Universal Programmer Recommendation
  • WhiteWolfHellas
    • Jun 2019
    • 95
    • Greece
    Hi, I want to buy a universal programmer for LED TV and PC/laptop repairs.
    I have my sights on the RT809H and the TL866II Plus. Are these two programmers Windows 10 compatible?
    Which one do you recommend? Which one will do for my work?
    What are their pros and cons? Do you have anything better to suggest?
    Share your thoughts.
  • imranromi
    • Jan 2015
    • 1290
    • Pakistan
    Re: Universal Programmer Recommendation
    I recommend RT809H is best for universal use.
      • 31278
      i reccomend dumping windows10
      • diif
        • Feb 2014
        • 6978
        • England
        Another for the RT809H here. Yes it's supported by Windows 7,8 and 10.
        • WhiteWolfHellas
          • Jun 2019
          • 95
          • Greece
          So far the winner is the RT809H. Is it future proof for TV repair? What are the most used adaptors for TV repair?
          • diif
            • Feb 2014
            • 6978
            • England
            If you want to tell me the types of memory they will use in the future I'll tell you if it's compatible.
            The majority of flash and eeproms on TVs are SOIC 8 pin.
            I've encountered BGA 63 and 169 and TSOP48 although the last time I checked it wasn't able to correctly program the Samsung Nand in the D5520s correctly, I don't know if this is still the case.
            • WhiteWolfHellas
              • Jun 2019
              • 95
              • Greece
              I read a comment on YouTube saying that the RT809H can't read or write nands correctly. I don't know because I haven't used a programmer for anything else other than 8pin chips.
              • diif
                • Feb 2014
                • 6978
                • England
                It's just the K9GAG08UOE I know it struggled with, I bought a GQ-5X for those.
                • WhiteWolfHellas
                  • Jun 2019
                  • 95
                  • Greece
                  So the RT809H is not going to work with Samsung Nand flash? That's why I started this thread, I wanted to know about a programmer that does the job right. So better off buying the GQ-5X?
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    The GQ-5X just does tsop 48 nand. I also have the Rt809h for most other programming as well as a Svod programmer for laptops.
                    • WhiteWolfHellas
                      • Jun 2019
                      • 95
                      • Greece
                      Does the RT809H read/write chips onboard or do they need to be removed first?
                      Is there a programmer that does that?
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        It depends on what is being programmed but most need to be removed.
                        • WhiteWolfHellas
                          • Jun 2019
                          • 95
                          • Greece
                          Most common ones are the 25Q64/32, does the RT809H program these onboard?
                          Can Nand chips in general be read/written without being removed?
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            It's not what it's programming but there are usually resistors and capacitors that interfere with reading and writing.
                            Nand is off board.
                            • nsab6464
                              • Jun 2019
                              • 6
                              So I tried a thing today...
                              I designed and 3D-printed a little eeprom chip reader and hooked it up to the SPI pins on a Raspberry PI. And... it works! Both onboard (with an external 3.3v PSU) and offboard. Best part is - it supports a huge number of chips (uses the Linux flashrom util), and you can look at the bit-banging live with Piscope. All for $0!
                              Here are my schematics, for anyone who wants to repeat my little experiment.
                              • CapLeaker
                                Leaking Member
                                • Dec 2014
                                • 8351
                                It depends on what you want to do. I have both, since one can do something the other can't and the same thing other wise around. If you want to play with EMMC's than the RT809H is your pick. If you want to program some GAL's then the TL866 is your pick. I needed both, so I have both.
                                • Mbw1a
                                  • Nov 2018
                                  • 29
                                  • Europa
                                  are thinking of buying a RT809h. does anyone know any good seller?
                                  Found this:
                                  https://www.hklrf.com/RT809H-51-Adapter_3647.html
                                  But don't know if this is a trusted site?
                                  • dicky96
                                    Sun Seeker
                                    • Mar 2017
                                    • 1825
                                    • Spain
                                    I have a TL866A myself. I bought that one as it can program old 22V eproms and it was no longer in production so I thought 'get one while I can'. If I need a programmer to handle low voltage 1.8v chips in future I sure I can easily buy one. I doubt there is any such thing as a universal programmer but so far the TL866A has programmed any device I wanted to program.
                                    Follow me on YouTube
                                    Learn Electronics Repair
                                    • Mbw1a
                                      • Nov 2018
                                      • 29
                                      • Europa
                                      What is the difference between RT809H and RT809F ?
                                      • luis.kiss
                                        • Oct 2014
                                        • SP
                                        Thanks for the file.
                                        • Teeheeze
                                          RT809H Programmer Firmware Corrupted
                                          by Teeheeze
                                          This is a shot in the dark, but I was just using my RT809H programmer and it got stuck in a certain state so I power cycled it. Now, the device LED just flashes quickly and does not connect to the software. I've tried to update the BIOS of it and it fails. I went so far as to remove the ROM from the programmer itself but it's some weird chip (I believe ATMEL, but I can't find any datasheet on it) so I've been unable to read the BIN from it w/ my other programmer. Chip has ATMLHC4C56BM CN written on it (I think). I'll upload an image. I have the programmer's BIN ready to program it manually. Anyone...
                                          02-13-2025, 04:51 PM
                                        • Aurora256
                                          T48 TL866II Plus High speed Universal Programmer
                                          by Aurora256
                                          Hi everyone, does anyone use this programmer "T48 TL866II Plus High speed Universal Programmer"?
                                          I am planning to buy a programmer for my Dell Precision 7710 to re-flash the bios....
                                          03-14-2024, 04:03 AM
                                        • sassan
                                          The new xgecu T76 vs rt809h programmer
                                          by sassan
                                          hello,
                                          i want to buy a new programmer mainly for use for laptops bios chips and i'm between the Xgecu T76 and the famous RT809H.
                                          i think that T76 is faster wich makes it the best choice for using Pogo pins,i asked the support if it supports Mec ships found on some Lenovo laptops i didn't get an answer yet.
                                          i would like some ideas and which one do you recommend?...
                                          03-06-2025, 05:36 AM
                                        • bembeno
                                          aquestion about RT809h programmer
                                          by bembeno
                                          dose RT809h programmer support the new Bios chips like 25q256jveq because i have minipro TL866 and icant programming these ics and if anyone can tell me about a cheaper programmer wich do the same job to buy it
                                          03-04-2023, 02:39 PM
                                        • mferna14
                                          RT809H Universal Programmer
                                          by mferna14
                                          Hi, does anyone in this world has the LATEST ENGLISH version Software of RT809H Universal Programmer. I download S/W from its site but my Windows 10 always gives message of Virus threats (Trojan) & then disable this software. Please help with a Latest Clean ENGLISH Version, I would appreciate. Thank you
                                          05-15-2020, 02:41 PM
