
      03-09-2023, 02:57 AM
    • sircastor
      Solder not reflowing - what am I doing wrong?
      by sircastor
      I'm trying to fix a broken MacBook Air, and got a parts board to salvage components from. Following the suggestions of many folks here, I wanted to get in a little practice of using my hot air station (A Quick 957DW+) on the parts board so I know what kind of behavior to expect.
      For the life of me, I can't get anything done with this thing. I have tried multiple temperatures (from 210-425c), different air speeds, preheating the board (with the hot air, just warming it all around). I have applied what feels like excessive amounts of flux (Amtech V2-TF-559) and the solder on these components...
      03-03-2024, 02:44 AM
    • pixelcap
      Pioneer Plasma 111FD To Solder or Not to Solder.
      by pixelcap
      Hello out there in Badcap land.
      I have a Pioneer plasma that gave me the dreaded 8 red blink and shutdown, I have been trying to trace the failure points. On my last inspection while replacing a Y Sustain Board I noticed on the original and replacement board some missing solder, the points of connection
      are from the Digital Address Board and the Buffer Boards. I have included the pictures, should I resolder these points or are they unsoldered intentionally? Any help would be much appreciated.
      Thank you
      Pixelcap...
      03-08-2025, 07:10 PM
