Angled multimeter probes
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    Good day folks. Here's something which I'd find incredibly handy but can't seem to find for the life of me: multimeter probes which have their tips bent pretty close to 90 degrees to allow for easier working under a magnifier. Louis Rossmann seems to have these but I can't tell what they are or if they're actually something homebrew. Maybe there's some really fancy technical term for them that I don't know and that's why I haven't been able to find any, so perhaps someone can set me straight on that.
    I was actually thinking of making my own: I have some probe handles (just the plastic+wire part) which came with an assortment of tips and connectors and these screw onto the end of the plastic handles which take a standard M3 thread. I was thinking of fashioning some tips out of something like paper clips or other thin yet stiff metal which can be bent rather easily but actually retains its shape afterwards. It'd then be relatively easy to terminate these with a lug through which I'd pass a short M3 bolt to attach to the end of the plastic part. I'd then sharpen the tips up a bit and there's that. Trouble is I'm not sure if they'd actually STAY sharp overtime, as paper clips are relatively flimsy metal...that's one thing I've noticed with most of my tips: they dull rather quickly, but that could be normal and I'm expecting too much of them, so I occasionally have to take them to a piece of sandpaper or even a grinding stone to get them looking decent again. Any thoughts ? Cheers.
    Wattevah...
    • 31196
    Re: Angled multimeter probes
    rossman is using tip extensions you find on ali-express - he bent them himself.
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      I have those too. Those caps that slip over the end of the probes. The reason I haven't tried bending them is because my dad believed they'd snap when doing so, since they're made of steel and would have to be heated up first. I think I'll go for it - YOLO
      Wattevah...
        • 31196
        steel bends, brass does not.
        spring-steel also does not.
        but heat is a good idea - if it wont melt the plastic
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          Went ahead and tried it, mostly on a whim upon getting out of bed today Grabbed it with a pair of pliers and in about 5 seconds I got what I wanted So it can be done. Cheers.
          Wattevah...
          • megaraider
            • Jul 2015
            • 307
            • Portugal
              • 31196
              rossmann is now using these - gotta get a pair!
              https://www.aliexpress.com/item/Prac...848907433.html
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                Have them - 3 sets in fact
                Wattevah...
                • megaraider
                  • Jul 2015
                  • 307
                  • Portugal
                  wfh good catch, was using my own custom made ones using very thin syringe needles.
                  Got to buy!
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    My super pros at work also struggle with all sorts of ghetto solutions like that instead of getting proper stuff...their probes are like 10 years old, patched and taped over and over again...never have I seen so much ignorance in once place as in this joint >_>
                    Wattevah...
                    • ca2014mp2
                      • May 2016
                      • 48
                      • usa
                      I like these :
                      https://www.ebay.com/itm/2x-Car-Mult...UAAOSw4~1cc0B7
                      Easy to bend at 90 for 3 mm or so.
                      • corrize
                        Small and robust multimeter probes
                        by corrize
                        Hello, I search a new probes for measuring pin of qfn and other very small stuffs. I bought the AE basics ones, but they are no longer sharp. Metal is bad. Do you have a stonger ones ?
                        05-13-2023, 02:36 PM
                      • estabilito
                        Tips geting oxidized when using wick
                        by estabilito
                        Hi, i have weird problem - when i'm using soldering wick to clean BGA balls under CPU or PCH on motherboard my tips(different types) getting oxidized very fast and lost all power.
                        i Was trying different types of wick, flux - no difference. I can't even clean one full socket and i need to use deoxidizer in half-time.
                        Temperature: 350-365celsius
                        station: jbc cd-2bqe
                        Wick: edsyn
                        flux: warton hf rework jelly
                        Do you have any tips?...
                        04-12-2025, 11:55 AM
                      • trex66
                        Craftsman 82345 Multimeter broke!
                        by trex66
                        My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
                        03-04-2025, 04:26 PM
                      • Sofian75
                        Things not to do with a multimeter?
                        by Sofian75
                        I started to learn laptop repair a few weeks ago, since then I ve ordered several dead laptops to try to fix them and learn.
                        I fixed some of them and some I ve made things worse by blowing components.
                        Every time while taking measurements with my multimeter.
                        Yesterday I was working on a dell laptop motherboard, I was checking the charge IC for short in diode mode and it killed the chip.
                        So my question is are there things I should not do with my multimeter?
                        Or measurements I should do only with the charger and battery unplugged?...
                        06-27-2024, 05:13 AM
                      • max_smart
                        T430 laptop doesn't power on- please help me troubleshoot w/multimeter (fixing for fun)
                        by max_smart
                        First off, this forum really helped me out by advising me to cut some ribbon connectors to the LCD panel in order to fix a 70" TV (lots of threads on Sharp TVs with this issue). I didn't believe that it could work, but it did.
                        Now I've been encouraged to try to diagnose something quite a bit more complicated. That is an old T430 motherboard. I work on a college campus so I have access to pretty decent tools. I found the schematic for the motherboard on the site, and have been following traces and taking DC measurements from things. I also don't mind...
                        06-01-2024, 03:27 PM
