I have about a dozen motherboards here that need new LGA 1151 sockets
I am able to remove the old socket but I have a problem with some sort of oxidisation that is getting onto some of the BGA pads and I am struggling to clean it off. Even dragging a solder ball around with my T12 doesn't shift it. See attached video
I assume that I need to get all these pads clean before attempting to solder the replacement socket? So how do I get them clean and shiny?
Another problem - So far I have not been able to fit a new socket successfully.
After soldering and checking for continuity from the LGA pins to 0V or Vcore it is obvious that only some pins are soldering. if I remove the socket again it is obvious that many of the balls did not melt because a lot of the PCB pads are still 'flat' with no solder on them. And this is when I get this oxidation problem even worse.
After a bit of experimentation I created a profile that will desolder LGA sockets from gaming motherboards, as the one I use for standard motherboards wouldn't do it.
But that profile will not attach the new socket properly. I then created a profile that is 10C hotter on the final ramp up and it still isn't soldering the new sockets. IIRC, with this profile, the probe near to the LGA on the top of the PCB is getting up to around 260C-265C on the final ramp up.
I will have to try a hotter profile for sure, it seems my probe isn't reading the actual temperature at the LGA to PCB junction. But how much more heat?
Also should I apply flux to just the PCB or to the PCB and the LGA socket? I'm using NC-559-ASM from Aliexpress. Can too much flux be as problematic as not enough? What is the correct amount?
video https://youtu.be/uMiCsbOJ-ZU
The cleaning liquid is Iso Propyl
Pics
Profile 'LGA Gamer' used to remove
Profile 'LGA Gamer Mount' used to solder.
Questions Questions lol
Rich
Pics
Rich
