First QFN removal with budget solder Huakko station 998D
  • jondoe
    • Nov 2016
    • 547
    After lots of swearing and practice on scrap boards I've finally managed to remove a QFN IC using my budget Huakko 998D soldering station, without completely destroying it.
    I had to crank the temp up to 420 °C, much higher than expected, but she did eventually come free. Judging by the close up attached picture I've slightly lifted one trace in the process and moved a couple of SMD's a little, but I think I could actually use this board again
    Practice makes perfect as they say
  • diif
    • Feb 2014
    • 6978
    • England
    Re: First QFN removal with budget solder Huakko station 998D
    Nice job, minimal work required to get those moved components back in place.
    I recommend Amtech 559 flux, allows for plenty of reworking before it goes off. Be careful on ebay, there's loads of fakes. Insatint is the genuine seller.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      speaking of removing SMD components, did you use square attachments or just used a regular circular nozzle?
      The best luck I've had in desoldering board is using a heat gun, but it tends to rip off more than just the target device and destroys plastic connectors ...
      • jondoe
        • Nov 2016
        • 547
        I had some very thin watery flux, it wasn't much use. Thanks for the suggestions, I'll be getting some of that tacky Amtech stuff.
        I used the smallest nozzle in the kit, bog standard kinda thing, quite low air speed (setting 2 of 8), spent plenty of time bringing the board up to temp.
        Kapton tape on your plastic connectors should protect them from the worst of the heat.
        • diif
          • Feb 2014
          • 6978
          • England
          I wouldn't worry about warming the board when doing SMD rework. It's only when doing large BGA work does it matter, far more heat needs to be put into a much larger area.
          Nozzle up close, little waft for a few seconds and watch as the solder changes through the microscope.
          When you say heat gun eccerr0r, do you mean paint stripping gun ?
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            Yes, and yes it has an extremely high chance of destroying the board...
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              BTW, fake rosin...what do you actually get? Is it not so great rosin or something that looks like rosin that doesn't even work like rosin?
              • diif
                • Feb 2014
                • 6978
                • England
                What's fake rosin ? Amtech 559 is rosin based tacky flux that lasts flipping ages when reworking. There's a reason it's more expensive than normal flux.
                Comes in a syringe and I stick a needle on it. Super easy to administer.
                Being tacky it holds pieces in place. Used for BGA reworking and normal rework.
                MG Chemicals also make a tacky flux, some say it lasts longer than 559 but I've no reason to change.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  I'm sure someone has gotten fake rosin/flux from china. I just wanted to know what the characteristics are like... is it so bad that it doesn't work, or is does it work but poorly?
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    Nice work jondoe!
                    Don't be afraid to crank the heat up. Hot air doesn't work exactly like a soldering iron, so you need hotter temperatures and longer exposure.
                    If you have a small bottom heater, though, you can often make your work a lot easier. I typically use the gas burner on my stove set on low. It actually does a perfect job of even heating on the bottom where I want to work.
                    Just keep this in mind if you have to remove bigger stuff with hot air.
                    One word: Kingbo
                    Apparently it's a cheap Chinese paste flux that varies in quality depending on where you get it from. It's also not regular rosin, but RMA (Rosin Mildly Activated). I think most re-work fluxes are RMA anyways, though.
                    In any case, I've tried several different Kingbo fluxes, and even the worst ones are not that bad. They just smell worse and smoke more. But they work.
                    As for Amtech fakes - there's a lot more variation. Apparently I have a small leftover in a syringe (picked up from the trash of a repair shop back in 2012), and it's fake, but it's not that bad. However, I have seen first hand how bad some of the fake Amtech fluxes can be - they literally leave a burned crust all over the board that is impossible to clean. They also dry out and crust way before reaching proper reflow temperatures. But mine seems okay for the most part. I use it for regular iron soldering sometimes and have no problems with that.
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      Does Rosin Mildly Activated need a Return Material Authorization?
                      Interesting. I did get some cheap china crap and ...well... I think it's crap or at least it doesn't seem to work very well at all. It's orange colored, waxy soft at room temperature. It easily melts but does not appear to "work" at least compared to the solder wire core rosin like Kester 44, etc. It smells like rosin, and does not crust over when heated. It returns to a waxy state if it gets to cool back down before it all gets vaporized.
                      Again I don't know if I'm expecting too much or not. Even Kester 44 rosin, if it cools back down, it becomes brown and crusty, but will readily remelt and reactivate when reflowed.
                        • 31044
                        there was a vid on utube - it may have been marcoreps, testing some "flux"
                        the conclusion was some of it could make a good soldermask!!!
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          Lol
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            • Romania
                            The orange stuff is garbage. Kingbo is alright, but the quality control leaves to be desired - you never know what's gonna be in your next can. It also makes a lot of smoke. But it's still 10x better than the orange stuff so if you're looking for cheap flux, Kingbo is the way to go.
                            For quality, another vote for Amtech NC559 here.
                            A working TV? How boring!
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              Yes, I think I remember seeing a video like that before.
                              Also, regular liquid rosin flux not meant for rework or lead-free solder can also do the same - it hardens up and then makes it impossible to solder on top of it until you chip it away. I have some MG Chemicals regular rosin flux like that. It's wonderful for leaded and lead-free through hole soldering and smells nice too. But for BGA or SMD work - pretty bad!
                              Well, now that my jar of Kingbo is nearly 6 or so years old, it has changed its color from "pasty white" to "dark-piss" yellow over the years. And it smokes a ton more than before. But it still works, lol. I just don't use it for BGA work anymore because it fogs up the whole house (And I pretty much have stopped doing BGA work anymore).
                              • clearchris
                                • Dec 2013
                                • 687
                                I'm quite happy with my kingbo flux. Fluxes great, yeah, lots of fumes, don't breathe it. Clean-up requires brake cleaner, I haven't found anything else that will dissolve it. Mine has also turned dark, but I stick my iron in the paste all the time, it would look a lot nicer if I didn't do that.
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  Any ideas what the kingbo stuff is made of? Not rosin, at least it doesn't look it? That "100g" jar looks huge...wonder what's a reasonable amount at a good price/quantity ratio.
                                  I need to get some better flux sometime. I got some acid flux which is no good for electronics, but I figure I have other stuff to solder and that's for that.
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    • Bulgaria
                                    I have no problems cleaning it up with IPA / rubbing alcohol.
                                    I would NOT suggest using break cleaner at all. I don't remember what chemical most brake cleaners had, but it will dissolve aluminum and sometimes other metals too - definitely something you shouldn't use on a motherboard or anything with electronic contacts. Even Acetone can be damaging - but that's mostly for the plastics. I only use Acetone for the most stubborn cleanups I have to do. And even then, I always clean up any leftover residue with IPA.
                                    Yes, I think heat is the reason Kingbo flux turns yellow over time. A fellow technicial told me if you keep it in the fridge, it won't do that as quickly. But I am doubtful and I also can't be bothered to walk to the fridge every time I need flux, lol.
                                    As for sticking your iron in the flux jar... doesn't that damage your tip's coating? If I use too much flux, I find my copper tips get eaten up fast and my steel-plated brass tips (mostly T12/T15) get gunked up and solder won't stick to them anymore. So I tend to use my flux sparingly and also NEVER apply it on any of the tips.
                                    • clearchris
                                      • Dec 2013
                                      • 687
                                      My kingbo flux laughs at 98% rubbing alcohol. Also tried everclear, no love. Haven't tried acetone because it does dissolve a lot of plastic.
                                      I have a real Hakko chisel tip, and no problem dipping it in flux. I dip it into the flux, clean with brass scrub pad, and it comes out perfectly tinned. I did have some aftermarket tips, and they were terrible. Couldn't transmit heat at all. So I haven't a clue how they perform dipped in flux, etc.
                                      I have been tempted to get a T15 setup, but my experience with non-hakko tips has kept me away.
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        • Bulgaria
                                        T12/T15 tips are awesome! Or any other tip with built-in heating element and sensor for that matter (only mentioning this because I don't know what JBC calls theirs).
                                        If you are using Hakko 900M tips, you'll never go back to them after going with T12. Granted genuine Hakko 900M tips are probably fine. But the aftermarket ones are a total disaster, as you noted. I have an iron/station with those, and I use it mostly for engraving wood and melting plastic - that's about all it's good for. Soldering? -HA! I can maybe solder two 22 AWG wires together if I crank the heat up to 400C, lol.
                                        • Crystaleyes
                                          Tenma (Farnell-rebranded) 21-10115 solder station question
                                          by Crystaleyes
                                          Olá.
                                          Looking for some help clarifying something.
                                          I have a Tenma (Farnell-rebranded) 21-10115 solder station which recently burnt out the ceramic element.
                                          The station is 60W / 28 volts, 110v.
                                          Right now I'm in Brazil and finding an equivalent element has proved to be not possible, so today I bought a 'Yaxun' 50W 24v iron in the hope that it would work.
                                          Both irons have a five pin plug.
                                          The Tenma had pins 1 & 2 and pins 4 & 5 shorted with pin 3 being the ground. No means of measuring the temperature.
                                          10-19-2021, 08:08 PM
                                        • liquidzorch
                                          862D+ solder station iron out of control when fan on
                                          by liquidzorch
                                          Hello.
                                          I have a soldering station, 862D+, and every time the hot air gun is on, even if it is just cooling off, the soldering iron controller stops controlling. Let me explain what has happened so far, as it took a while to get to this.
                                          First, the switch that turns on the hot air gun started to fail, the light came on, but temp never rose, I would have to switch it multiple time to get the gun to start heating, this was due to the contact inside being carbonized. I opened the switch up, clean the contacts, and it would work fin for a while until carbonized again. So, I ordered a switch...
                                          06-09-2022, 08:49 PM
                                        • corrize
                                          Best way to solder LVDS connector for beginner (and qfn) ?
                                          by corrize
                                          Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                                          I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                                          I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                                          See the test :
                                          https://youtu.be/bNAzC-EvqHs?t=1767
                                          With hot air from bellow the board, that's...
                                          03-09-2023, 02:57 AM
                                        • SolomonMan
                                          SMDs and Solder/Hot Air Station...
                                          by SolomonMan
                                          All,
                                          Looking to solder some SMDs and using my Solder/Hot Air Station for more than taking Digitizers off Ipads/cellphones as I have done the past year or so with it.
                                          From the examples I have watched on youtube etc seems like they use flux and Solder Paste...Is there anything special about the Solder Paste...If so, what should I look for in Solder Paste and where can I source it for a small project.
                                          Chris
                                          02-10-2020, 07:18 PM
                                        • ugamazing
                                          Procedural question about BGA rework and removal of CPUs
                                          by ugamazing
                                          I have been working to develop a consistent and reliable method/workflow for removing, re-balling, and replacing CPUs on various MacBook Pro models (2015-2020).
                                          I have done OK so far, but there's one detail I need to sort out. I'm hoping someone much more experienced than myself may be able to shed some light:
                                          I am noticing the pulled CPUs (to be re-balled) come off fine, and they "look" fine as well, immediately when I pull them. However, within a few minutes, after cooling, the CPU chips develop a very, very slight curve/bend. It's SO SLIGHT, maybe a 1-2%...
                                          07-12-2022, 03:11 PM
