New tool to find short capacitors on motherboards : shorty with display
 Re: New tool to find short capacitors on motherboards : shorty with display
 do you mean your not getting enough current from the one on the arduino?
 that doesnt surprise me really.
 you probably need to use a 1A linear regulator and some tantalum capsComment
 I added a voltage regulator 1755S to bypass the one inside the arduino. just thinking there would be a better regulation than the 1117. I also added a constant current source with the pnp transistor, to have better accuracy and better reproductibility of the measures.
 now I'm debugging this new schematic, it's almost working, but as a reminder it is a hobby project, and I have been very busy these last months.Comment
 I was more about
 As I see 1755S is limited to 300mAI'm still investing. the voltage regulator is giving 2.4V instead of 5V
 Aprox 60mA via Q1 and resistors, 240mA for Arduino, oled and others.Comment
 I checked on a lab power supply, the whole device is now using 50-60mA.
 the current constant source now is using 30mA.Comment
 Some schematic will help a lot.
 Where did you get 2.4V instead of 5V with voltage regulator?
 Also
 Voltage drop C-E on BC557 at 100 mA is in datasheet 0.65V
 5V -Vdrop on BC557 = 4.35V
 4.35V on 82 + 2 +1 ohms is around 0.051A that is 51mA but since it may be pulsing lab power supply will show some intermediate value.
 I'm not so familiar with Arduino but in source code seems like you defined TRANSISTOR and BUTTON both to pin 3Comment
 transistor is on an analog pin 3 A3, and button on a digital pin 3 D3I'm not so familiar with Arduino but in source code seems like you defined TRANSISTOR and BUTTON both to pin 3
 they are not the same pin.
 anyway, the transistor is always on, and has been removed from the source code when I use the constant current source.Comment
 Are both 3 but must be something to differentiate.
 For digital pin you can define simple with number only but for analog inputs you need to specify is analog one by using A prefix.Comment
 Hi Kripton
 Do you have any up to date news regarding the PCB?Follow me on YouTube
 Learn Electronics Repair
 https://www.youtube.com/channel/UCFX...R8UZ2vg/videosComment
 He has been busy with work. I have considered building one from the schematic, but it's not enough of a priority for me to drag out the perf board.
 I am getting the LCD on order though.Comment
 I have this one in my cart. Not sure I want to go back to the old days with a choice of monochrome green or monochrome amber. I don't miss that at all.
 https://www.aliexpress.com/item/3280...c00gcT6Vz&mp=1Comment
 My LCD for this project just arrived today, it's much smaller than I thought it would be. This project should be able to fit on some perfboard. If you want to build it on some perfboard, I'll go along. Last I heard there was one last issue, and kripton was busy at work. I'm sure he will come back when he's through.
 Want to work through the last issue?Comment
 From eevblog:
 I could contact him and get some sent to me and send them out to others (US only) if there are enough people interested."sending good with a value from france to outside of europe (even into europe) has become a pain in the a** since january 2021 and new EU VAT rules.
 it will be easier for me, and cheaper for everyone, to sell a gerber file of the pcb, and people ordering 5 pcb from jlcpcb or like.
 instead of me collecting many pcb's and sending them one by one to the world."Comment
 Yes the new EU VAT rules (January 1 or Jun 1, 2021) are a really f*cking pain in the a**.
 No more exclusion on small values (less than 20€, including shipment).
 In practice, this means that even end consumers and non-profit receivers / senders in the EU must handle themselves all bureaucracy and collect/deliver all VAT values to EU member State, plus a fixed fee to local/end carrier.
 What a f*cking mess!Comment
			by aaronkatriniHi all,
 Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
 Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
			by snow_sg1Hi,
 First : I've got a SMD rework station, thermal camera and good soldering station
 This is my first "short" motherboard repair, this laptop was 25€ so no loss, it just for learning. I want to learn how to fixed board because I want this to become my job.
 I've been fixing electronics for 15+ years, but mostly VCR and camcorder.
 So, I checked power adapter pin to ground, no short, then I plugged the charger in, light on charger blink indicating short.
 PQ19 mosfet got HOT straight away (viewed on thermal cam). Checked,...
			by ProttHello!
 Recently I have a problem finding a dead short (as far as my cheap multimeter is concerned) on a multilayered (12 layer) PCB. It is caused due to mechanical stress (warping the board and, I assume, cracking inner layers). Injecting voltage of 0.9 V (operational voltage of that part of the circuit) and drawing 0.5 W doesn't cause any visible hotspot on a thermal camera.
 Does anybody have any tips & tricks in order to locate the short more or less precisely? The area has a lot of powerplanes, so it's both blessing and a curse.
 Silly idea no. 1: Can I...-
			by rex98HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
 DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
 The DMI Tool given here are for personal use only.
 DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
 You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
 from it, and that you please credit the author...-
							Channel: BIOS Requests ONLY!
			by Mess
 Hi beginner here, so I'm not sure of I've done this right 😅 trying to diagnose my laptop's motherboard (dax31mb1aa0 rev a). I don't quite know how to read the schematic, so I'm attaching the pictures of the motherboard and the measurements.
 I was attempting to measure resistance to GND on inductors. I disconnected motherboard and used "continuity testing" setting on my multimeter. I put black probe to Ground & red probe on an inductor. Did I measure this right? Am I correct to think that 0.3 ohm measurement indicates a short circuit? Thank you for your help!...
- Loading...
