How to remove this ribbon cable?
  • tmho
    • Jun 2016
    • 39
    I am trying to take out a PCB from a receiver (Onkyo tx-sr606) to replace a defective capacitor. But I need to remove a ribbon cable which is connected to it. I do not have experience in such connector. That connector should not be the "pressing down and pull out the cable". I am not sure how to remove it and I do not want to damage it. Therefore, I would be glad if someone can tell me the correct way to remove the ribbon cable from the connector.
    • 31017
    Re: How to remove this ribbon cable?
    press the top down and pull the wire out while doing it.
    • tmho
      • Jun 2016
      • 39
      I followed your method and successfully removed the cable from the connector. Thank you very much.
      • Curious.George
        • Nov 2011
        • 2305
        • Unknown
        When you go to reintroduce the cable to the connector, make sure the "wires" are straight and in-line (and don't get bent before or WHILE inserting)
        • redwire
          • 3910
          I always make sure there's no latch that has to be released to get the wires in.
          • Curious.George
            • Nov 2011
            • 2305
            • Unknown
            Usually, any latching (clamping) mechanism was discovered when you removed the cable in the first place.
            Though, often, folks fail the "common sense" test ("If I had to do something to remove the cable, shouldn't I also have to do something to reinsert it?")
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • Tr0ll
              by Tr0ll
              Original T-con:
              First replacement T-con:
              10-07-2023, 07:48 PM
            • scubacamper
              Sharp Aquos LC-70C6400U Half Screen Dark
              by scubacamper
              I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
              Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
              when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
              05-03-2025, 12:19 PM
            • Acnologia
              Lenovo Thinkpad E15 Gen 2 NM-D011 - No display ? External , yes!
              by Acnologia
              Here is a pretty crazy one.
              Step 1.
              Laptop was brought to me as dead not working. Removed everything , cleared everything.
              Step 2.
              Some liquid damage close to the Type - C connector, and the connector even though it was cleaned wasn't charging the battery . Removed the Type-C port, and replaced it. Now the laptop turns on and charges battery. Shows external screen , not internal.
              Step 3.
              Took out the screen and checked it to a secondary Gen 2 i have, screen works like a charm.
              Step 4.
              Lets ,dive into the board. I see the edp cable on the...
              05-07-2025, 07:16 AM
            • sarroura
              Help Unowhy Y13 Remove battery connector
              by sarroura
              Unowhy Y13 . I have to unplug the battery connector before flashing the bios. But I can't remove this connector and I pulled hard but it doesn't disconnect. I'm afraid to break it. Is there a special way to remove it? THANKS
              08-29-2023, 03:33 AM
