Re: Soldering station thoughts and guidelines
Let us know what happens with case
It will be a cold day in hell when I let eBay get away with charging me "a few percent" because they let an illegitimate seller scam buyers on their website. That's not going to happen.Leave a comment:
Paypal charges for giving refunds, so you still lose a few percent.Leave a comment:
A soldering iron tip or workbench that has stray voltage, it will damage parts.
Callbacks after about 2 weeks... I found shorted gates on mosfets and cmos IC's after 2 weeks consistently. It seems an IC gets damaged a little then dies. Other techs had the same problem. I grounded stuff and was the only tech not getting call backs.
Find an earth ground in the building.
It could be the steel frame I-beams or metal siding, sinks/water supply or drain lines, heating system piping/ducts, metal conduit for wiring etc. Worst case is looking at neutral but the electrical panel should have the earth ground connection to neutral.
You have to find one thing you know is ground. Then take a multimeter and very long wires and compare ACV and ohms to see what you have.
I find pulling Y-caps can make it worse because the SMPS transformer has stray capacitance, so no Y-cap and you get more common-mode noise on the 24V side. If other stuff is plugged in (to dirty ground) it does not help.
There's a few different T12 24V power supplies. Some have Y-cap from PE to DC(-), others from HV DC to DC (-).Leave a comment:
You mean the cap going between HOT GND and COLD GND ?
There's also two blue Y caps going between L/N and the earth prong on the IEC connector itself - should THESE be of concern as well ? I always thought caps pass AC and block DC (at a very crude level), so I've always wondered how such a setup doesn't result in a short L to N, despite this configuration being used just about everywhere.
No pipes around sadly, but the metal workbench is contacting the cement floor, so ILeave a comment:
Well duh, eBay getting wiser, faster...they said "We're writing to let you know that we've removed an item you recently won due to concerns with the seller's account:
183837069653 - Professional 3in1 Soldering Iron Hot Air Gun SMD Power Supply Solder Kit Station. Since you've already paid for the item, you don't need to do anything else. If your item hasn't arrived yet, it should arrive soon. If it doesn't, then you'll want to open a case in our Resolution Center."Leave a comment:
Just noticed my KSGER T12 station likes to zap me if I touch anything conductive on the board while also touching the tip to it - there's some leakage on the tip apparently. I imagine this could cause problems in some components, since it completes the circuit from the tip, through the board, through whatever components it feels like, through my body and back down to earth. The main reason for this is the lack of an earth in my building, so the earth prong on the IEC 13 connector on the back, although present, is floating. I was thinking of adding my own grounding banana jack and connect that to my workbench or something to dissipate that away from the board... The 858D I've got actually has this ground post on the back, so that's where I got the idea.
either remove the ceramic caps in the psu to isolate the secondary,
or run a ground from your desk to the basement water/gas pipes.
right now, the earth wire has the combined voltage/current from every switching psu connected to it + the capacitive coupling of the cable run itself.
and it has nowhere to go other than back into the users!!!Last edited by stj; 06-08-2019, 08:56 AM.Leave a comment:
One give away is that they have not been on EBay for very long no negative or neutral feedback to me this is a giveaway that it is probably a phony seller
I also see with this seller is that there has been some items sold but the ( supposedly ) buyers only have a few feedback themselves sometimes to me this is a red flag as well
If this is real it could be that these units for sale are nock offs or rejected items for some reason or anotherLast edited by sam_sam_sam; 06-08-2019, 05:20 AM.Leave a comment:
Just noticed my KSGER T12 station likes to zap me if I touch anything conductive on the board while also touching the tip to it - there's some leakage on the tip apparently. I imagine this could cause problems in some components, since it completes the circuit from the tip, through the board, through whatever components it feels like, through my body and back down to earth. The main reason for this is the lack of an earth in my building, so the earth prong on the IEC 13 connector on the back, although present, is floating. I was thinking of adding my own grounding banana jack and connect that to my workbench or something to dissipate that away from the board... The 858D I've got actually has this ground post on the back, so that's where I got the idea.Leave a comment:
Too expensive! $5 for a rework station and multimeter test leads. I can get a burger for that much money...
Last time I bit the hook for a $5 multimeter worth $25, I got a fake china tracking number.
Had to phone eBay and they gave a refund under their money back guarantee only after the arrival deadline. The seller had vanished.
Seems to be sellers scamming eBay, they have maybe 100 feedback. Or maybe bots are doing this.Leave a comment:
HALF PRICE SALE......US SHIPPER....LOL
https://www.ebay.com/itm/183837069653
ETA JUNE 14, 2019
yes, I knowLast edited by captainKKK; 06-07-2019, 08:28 PM.Leave a comment:
C tips are just cross-cut, they have no recesses to hold solder.
the beveled tip is BCM3, i think i have one in my collection.Leave a comment:
I call that C4 in the picture of the T12 assortment a "bevel" tip and the ones you linked to "screwdriver" tips....which Hakko calls "bevel" tips, so I don't know which is whichLeave a comment:
there are no bevel tips in that image.
http://www.hakko.com/english/tip_sel...eries_t12.htmlLeave a comment:
I think it's a C4, which is perfectly adequate for THT and even SMDs which are on the large side. I didn't get it especially for this - it came in a pack of several tips I ordered a while back just for the JL02 one and my JL02 had finally succumbed to the abuse I had given it, so I decided to try something fatter so it would last longerIt's also not a T12 - it's a Hakko, sleeve-type tip, but essentially the same thing.
Yes, I know it's a scammer but I cannot get hurt, so what the hey? I'm not saying another word about this until it's done. I will report the results.Leave a comment:
pretty sure Epacket is just small stuff like jiffybags.
for big boxes they would probably use china-post or EMS.Leave a comment:
I have had this same email today with a different tracking number though like i say im not bothered if it does not arrive as will get the cash back either way.Leave a comment:
That indicated it's not been shipped. The tracking number isn't recognised.
They have filled their store out in the last couple of days and having a quick look at numbers sold, have pulled in 3-4 grand already.Leave a comment:
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by chth96hello.
A few months ago,I have purchased 0.1mm Soldering Iron Tip of below aliexpress link,But I noticed that It is totally impossible to use this 0.1mm iron tip in the T12 soldering station
https://ko.aliexpress.com/item/4001275635593.html
Is there any good soldering station which is possible to use 900M-TJ-I tip and have inexpensive or reasonable price in aliexpress?
Any reply would be appreciated. -
by mkbehbehI purchased this soldering station when it was on sale at amazon. It had a slew of one star reviews, but the price was low enough that even if the controller and PSU were toast, the handle tips and stand were worth more than the price. All of the reviews mentioned that the unit was either DOA, or died on the first use. I looked on Aliexpress and the first clue was that KSGER still sold the 220V version of this station, but all of the 110V versions had been discontinued. I figured That there was a problem with the 110V on the power suppply and the controller would be fine.
I am... -
by Peter_1402Hi Everyone,
I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
1. Soldering iron works great
2. There is a burnt mark on the hot air gun handle.
I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
Reed switch tested ok with a magnet.
From the above test, I can conclude... -
by deep000Hi,
I'm looking to get on Aliexpress a hot air soldering station for hobby use, nothing too fancy, just something "reliable" and budget-friendly.
Any recommendations for a "good" cheap one that gets the job done?
Thanks in advance - Loading...
