cap leg broke off from cap and stuck in through-hole :(
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3266
    • Singapore
    i was trying to desolder ost junk caps at the cpu vrm out area from an asus p4c800-e deluxe board. the problem is that a couple of the ost junk caps came out but without their legs. the legs were stuck in the through-hole of the board. i managed to pull some of them out with pliers on one hand and soldering iron on the other hand but now only one is left.
    this one is too short to grip with pliers. i tried pushing a sewing needle through one side and soldering iron on the other but the leg is just stuck fast inside the through-hole and wont bulge. if i use too much force, the sewing needle just bends sideways because its too thin. its a 0.6mm wide through-hole for mounting 8mm diameter caps. wasted an entire day with it! any ideas?
    • Jul 2011
    • 6070
    Re: cap leg broke off from cap and stuck in through-hole
    Try putting more solder on the joint and try your needle and see if you can push it through
    But when you are trying take out component off of a board you need to be a little bit careful when you wiggle the component not to put much force to it when the solder melts the component will move freely on the one side
    You might need to put more heat to the solder joints when you have a ground plane it will take a lot more heat
    One thing that helps is if you have Desoldiering Gun and a temperature controlled heat gun will help a lot
    • Stunt
      Hp Laptop Stuck on Hp protected by hp sure start screen
      by Stunt
      Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
      I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
      I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
      Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
      screen that's it and stuck there. I left it until the following day and i still...
      09-02-2025, 01:51 PM
    • CG2
      Janome DC3050 Sewing Machine Pedal Resistance
      by CG2
      OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
      Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
      04-14-2023, 07:53 AM
    • stormanimal83
      Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
      by stormanimal83
      Hey....
      Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
      my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
      01-18-2024, 02:15 PM
    • ekozeko333
      [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
      by ekozeko333
      I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
      🔥 The Problem Started After Suspected ESD/PD Fault
      I experienced a power issue or ESD event through a USB-C charger
      After that, the NX20P5090 power switch was visibly burned and was replaced
      Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
      🧠 What I’ve Done So Far
      Flashed...
      06-21-2025, 02:48 AM
    • praveenramavath
      Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
      by praveenramavath
      Hello All,
      I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
      https://www.hifivision.com/threads/m...-screen.98243/
      Troubleshooting Summary: Majority Internet Radio - Flash Chip
      04-26-2025, 09:08 AM
