ESR readings
  • Toasty
    • Jul 2007
    • 4171
    Re: ESR readings
    That's still not sensitive enough. You'd have to divide the last portion of the scale (0 to .2) into 20 marks (.01 ohms each) to see a problem.
    Don't waste another $35. Save your money and get AnaTek's Blue meter.
    Toast
    veritas odium parit
    • lucky13
      • Aug 2007
      • 412
      Re: ESR readings
      Still not fine enough resolution for troubleshooting mobo caps? I see range of 1.0, 0.5, 0.2 and 0.
      • lucky13
        • Aug 2007
        • 412
        Re: ESR readings
        Darn...
        Read feedback:
        "Unit was made in and shipped from China not from Verdun, QC, Canada as stated."
        I'd say pass on this deal.
        • bigbeark
          • Jan 2010
          • 661
          Re: ESR readings
          Well, I bought my ESR meter on Ebay, from a seller in Poland. It is housed in a brown bakelite case, is powered by a 9-volt battery, and is obviously homemade.
          This cost me $60 CAD. I looked at the Blue meter, but it would have cost me about $150
          assembled and I didn't know if I would be interested enough in recapping to make it worthwhile.
          Long story short, I have become a recapping enthusiast, done about 10 motherboards and many soundcards.
          The Polish meter is accurate enough to spot bad caps, but any good cap wil go to a zero reading within a second or so. It detected some bad OST 6.3v 1500uf caps, reading was .20. When I read the caps off-board, the reading was 1 (maximum).
          When used on bare capacitors off-board, it will give readings on new caps very close to the published specs.
          Is the blue meter way more accurate?
          If I were doing this for a living as opposed to a pasttime, I would opt for a better meter.
          • i4004
            • Oct 2006
            • 2029
            Re: ESR readings
            is your meter simillar to the one used in this clip
            http://www.youtube.com/watch?v=VRoBt...layer_embedded
            ? (go to 2'38'' into video)
            such meter obviosuly has one decimal point less of a precision than either esr blue, or this
            http://translate.google.com/translat...tm&sl=ru&tl=en
            which is much cheaper than esr blue and it measures capacitance (costs about 70$)
            esr micro was discussed in this thread
            https://www.badcaps.net/forum/showth...4&page=4&pp=20
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • tvguy12012012120
              by tvguy12012012120
              02-07-2025, 05:13 PM
            • Takeatry
              Yet another Samsung QLED Boot Loop
              by Takeatry
              Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
              10-04-2024, 02:57 PM
              12-31-2023, 06:04 AM
            • flibidy
              Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
              by flibidy
              I have here a Magnum IA.100 which belongs to my parents.
              The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
              Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
              What Ive done........
              01-01-2025, 01:26 PM
