KID-R600 Black need backup firmware
  • linkoln01
    • Mar 2013
    • kazahstan
    Good evening, forum participants. I have a problem. there is a BGA station Kid-R600 black accidentally reset the settings now I can not control it. you need a firmware backup there is a tpc7062k control unit. It turns out to go into the settings, but the station control utility does not start. I ask for your help
  • sikocan
    Lenovo X1 Carbon 9th Gen Black Screen
    by sikocan
    I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
    SN: PF3G1REP
    MODEL: 20KW-00J1AU
    PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
    Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
    06-24-2025, 09:01 PM
  • Greg81
    Acer Nitro 17 VN7-793G Black Edition Neptune_KLS Thunderbolt firmware
    by Greg81
    does anybody have the firmware for the TPS65982DA conroller? Type-C 3.1 gen 2 and HDMI is not working. I have replaced Alpine Ridge controller JHL6340 so far (bought on Ali Express), since it had low resistance on one of the HDMI diff pairs. I tried the firmware from the VN7-792G, which has TPS65982ZQZR (different index!) onboard which at least has stopped hanging when restarting and HDMI started showing discolored picture on my monitor with DVI adapter (but no picture on my TV with native HDMI port). Would be glad if someone could upload working firmware, so I can proceed...
    02-12-2024, 02:15 PM
  • liquidzorch
    862D+ solder station iron out of control when fan on
    by liquidzorch
    Hello.
    I have a soldering station, 862D+, and every time the hot air gun is on, even if it is just cooling off, the soldering iron controller stops controlling. Let me explain what has happened so far, as it took a while to get to this.
    First, the switch that turns on the hot air gun started to fail, the light came on, but temp never rose, I would have to switch it multiple time to get the gun to start heating, this was due to the contact inside being carbonized. I opened the switch up, clean the contacts, and it would work fin for a while until carbonized again. So, I ordered a switch...
    06-09-2022, 08:49 PM
  • TheUser
    Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
    by TheUser
    Hello to everyone ,
    This is my first post here, and i would like to share with you a small story in case you can help me.
    Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
    All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
    I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
    02-10-2024, 02:07 PM
  • zklgfs
    Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
    by zklgfs
    I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
    08-11-2025, 02:14 PM
