diy hakko t12
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    diy hakko t12
    I'm interested in this object
    https://www.ebay.it/itm/Digital-Sold...kAAOSww3tY3-v2
    but is the thermocouple stored in the tip that can be changed?
    • 31196
    Re: diy hakko t12
    yes, thermocouple and element are both in the tip.
    but that kit is rubbish.
    this is better:
    https://www.aliexpress.com/item/MINI...839523934.html
    you even get a case, dont forget to select which tip you want.
    btw, the handle is shit - so you should also grab this.
    https://www.aliexpress.com/item/SHEV...835065313.html
    • dellxps15
      • Feb 2014
      • 1598
      • italy
      Re: diy hakko t12
      63.90+7.90 for atten 8586. use if from years and always work fine. just had to replace once the thermocouple for few euros.
      add some extra tips and ur done for every work.
      buy good, buy once.
        • 31196
        Re: diy hakko t12
        but the iron is shit,
        and you can get the hot air unit on it's own - 858D for about 30 on ebay.
        • jasko_jacker
          • Oct 2014
          • 1140
          • italy
          Re: diy hakko t12
          for some years I'm using a Lukey 852D without any problem but with this type of soldering stations the thermocouple is placed directly on the heating element and I almost always use it with the temperature at max.
          • redwire
            Hakko 950 SMT hot tweezers but no base or stand
            by redwire
            I got gifted a Hakko 950 SMT hot tweezers but no base or stand.
            Any suggestions for building one?
            "The 950 is compatible with the Hakko 936, 937, 939, 703, 926, 927 and 928 soldering stations." Apparently it has two heaters in parallel "24V 50W", one RTD temperature sensor 43-58Ω at room temp. 5-pin DIN.
            I don't have any of those, have a 470-2 (no RTD in) and a FX-888A.
            04-17-2025, 03:01 PM
            What is a good brand of a HDMI monitor that is 10” inch or smaller I am interested in purchasing one
            I was looking for one on EBay but I am not sure what is considered a good brand and what is good price to consider when buying one
            Feed back wanted and website links are welcome ( I would refer a new one )
            I have a HP elite 8200/8300 computer that has a separate table top switching power supply ( that I planning on converting into a battery powered computer instead and I would refer a monitor that has an external switching power supply to power it )
            I plan on making a battery powered battery testing machine on a computer rack system
            I am not sure if...
            09-07-2024, 06:51 AM
          • Gjackson
            Question about UE60JU6800K backlight power.
            by Gjackson
            got my hands on a Samsung UE60JU6800K, initially it apparently had a bunch of white circles on screen which I confirmed was due to loose diffusers when I opened the set up and found a mountain of them at the bottom. The person I got if from stored the TV unused for a lengthy period after this so when I got it the backlight was completely gone. I took out the strips and almost all of the LED's have a crack on the yellow phosphor form the center of the LED outward, the ones that don't have this crack seem to work still (Maybe due to humidity after a long period?). Anyways I...
            06-11-2024, 06:03 AM
          • Rob Thomas
            HIKVISION DS-7204HQHI-SH, DS-80197 Rev 1.0 Unknown Password
            by Rob Thomas
            Hi Ladies & Gents,
            I am currently playing with and old Hikvision DVR for which I do not have the password. Is anyone able to help with the password on this or able to provide a bios flash image without a password?
            I would be interested in learning how to find where the password is stored in the bin file so that i know how to do this sort of thing for myself.
            DVR Details are:
            DS-80197 Rev 1.0
            Serial Number: 556775917
            Bin file from the bios chip (Winbond 25Q128FVSG) attached....
            04-28-2024, 04:41 PM
          • jayjr1105
            Finally bit the bullet on the Hakko FR301
            by jayjr1105
            I've been eyeing this thing up for years but could never justify the cost. I'm doing more console modding and repairs so I finally bit. I don't have it yet but wondering others opinions. I'll not be surprised to hear "you should have bought X instead". Unlike the hundreds of decent Hakko soldering iron clones, I didn't feel the chinese desoldering clones came anywhere near this unit....
            03-10-2022, 02:45 PM
