Any good discount electric desoldering pumps?
  • SluggerB
    • Aug 2020
    • 747
    • US
    I see these listed for as cheap as $40 all the way up to over $200. Does anyone have any experience with any of the discount units that actually work well?
    • 31197
    Re: Any good discount electric desoldering pumps?
    zongdi ZD-915 is good.
    costs about €60 if you look hard enough - average price €100
      • Jul 2011
      • 6065
      I second this but I would recommend this
      If you buy one make sure that you buy extra filters and tips you will need them
      The only other thing that I will tell you the more flux you suck up into the gun the more than likely will clog the tube in the gun but if you happen to do take the tip off and use a 1/16 drill bit if the cleaning rod does not clear the tube
      Here is one on eBay
      https://www.ebay.com/itm/Pro-Vacuum-...-/302470622082
      MPJA electronic store sometimes they have but they have been out of stock for quite some time now but this has happened before
        • 31197
        filters are a robbery, you can make your own better ones.
        that said, thereare a number of threads here about "upgrades".
        from changing the fan and it's power, to making filter discs, to adding an inline (fuel) filter as a backup/pump-saver
        • dicky96
          Sun Seeker
          • Mar 2017
          • 1825
          • Spain
          Pretty much what the others say
          I have this one which is same as / clone of Zongdi 915
          https://www.aliexpress.com/item/4000...archweb201603_
          And it's just wonderful to use
          I find a combination of hot air wand in the left hand and this desoldering tool in the right hand will work even on motherboards with heavy ground planes
          One bit of advice - when you finish desoldering, push a cleaning needle through the tip several times before you switch it off. They are a bugger to clean out if you let solder solidify in the base of the tip!
          Follow me on YouTube
          Learn Electronics Repair
