Yihua 305D IV off measurements
  • marce002
    • May 2018
    • 316
    • Argentine
    Hi
    I was wrong buying this bench YIHUA 305D IV!!! is was a real mistake since amps readings are terrrible off... Can anyone know how can I calibrate with the 4 internal blue pots in order to have real amps reading and not offset in low currents (like 100mah error!!...)
    I have managed to get volts almost acceptable *compared with my reliable unit multimeter 980d+, but current think has 3 pots to work with.... i know maybe they are for:
    1- mA range gain.
    2- A range gain.
    3- mA and A offset.
    4- V gain. says VR in the board attached pic
    but dont know which one controls what, in the IV version... see circuit attched
    also the procedure to calibrate or adjust..... low current measure half of the real current eg says 50mah and should be 110mah in 4000mah says 310mah and so
    crap
    Marcelo J
  • clearchris
    • Dec 2013
    • 687
    Re: Yihua 305D IV off measurements
    They do have contact information, why don't you ask?
    http://yihua-soldering.com/product-4...ply-en/160008/
    I wouldn't imagine they would be proprietary about that. I assume there was no manual?
    • marce002
      • May 2018
      • 316
      • Argentine
      Already contacted them... is a shame support gave nothing useful
      Marcelo J
        So you have calibrated Amp meter as a reference (980d+???) to verify that the meter of the power supply is not correct?
        "low current measure half of the real current eg says 50mah and should be 110mah in 4000mah says 310mah and so"
        So in low range the error is more than 100% off, showing 50mA instead of 110mA, But what does "in 4000mah says 310mah" mean? The real current is 4000mA but the power supply meter shows only 310mA?
        The IV version may be too new to have some review and info about the problem for this IV version.
        https://yihuadz.en.made-in-china.com...er-Supply.html
        I like their claim of 'high precision'. Link in post #2 does not show the IV model.
        https://cdn.badcaps-static.com/pdfs/...9b15493ec5.pdf
        Not much in the manual. So far I have not found schematic for the unit to show what the pots are for.
        There are some info at EEVBLOG for the 305d, the circuit mat be the same and only the displays are not the same.
        https://www.eevblog.com/forum/review...05d-bench-psu/
        https://www.eevblog.com/forum/review...ion-procedure/
        Some youtube for 305D: may be the same quality for the IV series.
        https://www.youtube.com/watch?v=KEppGK6wWKA
        • marce002
          • May 2018
          • 316
          • Argentine
          Budm sorry 3100mah and my tester is a 890d+ i was in a hurry typing
          Marcelo J
          • cnti
            Samsung 245B PLUS - BN44-00195A - bang and smoke - solved - tips
            by cnti
            Hi.
            BacCaps forum is awesome - thank YOU ALL for sharing knowledge!
            This is about DONG YANG PSU BN44-00195A failiure in Samsung 245BPLUS. It started with bang and smoke from the back of LCD. Downloaded diagram BM44-00192A - a bit different but I will use all parts names from this diagram [and real PSU].
            BIG CAP CP801 had 315V, on standby pin 5,2V. After shorting S_B ON (through 3,3k ohm resistor) 24V and 5,3V were missing, on CP801 was 312V.
            RM801 [real PSU: RM801 - 0,22 ohm 1W] - FAIL
            burned, measured 10M ohm.
            QM801 [real PSU:...
            10-19-2023, 05:33 PM
          • edugimeno
            Diagnose real-vintage Strong-Hammer arcade machine
            by edugimeno
            Hi there!
            My friend wants me to help him repair his old-real-vintage strong-hammer machine. Well it's only 90% real as the force applied doesn't lift the weight itself but it is measured and it moves a motor that lifts the weight
            I am attaching several pictures of the machine.
            It basically has 2 sides, left side has
            • 2 x 220->12+24v transformers
            • 2 relays (1 moves motor UP, other moves motor DOWN)
            • IGF and breakers for safety
            Right side is shown on pictures. It has 3 boards ( top-down)
            • Logic board. Receives 24AC and recitifies it into DC. Contains a uC (M80C85)
            02-29-2024, 11:05 AM
          • DynaxSC
            by DynaxSC
            11-17-2023, 10:56 AM
          • Peter_1402
            Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
            by Peter_1402
            Hi Everyone,
            I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
            1. Soldering iron works great
            2. There is a burnt mark on the hot air gun handle.
            I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
            Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
            Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
            Reed switch tested ok with a magnet.
            From the above test, I can conclude...
            07-12-2025, 11:50 AM
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
