How to clean oxidation from BGA pads?
  • Spider1211
    • Oct 2019
    • 532
    • Mauritius
    Re: How to clean oxidation from BGA pads?
    @dicky96
    Sadly none like this around me. Even if there was, I can't go out to collect it.
    I do have some flux but not as good as the 559. I'll only be using those if there is no other choice.
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
    • petemanuk
      BGA solder balls not connecting - help pls
      by petemanuk
      So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
      I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
      I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
      11-16-2022, 05:21 AM
      Multifix 425-01 and 450-01 Rework Flux Datasheet
      REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
      - No Clean Formulations
      - Low residue
      - Range of activity to deal with different component solderability
      - Halide free
      - Suitable for dispensing
      - Compatible with solder coatings and/or No Clean flux cored solder wire product range
      Both products are supplied in syringes or cartridges for application by dispensing....
      10-07-2024, 06:02 AM
    • dbuergi
      Restore solder pads for SMC on MacBook A1466
      by dbuergi
      i got a A1466 logic board for spare parts but it looks like the SMC ist bad. I got several spares but somehow i was too fast while removing it and ripped some pads off. You can see the damage attached.
      Just for experience i would like to restore the lost pads but before i start (haven't done this before) do you have some hints or tutorials how to do it?
      As written i want to improve skills so it doesnt matter if it takes longer.
      12-29-2024, 10:24 AM
    • chth96
      Is it good to use chemistronic flux off es835b for flux remover?
      by chth96
      I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
      Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
      11-17-2023, 07:25 AM
