cap leg broke off from cap and stuck in through-hole :(
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3264
    • Singapore
    i was trying to desolder ost junk caps at the cpu vrm out area from an asus p4c800-e deluxe board. the problem is that a couple of the ost junk caps came out but without their legs. the legs were stuck in the through-hole of the board. i managed to pull some of them out with pliers on one hand and soldering iron on the other hand but now only one is left.
    this one is too short to grip with pliers. i tried pushing a sewing needle through one side and soldering iron on the other but the leg is just stuck fast inside the through-hole and wont bulge. if i use too much force, the sewing needle just bends sideways because its too thin. its a 0.6mm wide through-hole for mounting 8mm diameter caps. wasted an entire day with it! any ideas?
    • Jul 2011
    • 6039
    Re: cap leg broke off from cap and stuck in through-hole
    Try putting more solder on the joint and try your needle and see if you can push it through
    But when you are trying take out component off of a board you need to be a little bit careful when you wiggle the component not to put much force to it when the solder melts the component will move freely on the one side
    You might need to put more heat to the solder joints when you have a ground plane it will take a lot more heat
    One thing that helps is if you have Desoldiering Gun and a temperature controlled heat gun will help a lot
