advice for new toy *ahem* tool HP1220A oscilloscope
  • NTkiller7000
    • Dec 2015
    • 44
    Hi folks, I just picked up an oscilloscope on the cheap, a HP 1220A. Guy advertised it as dead ("Won't power on") and I took a chance. Got it out of the box, and plugged it in. Mind you, I've never personally messed with a scope before, so I had no idea on how to operate it. Turned it on, and nothing. I then popped the cover for a look, and it was really clean inside, with no obvious damage. turned it back on, and I saw the CRT cathode light up. "This thing can't be dead" I said to myself, so time to RTFM! OK, Online manual says set up scope as shown in picture and turn on, but the picture is unreadable (craptastic scanners!). Anyway, I ended up using some educated guessing to set up the scope, turned it on, and pressed the beam finder button. Huzzah, it worked! I guess the guy responsible for testing the scope didn't know how to run it either. After putting the lid back on, I proceeded to send a signal to it for testing, using a multimeter lead in between one input and the scope's test point on the front. Got a nice square wave going on the face after playing with some settings. I'm currently waiting for a pair of probes to show up in the mail. Is there anything I need to be aware of about this scope? I'm going to use it for working on a CRT TV motherboard, so no digital signals to speak of. How come when I feed it a square wave it doesn't draw the lined between the crest and trough of each wave? And does anyone know where I can find a high quality scan of the manual? Thanks!
    Just trying to make these stupid electrons behave!
    ...Not having too much success, they keep flying around those atom thingy-majiggers...
    • 31196
    Re: advice for new toy *ahem* tool HP1220A oscilloscope
    consider a x100 probe for tv work, the x10 probes usually arent rated over 300v
    • R_J
      • Jun 2012
      • 9588
      You might want to find an isolation transformer also, a lot of crt chassis are hot, not isolated from the a/c line
      • NTkiller7000
        • Dec 2015
        • 44
        I picked up tp6100 probes off ebay, hopefully they'll be good enough for what I want. I'm not going to be poking around high voltage, so it should be fine. An isolation transformer should not be necessary for this particular TV, since it has proper line isolation on the board.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Sometimes the rise/fall slopes don't show up very well when the signal's edge rate is extremely fast. If you bump up the horizontal sweep (or, namely, reduce time per division on "modern" 'scopes) you should get to a point where you should be able to see the up/down edges, unless that edge transition rate far far exceeds the bandwidth of the 'scope.
          • NTkiller7000
            • Dec 2015
            • 44
            I set the time division to where the scope showed 2 waves on the screen, and the only way to see the edges was to turn intensity WAY up (don't do this for more than a split second, screen burn hazard!) when connected to the 2KHz square wave reference on the front of the scope. Maybe the transitions are too fast for the scope to pick up, or it's the fact I'm not using a proper scope probe (waiting for the probes to show up in the mail)
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              Actually an improper probe will slow down or otherwise distort the slope, making it more likely to be seen. It's more of the former. But you shouldn't be concerned about it, you can fill in the blank in your head.
              Also don't worry about seeing the full wave if that's not what you want to see, likely it's near the transitions that's the "interesting" stuff and if you just show the transition, it can show more of what you need.
              • NTkiller7000
                • Dec 2015
                • 44
                Gotta dumb question: can I turn down the cathode heater to prolong the CRT life? I remember when I had the cover off, I saw the cathode was getting orange hot. Is that too hot, or normal? The reason I'm asking is I've never seen a CRT TV or monitor get their cathodes as hot as this thing does.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  All vacuum tubes should somewhat glow when heated, even VFDs. So it's normal it's orange. It should NOT be white however, but it's hard to gauge what is normal for a particular tube as different tubes have different amounts of the filament exposed, and have different normal operating temperatures.
                  Usually you can't change the voltage without affecting the secondary anode voltage anyway, as both tend to use the same transformer. A resistor in series may work.
                  Actually, heater failure is the least of your concern. Gas diffusion from a leak and cathode emulsion loss can't really be helped are the 'wear' that happens to CRTs over time, other than phosphor burn. As you said earlier, keep the intensity reasonable. Turn the 'scope off at nights, weekends, long periods of disuse, etc., and it will last a long, long time. I have several old CRT oscilloscopes and they still work just fine.
                  • repair-it
                    Need advice testing a samsung power supply board with scope
                    by repair-it
                    I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                    07-12-2025, 11:00 AM
                  • rex98
                    HP DMI Tool
                    by rex98
                    HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
                    DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
                    The DMI Tool given here are for personal use only.
                    DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
                    You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
                    from it, and that you please credit the author...
                    07-02-2025, 05:51 AM
                  • salim5566
                    loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                    by salim5566
                    Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                    06-26-2025, 03:25 PM
                  • Tarot Superstars
                    How not to Damage an Oscilloscope
                    by Tarot Superstars
                    Hello.
                    I have jut got my first analogue oscilloscope. An Isotech 620 20MHz.
                    I want to learn how not to damage it, and I found instructions on the internet obscure.
                    They talk about ground, earth, floating ground, this, that....
                    But they don't actually say anything anything useful so far.
                    I want to know:
                    Don't connect exactly this to exactly there or it blows up.
                    For example, I am tracing a signal from a function generator in an audio amp, or testing for voltages in different parts of a circuit.
                    I want to know what not to connect...
                    08-29-2023, 02:27 PM
                  • abajor
                    A3401 Gatorade Spill Best next steps
                    by abajor
                    I had a customer call me with an M4 A3401 her daughter spilled a gatorade into, and didn't tell her mom for about 2 hours.
                    I had her bring it in immediately so we could disconnect the battery and I could dismantle it so I could swab the board with Isopropyl an dry with a heat gun.
                    There was already some green copper corrosion when I opened it.
                    I did a good first pass and dried off the board, now I'm going over it with my scope swabbing and poking at any oxides with my exacto tip.
                    I brought out my hot air tool to evaporate the iso and caramelized sugars started bubbling...
                    02-16-2025, 08:01 PM
