how to solder NEC TOKIN IC 0E907 ( conductive glue ???)
  • lepak06
    • Feb 2017
    • 51
    • france
    Hello
    I need to remplace NEC TOKIN 0E907 for acer laptop but i can t use the airflow gun because the nec tokin ic burnt. And for low temperature <220° the solder paste don't heat. it's low
    I seen we can remplace it with 4 x 330uF smd but i want remplace it with original ic.
    Can i use conductive glue (which product) or an other solution?
    Thx
    • 31068
    Re: how to solder NEC TOKIN IC 0E907 ( conductive glue ???)
    you need a real reflow station - and then it can fail again.
    use the 330uf polymers.
    • lepak06
      • Feb 2017
      • 51
      • france
      sorry i ve an Digital Hot air Station and not airflow gun that i wrote.
      I feel that the tokin was glued and not soldered because I can tear it off the motherboard
      i tried with 330uf the laptop is good working but i want a clean working for client
      thx
        • 31068
        well most laptops use the 330uf caps, the tokin caps are a failure and kill a lot of PS3's too.
        • megaraider
          • Jul 2015
          • 307
          • Portugal
          Originally posted by lepak06
          (...) but i want a clean working for client
          That's an epoxy glue type (probably black color).
          I always remove it by scratching and peeling it off. Then use a solvent to remove any smaller lefties.
          • petehall347
            • Jan 2015
            • 4427
            seems the recommended repair is an upgrade .. i dont think the customer wants to look at that bit .
              • 31068
              most repairs are an upgrade, because you dont want the blame for it failing again.
              that's why we dont replace shit caps with more "chong-x" or whatever, but spend the extra on panasonic or use polymers.
              a good repair is a repair you only do once!
              • promo7uk
                • Aug 2014
                • 31
                • uk
                PMSFL.!! TOO TRUE, cheap china caps always fail.
                  master hoarder
                  • May 2008
                  • 12175
                  Exactly!!!
                  Skip the NEC TOKIN caps and use something else - SMD polymers, tantalums, ceramics... whatever. just NOT those NEC TOKIN c[r]aps.
                  The customer will likely never look inside the unit and hence never complain, as long as the unit is working. And if they do, you can always tell them why you didn't use original replacements.
                  As stj mentioned, many PlayStation 3 consoles and also a few older Toshiba laptops were affected from these failing NEC TOKIN caps.
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    I've done dozens of these. Always 4x330uF on Toshiba. Only on Acer 6930G/8930G I do 4x 470uF or 6x 330uF because 4x330uF is not always stable.
                    A working TV? How boring!
                    • mitsu2k
                      The Real Dangers of conductive glue.
                      by mitsu2k
                      I know many folks on this forum warn against conductive glue and suggest removing it immediately upon site. I'm here to vouch and say these people know what they are talking about. To be more accurate, the glue isn't intended to be and doesn't actually start out conductive. It gets conductive as it is heated by components that get hot. The glue starts out to be a light tan color but as it is exposed to heat, it gets darker and darker until it is a dark brown. I have found that it becomes conductive at the point that it reaches a light brown color on darker.
                      Here is an experience I...
                      04-16-2023, 06:29 PM
                    • acedogblast
                      by acedogblast
                      11-02-2024, 05:13 PM
                    • Chaks
                      NEC TOKIN 0E907 Fault in Toshiba L510 Laptop - Can I use any of these caps
                      by Chaks
                      My old Toshiba L510 Laptop which was working fine with Ubuntu 22 Server till couple of days back. But suddenly I got a blank screen with fan spinning and no HDD activity. I tried all options and zeroed to a suspected/faulty NEC TOKIN.
                      So I removed the faulty NEC TOKIN 0E907 and want to know if I can use the capacitors I have salvaged from old Motherboard. These caps are from old Mackbook Pro Motherboard and I am not sure if any of these caps will work.
                      Can anyone please guide me....
                      09-12-2024, 12:06 PM
                    • corrize
                      Best way to solder LVDS connector for beginner (and qfn) ?
                      by corrize
                      Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                      I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                      I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                      See the test :
                      https://youtu.be/bNAzC-EvqHs?t=1767
                      With hot air from bellow the board, that's...
                      03-09-2023, 02:57 AM
                    • petemanuk
                      BGA solder balls not connecting - help pls
                      by petemanuk
                      So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                      I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                      I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                      11-16-2022, 05:21 AM
